2020 Leaking Rear struts
Discussion in 'General Tundra Discussion' started by BoerboelTundra, Dec 16, 2020.
  1. Dec 16, 2020 at 8:31 AM
    BoerboelTundra
    BoerboelTundra [OP] New Member
    2020 Tundra Super White SR5
    Has anyone had problem with there struts leaking? My 2020 truck has less than 10,000 miles and the one of my rear struts is leaking. Toyota says it’s not “leaking enough” to replace yet even though it’s under warranty.
    wondering if this is a coming problem?
    Is it worth upgrading the struts and paying for the upgrade?
  2. Dec 16, 2020 at 8:38 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Heck no, don't spend your $ unless you wanted to upgrade the suspension anyway. Should be a warranty repair, shocks should not leak, even a little. I would keep pushing on it and/or hit up another local dealer. Any of them can perform warranty work.
    So how much is a little leaking?
    BoerboelTundra[OP] likes this.
  3. Dec 16, 2020 at 8:45 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    BoerboelTundra you have shocks in the rear.
    Take a some oil of sort in a squeeze bottle and squirt it somewhere at the top of the boot or shock so its "wet enough to replace it" then make another service appointment stating your complaint is now a drip or puddle under that particular side of the truck.
    (I work for a dealership and "its all in how you word or explain the concern"
    Good Luck
    RdKing
  4. Dec 16, 2020 at 8:48 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    A leaking strut is a blown strut, they can't be repaired, leak will only get worse.
  5. Dec 16, 2020 at 8:48 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    If it's wet at all, it's "wet enough" since shocks are supposed to be sealed. :der:
    Try a different dealer. Look and ask around for ones in your area with a service department known for better service.
  6. Dec 16, 2020 at 9:07 AM
    Kanobi13
    Kanobi13 New Member
    All great advise
  7. Dec 16, 2020 at 10:30 AM
    BoerboelTundra
    Thanks guys, I appreciate the advice and will be calling to make an appointment to have it replaced ASAP
  8. Dec 16, 2020 at 12:17 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had a 5160s from factory on my last Tacoma and one had a slight leak. Dealer replaced under warranty. Only problem was they ordered the wrong shock. They had never seen a Tacoma with remote resi's
  9. Dec 23, 2020 at 3:34 AM
    bjohnson425
    bjohnson425 New Member
    Brandon
    Sounds like a good time to throw some 6112s on there
  10. Dec 23, 2020 at 3:52 AM
    P-Factor
    P-Factor New Member
    Don't be afraid to play a liability card if needed by putting them on notice. "If a strut is leaking fluid, this severely impacts its ability to absorb the wheels impact from the road. This means that the wheels are less likely to stay in contact with the road than if the struts were working properly. As the wheels have less resistance, this makes them more prone to an uncontrollable bounce, which can eventually make driving dangerous and increase the likelihood of an accident, especially during adverse weather".
    Haggis777 likes this.
  11. Dec 23, 2020 at 3:53 AM
    timsp8
    NY
    Like others said, once the seal is blown the shock will continue to leak until there isn’t enough to provide any dampening and no way to fix it unless its rebuildable, which stock shocks are not. You could try what others said about squirting some oil on it, go to a really bumpy road right before going to the dealer, or try a different dealer and be that person that won’t leave until it’s fixed.
    I have read where people drive for years on a leaking shock. My 6112s leaked after about 6 mo and I drove for awhile before replacing it. So if you don’t get in right away, it shouldn’t hurt anything. It’ll only get worse and your have a warranty for a few more years.
    Can you post a picture of it?
  12. Dec 23, 2020 at 6:16 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Like others said - don’t accept the service writers response. Escalate - speak to the service manager and if you don’t get resolution call Toyota and file a complaint. I sold my F-150 for a lot of reasons including shitty dealer and Ford Corporate. I will never buy a Ford again because of their inability to foster a good customer experience.
    If Chevys weren’t such shitty trucks I’d buy one, I have a great local dealer but I hate the newer Chevy trucks.
  13. Dec 23, 2020 at 6:19 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Dang.... you're good!
