2020 Radio in a 2018 help
Discussion in 'Audio & Video' started by SnrDisregardo, Feb 18, 2022.
  1. Feb 18, 2022 at 10:30 AM
    SnrDisregardo
    SnrDisregardo [OP] New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Hey everyone, I went through and got a 2020 JBL OE radio along with the amp and the harnessed need to do the conversion, but am having issues with CarPlay not wanting to hook up. I've tried doing a soft reset by holding down the VOL knob, but it isn't a absolute fix. The only thing I haven't tried yet is bypassing the USB jack and plugging at the adapter harness.
    Anyone else having intermittent issue with CarPlay hooking up on a 2020+ OE radio? Wondering if the unit I got was bad?
  2. Apr 19, 2022 at 10:19 AM
    Fish River Tundra
    Fish River Tundra New Member
    JD
    Nashville
    ‘16 Platinum
    did you ever get it to work? Am doing the same conversion from a platinum as well
  3. Apr 19, 2022 at 10:24 AM
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    When i had this setup in my 2019, the head unit was very sensitive to using an apple cable only.
    In the end it still was such crap I abandoned the conversion for a pioneer head unit which works perfectly.
  4. Apr 19, 2022 at 10:26 AM
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    did you find a video to help connect the harness' or did you just figure it out? have a '20 harness that one adapter will fit in two different slots in the back of the new head unit. didn't know which to plug it into
  5. Apr 19, 2022 at 10:29 AM
    OGDark Knight
    Jeff
    Autoharnesshouse.com is where i got all the wiring. All my connections were an only fits one way type thing
    sgtfluffy16 likes this.
  6. Apr 19, 2022 at 10:32 AM
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    I got it there as well. There is a plug on the new harness that will fit into two different inputs on the back of the new head unit. Didn’t know where it went
  7. Apr 19, 2022 at 10:33 AM
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    It fits perfectly into either white input in the background
  8. Apr 19, 2022 at 11:31 AM
    OGDark Knight
    Jeff
    Maybe send them an email?? They were quick to answer my questions pre purchase.
  9. Apr 19, 2022 at 11:40 AM
    SnrDisregardo
    Wade
    IL
    I had the same issue. Switched which plug it went to and it worked. The only issue I am having is the USB port adapters not working. I wound up cutting and soldering both to about a 6”-8” solid adapter. Only an Apple cable will connect and charge along with my wireless adapter.
    I know I’m nuts for not just going aftermarket but I didn’t want to have a separate mic just laying about and that jack being useless. I still can’t believe they sell the JBL as a premium.
  10. Apr 19, 2022 at 11:42 AM
    SnrDisregardo
    Wade
    IL
    Also if you got the JBL, you need the ‘20+ amp as well.
  11. Apr 19, 2022 at 11:50 AM
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    Thanks for the reply. I already have the amp, and really didn't want to possibly fry the HU by switching the plugs. I'll let you know if I have any issues with the CarPlay
  12. Apr 19, 2022 at 2:27 PM
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    How did you get the navigation to load?
  13. Apr 19, 2022 at 2:35 PM
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    Did you have to break this down to put in the CarPlay usb unit or did you install it in a new housing
  14. Apr 19, 2022 at 2:47 PM
    OGDark Knight
    Jeff
    Man you’re in deep. Its a plug and play situation!
    SnrDisregardo[OP] likes this.
  15. Apr 19, 2022 at 2:59 PM
    SnrDisregardo
    Wade
    IL
    I didn’t touch that. There is an adapter from the ‘18 to male usb and female usb to ‘20 that I chopped. I didn’t touch the dash usb switch.
  16. Apr 19, 2022 at 3:00 PM
    SnrDisregardo
    Wade
    IL
    Did you get a radio with the navigation unit? I saw many on eBay that didn’t have it. On the head unit, there should be 2 “modules”.
  17. Apr 19, 2022 at 4:52 PM
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    Yes, it should have navigation. It came out of a ‘20 1794
  18. Apr 19, 2022 at 5:37 PM
    SnrDisregardo
    Wade
    IL
    Just making sure. I saw a lot when I was looking that were JBL and no nav.
    This is the standard one. Does yours have a second row of plugs?
  19. Apr 19, 2022 at 5:42 PM
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    Yes, and it had a few wires connecting both sections
  20. Apr 19, 2022 at 6:24 PM
    SnrDisregardo
    Wade
    IL
    Ok. Then you have the navigation. Did you get the adapter harness for that as well? Mine come up after a few minutes once it acquired the signal.
    IIRC, there should have been the radio adapters, USB adapters, gps adapter, and the amp harness.
  21. May 14, 2023 at 8:41 PM
    Tundramann32
    Tundramann32 New Member
    2018 SR5 CrewMAX
    Truxedo, side steps, rockstar rims, tint, red calipers
    I’m purchasing a 2020 non jbl and installing into a 2018 non jbl.
    Would autoharnesshouse have what I need to plug and play? I noticed some question if the usb connection would work.
  22. May 15, 2023 at 6:16 AM
    SnrDisregardo
    Wade
    IL
    Yes, they have everything you need.
  23. Sep 20, 2023 at 6:07 PM
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    Still have any of this? Sell it to me?
  24. Sep 22, 2023 at 4:01 PM
    OGDark Knight
    Jeff
    All parts were sold
