2020 Sequioa and 2020 Tundra same front bumper?
Discussion in '2nd Gen Tundras (2007-2013)' started by Zafico, Sep 8, 2021.
  1. Sep 8, 2021 at 3:48 PM
    Zafico
    Zafico [OP] New Member
    Sam
    2020 Green TRD PRO Sequoia
    So I’m trying to get a after market bumper for my 2020 TRD Pro Sequoiaupload_2021-9-8_17-44-32.jpg
    Identical to this one. And I want to replace the front bumper because of the Houston drivers and they love trading paint with me for some reason especially when I park it. So I’ve been looking on Instagram to find a bumper but no one makes one for the sequoia but I did notice from this forum there’s a lot of Sequndras and I was hoping this company.
    https://www.instagram.com/p/CSNeJC7JA_C/
    That makes it for the tundra would fit. But they’re not sure themselves. Does anyone here know if this would work?
  2. Sep 8, 2021 at 3:50 PM
    GODZILLA ASCM#1 Douchebag formerly known as 50 Buck
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    You might be better off looking for a bumper for the 2nd gen (2007-2013) Tundras as they share a few parts/designs with the current Sequoias.
    1lowlife likes this.
  3. Sep 8, 2021 at 4:31 PM
    Zafico
    Sam
    I’m not sure if I’m using this thread system correctly so I apologize in advance. But I saw some forums saying that are really close but I don’t know to what extent. I know that the tundra is different in the back because tundras are longer by about 2 feet but I’m just curious about the mounting points for the bumper
  4. Sep 8, 2021 at 4:36 PM
    Wyoming
    Yeah, you are asking in the forum section that is for the new 2022+ tundras. You'd want the 2nd gen section. I'll put a link at the end of this post.
    I don't have a either a Sequoia or a 2007-2013 Tundra, I just know that the Sequioa is heavily based on them. With some swapping I know some members have swapped the grilles, headlights, and the panels under the headlights, but I don't know for the bumper.
    You might try asking in here (2nd gen) to see if anyone knows better than I do.
    https://www.tundras.com/forums/2nd-gen-tundras-2007-2013.26/
  5. Sep 8, 2021 at 4:39 PM
    Wyoming
    You can either retype it all over there, or ask the mods to move it.
    I'll hit the report on this one to get it moved, and you should get better traction.
  6. Sep 8, 2021 at 6:23 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Moved
    GODZILLA and T-Rex266 like this.
  7. Sep 8, 2021 at 6:24 PM
    Wyoming
    Thanks, Brian. :hattip:
  8. Sep 8, 2021 at 7:13 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    Reg Cab Gang
    I think the Sequoia peeps use a '07-13 Tundra bumper. The front end is nearly identical except the bumper cover is different and the Sequoia grille is shorter and you will have a gap at the bottom. Depending on what bumper you buy it may not even be noticeable or you can change to the taller Tundra grille.
    Some of the '07-13 guys have used '14-21 tundra bumpers. The main mounting points are the same, but do to the different front end it required modifying and keeping the upper bumper fascia on the '07-13 trucks with the newer bumper. Though I can't recall seeing one used that had the brush guard. I think the hoops would be in the wrong places.
  9. Sep 8, 2021 at 7:16 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    You would need to find a 2nd gen tundra bumper to fit the 2nd gen Sequoia. You can look into doing the 3rd gen Tundra front end swap if you like the 3rd gen options but that involves more work and body panel replacements.
