2020 Tundra hot start issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by bellwilliam, Sep 10, 2020.
  1. Sep 10, 2020 at 11:39 AM
    bellwilliam
    bellwilliam [OP] New Member
    William
    happened twice. Both times, ambient temp was 115F+. I've driven the car a while, stopped, then car will fail to start. Called roadside, but they were few hours out (not surprising, in 115F weather, more cars break down, everything moves slower). Finally car started after ~1 hour.
    Car cranks over easily, but just won't fire up.
    once (separate from 2 incidents above) the car took ~4 seconds before it fired up, weather was 112F.
    Took the car to dealership, they can't duplicate it (of course, we rarely get 110F+).
    Now I am stuck. I am scared of driving my new Tundra in hot weather. If I do, I don't dare turn the car off unless I know I won't need the car for a while. Getting stuck in 115F weather is not pleasant. I've asked the dealer to escalate it, but I think they blew me off. They said Toyota has no TSB on this either.
    I can't imagine I am the only one with the issue.
    Doxiedad likes this.
  2. Sep 11, 2020 at 6:18 AM
    blanchard7684
    blanchard7684 New Member
    What was fuel level?
  3. Sep 11, 2020 at 9:12 AM
    bellwilliam
    William
    fuel level was 1/4. first thing I did, was removing fuel cap and reinstall. I also though a possibility of bad fuel gauge, so I added 2 gallons (I was close to a gas station). After I got it started after an hour, I filled it up. can confirm it indeed was 1/4 tank earlier.
    2nd time, I knew what the issue was. Luckily I was at home. just left it alone and took another car. fuel level was may be 1/3 tank.
    btw, I never overfill the tank. always stop at the click.
  4. Sep 11, 2020 at 10:51 AM
    blanchard7684
    Well here is what I'm thinking:
    Bad fuel pump--sounds similar to the fuel pump recall.
    Vapor control system fault leading to entrained vapors in fuel.
    Fuel pressure control/regulator fault when hot.
    Contaminated fuel/fuel tank
    Plugged or defective in tank filter
    Outside of fuel system, it could be
    crank sensor or cam sensor that isn't synchronized right. Defective sensor may only have fault when hot.
    Leaky injector
    Throttle body issue
    MAF sensor
  5. Sep 14, 2020 at 11:05 AM
    bellwilliam
    William
    any recommendation what do to now? how do I escalate this with Toyota.
  6. Oct 6, 2020 at 9:45 AM
    bellwilliam
    William
    an update:
    it is a little worse now. Even in 100F weather, it will take a few cranks to start the car, but it does start.
    called Toyota, Toyota said nothing they can do unless they can replicate it.
  7. Oct 6, 2020 at 10:16 AM
    blanchard7684
    Is this a flex fuel configuration?
  8. Oct 6, 2020 at 10:16 AM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Surely, you can get it happening on video multiple times. Take the truck down, show the video, then either fix it or give me a new truck. It is a 2020 after all.
  9. Oct 6, 2020 at 10:22 AM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    park it at the dealer in the heat and have them out to start it up with you the next day
  10. Oct 6, 2020 at 10:22 AM
    bellwilliam
    William
    I have the video. but it still starts. weather is getting cooler, so it probably will fix itself in winter.
    no, it is no flex fuel. I wish they are, I was looking for flex fuel 1/2 ton, but couldn't find ANY new.
  11. Oct 6, 2020 at 10:25 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    When it won’t start, have you tried disconnecting and then reconnecting the battery after a few mins to see if that would help?
  12. Oct 6, 2020 at 10:30 AM
    bellwilliam
    William
    only times (twice) it didn't start were in 115F+ weather. I don't think we gonna get that kind of weather any more.
  13. Oct 6, 2020 at 10:31 AM
    bellwilliam
    William
    no, I did not. but what's the reason for that? there are no CEL. but I always carry an OBD reader, so I can reset it if needs to.
  14. Oct 6, 2020 at 11:00 AM
    bellwilliam
    William
    I did escalate it to Toyota headquarter. They sided with dealer. if it aint broken when I took it in, nothing they can do.
  15. Oct 6, 2020 at 11:09 AM
    TheBeast The Beach
    can you measure the battery voltage ? batteries dont like extreme heat. and toyota batteries are far from being reliable.
  16. Oct 6, 2020 at 11:14 AM
    bellwilliam
    William
    I will try that next time it has issues.
    TheBeast[QUOTED] likes this.
  17. Oct 19, 2020 at 1:43 PM
    bellwilliam
    William
    an update:
    it got worse and worse. next time it wouldn't start was in 103F weather. then happened again in 95F weather. Both times, it started after 1/2 hour sitting.
    There is a Toyota dealer was on my way to work. so I started driving to the dealer every morning. Turns the engine off, and waited a few minutes before starting it again. 3rd time was the charm. it stalled in the dealer's driveway and blocked service entrance :) (kinda happy as they wouldn’t fix it till then).... They installed a fuel pump (tech was surprised that it was a 2020, not 18/19), just picked up the car. will report later. but weather has gotten cooler......
    Black Wolf likes this.
  18. Oct 19, 2020 at 1:56 PM
    Hartsy8
    Max
    2020 MGM 1794
    At least they have seen it and documented it! Hopefully that was it
  19. Aug 30, 2022 at 4:18 PM
    abishop
    abishop New Member
    Allen
    2020 Crewmax 4x4
    Did the new fuel pump solve the problem? I'm having the same issue with my 2020 now.
  20. Aug 30, 2022 at 4:22 PM
    bellwilliam
    William
    Yes. New fuel pump fixed it.
  21. Aug 30, 2022 at 4:46 PM
    abishop
    abishop New Member
    Allen
    2020 Crewmax 4x4
    Great! I'll see how it goes with mine at the dealer tomorrow.
  22. Dec 12, 2023 at 1:33 PM
    craptundra
    craptundra New Member
    2020 tundra won't start when hot
    you're not the only one with this issue. Ive had it for 2 1/2 years and I live in Hawaii so it's every day. hate this truck. have had everything tested. replaced purge valve, battery, fuel pump brain. its been at Toyota 3 times for multiple days at a time. They say it always starts for them. right. they are useless. if anyone has had success fixing this please let me know.
