Tragdor's Form and Function Build
Discussion in '2.5 Gen Builds (2014-2021)' started by tragdor, Jun 27, 2020.
  1. Jun 27, 2020 at 6:17 PM
    tragdor
    tragdor [OP] New Member
    Austin, TX
    2020 Tundra SR5 4wd
    Coming soon...
    Hi all,
    I'm setting up my build thread for sharing the stuff done and things I'm learning. I moved from a 2018 Jeep Wrangler 4 door because I got into welding and needed to haul stuff. Plus it was a tight squeeze with the family in there.
    I've had a couple of trucks, a bunch of Toyotas, but never a Toyota truck. I'm hoping to build something that's a lot of fun, lasts with care and maintenance and allows me to pull anything else that's pretty fun too (like when I start looking for my hot rod build.).
    How she's set up at this time:
    Running list of upgrades:
    - Added factory bed rail system
    - Removed steps, added Amp Research power steps
    - TRD Pro grille/surround/bulge
    - TRD Pro black headlights with @iHacker plug and play wiring harness (thanks!!)
    - Tundra black chrome exhaust tip
    - Icon Stage 3 lift
    - Hostile Rage H113 20x9 -19mm offset
    - BFG KO2 tires
    On the list:
    - C4 overland bumper/winch setup
    Starting point:
    2020 Tundra SR5 4WD
    rxtJ_VzSB2R5eMvz_Hf6II3YZtQEDEfzoe_0kAW8_504a5603be959c161a2d55734d6eea10b31a3c88.jpg
    Added:
    TRD Pro grille/surround, bulge, garnish, black headlights
    9D-bP0h4C_121kUrWv4Vi68eiW5HUP96NDcfv6MQ_ceb48c5a965ef58d8f3ef37338e558b6ef627986.jpg
    Icon Stage 3 lift, Hostile wheels added
    YardBird and 300BLK like this.
  2. Jun 27, 2020 at 6:18 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Nice! Looks good! :thumbsup:
    tragdor[OP] likes this.
  3. Jul 17, 2020 at 7:11 PM
    tragdor
    Austin, TX
    2020 Tundra SR5 4wd
    Coming soon...
    Lift, wheels and tires added. She's looking fine!
  4. Jul 23, 2020 at 7:25 PM
    RobertG
    RobertG New Member
    Robert
    2020 Tundra Limited
    Just got my 2020 limited tundra in white as well. Yours looks perfect. Is there any way you can give me the part numbers you bought today put your grill together? Mine is currently chrome but I would like to upgrade to the Trd pro grille! Thank you!
  5. Jul 23, 2020 at 7:26 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
    tragdor[OP] and RobertG like this.
  6. Jul 25, 2020 at 2:20 PM
    tragdor
    Austin, TX
    2020 Tundra SR5 4wd
    Coming soon...
    @RobertG Sure thing. And this Ultimate OEM Toyota parts thread helped a lot too! The part numbers were in Super White, so they should work for you.
    Grille + Surround (everything between headlights, bumper and hood) -
    • 53101-0C070-A0 TRD Pro Grille - 040 Super White
    Bulge (top part connected to hood) -
    • 76180-0C030-A0 Hood Bulge (Super White - 040)
    Sensor garnish - It's a 2"x3" rectangle piece of plastic. Factory one is expensive but works without issue, aftermarket can cause headaches. I went with factory.
    • 53141-34010 (2019+ TRD Pro grille sensor cover)
    Important Clips - they hold on the garnish piece
    • 90183-06044 Cover Nut
    And, I can't tell if you already had the LED headlights. It looks like you do. If you don't and decide to do them, you need the lights plus a wiring harness adapter
    • 81110-0C211 2019 Tundra Headlamp Assembly Right-Hand - LED DRL - TRD PRO
    • 81150-0C211 2019 Tundra Headlamp Assembly Left-Hand - LED DRL - TRD PRO
    Harness adapter purchased from a member on here. High quality, plug and play and no cutting required. I'll send info if you end up needing this.
    Hope this helps!
  7. Jul 26, 2020 at 9:12 AM
    RobertG
    RobertG New Member
    Robert
    2020 Tundra Limited
    Thank you! This helps a lot.
  8. Jul 27, 2020 at 10:43 PM
    HighCountryTundra
    HighCountryTundra New Member
    Elijah
    2014 Black 1794
    What is the offset on your wheels?
  9. Jul 28, 2020 at 8:45 AM
    tragdor
    Austin, TX
    2020 Tundra SR5 4wd
    Coming soon...
    -19mm offset
    I've added to the top as well. I'm getting some rub with the lift/tires/wheels combo and need to take it back in this week. I'll let you know what ended up being needed to solve for that.
  10. Jul 28, 2020 at 10:07 PM
    HighCountryTundra
    Elijah
    2014 Black 1794
    Awesome! Looks great. Let me know what you find out. What size are the tires?
