2020 Tundra would not start
Discussion in '3rd Gen Tundras (2022+)' started by PWMDMD, Nov 9, 2021.
  1. Nov 9, 2021 at 7:55 AM
    PWMDMD
    PWMDMD [OP] New Member
    Worcester, MA
    2020 Tundra Platinum
    Weird issue this morning for my 2020 Tundra Platinum. I remote started the truck with the ket fob and it started right up. I went out to the truck and opened the door and the truck did NOT shut off as it normally does. When I got in all things appeared normal except the red security indicator light was on. When I put the truck into the drive the engine cutout.
    For the next 10 mins when I pushed the brake and pushed the start button all the electrical components came on as normal but the engine made no sound. I locked and unlocked everything. I removed the negative terminal from the battery and the engine still would not start. I got out, locked the doors, and I was just about to give up when I tried starting the truck with the remote start again and it started right up. This time when I opened the door the engine shut off like normal.
    The truck then started up and I went to work like nothing happened. The security light was now off. When I got to work I restarted the truck several times with no problems. Any ideas?
  2. Nov 9, 2021 at 8:00 AM
    stecky
    stecky Tech Geek
    Dallas, TX
    2021 Nightshade CM MGM
  3. Nov 9, 2021 at 8:01 AM
    PWMDMD
    Worcester, MA
    Oops! Trying to multitask at work...thanks!
    stecky[QUOTED] likes this.
  4. Nov 9, 2021 at 8:04 AM
    PWMDMD
    Worcester, MA
    If a mod could delete this please.
  5. Nov 9, 2021 at 9:10 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Punishment for such violations require you pin up a 2022 Tundra poster in your bedroom, over the bed.
    In all seriousness, I hope you get the issue resolved.
    PWMDMD[QUOTED][OP] likes this.
