2020 DRL fog lights mod?
Discussion in '2.5 Gen Tundras (2014-2021)' started by lassiter1979, Aug 24, 2020.
  1. Aug 24, 2020 at 11:19 AM
    lassiter1979
    lassiter1979 [OP] New Member
    Donnie
    NC
    2020 Tundra SR5 Crewmax 4x4 in Silver Sky Metallic with XSP Package
    3" front lift, 1" rear lift; BFG KO2 295/60R20; color matched front grille and hood bulge
    Is there a mod someone knows about to turn off the DRL fog light feature (where only the outer circle of the fog light is illuminated)? I can't seem to find anything in the forums to take care of this. The full fog light looks good when on, but who wants to ride around in the daytime with fog lights on? The outer ring only makes the truck look very dinky. Stupid even.
  2. Aug 30, 2020 at 10:26 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    Can you post a picture of what you're seeing and explain how you get it to do that? Mine only has fogs on or off; I'm not seeing this outer ring.
    AggiePhil likes this.
  3. Aug 31, 2020 at 11:54 AM
    lassiter1979
    Donnie
    NC
    This is what I get with DRLs on, fog lights off.
  4. Aug 31, 2020 at 11:56 AM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    Must be unique to that XSP package? Mine definitely doesn't have that.
  5. Sep 7, 2020 at 6:33 AM
    lassiter1979
    Donnie
    NC
    Looks like it is just an XSP thing. So weird they'd fool with that on a regional package.
  6. Sep 7, 2020 at 6:40 AM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    I wonder if you could buy the stock fog lights and swap them out.
  7. Sep 7, 2020 at 7:32 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That was a pretty dumb idea on Toyota's part.
    I think people that run their fogs at night in clear weather are goofy.
    Running them during the day, I can understand your concern.
    You could get behind the light and cut the wires that feeds the DRLs.
    Maybe even find a feed under the dash and place a switch in line to turn them on and off.
    But the dealer would probably give you sh!te whenever you have it in for service.
    My 2005 had a plug next to the battery that fed the DRLs, there were the actually dimmed down headlights.
    I kept it unplugged, but every time I had it in for service they would plug it back in.
    They said they had to plug them in and having working for some reason.
    Since you have the fender flares (that give a rugged look) you might opt to replace your fogs for a pair of Rigids.
    There is a mod that uses TRD Pro bezels and you mount Rigids in them.
    I did it for my 2014..
    https://www.tundras.com/threads/diy-trd-pro-rigid-fog-lights.34224/
    I still have DRLs that are my turn signals on my 2014.
    I like them, they match up with my grille and Rigid pod LEDs
    I'm not sure if removing DRLs are part of any inspection or requirements if you remove them.
    rjz07cg4_zpsh5yoyzge_06b53c46f1294c8af68d938678d050d565370607.jpg 4omfkzbu_zpseaj58bgb_67e3f8344a97c3fbf1cd65947dd9329e17d08495.jpg
  8. Sep 11, 2020 at 8:43 AM
    lassiter1979
    Donnie
    NC
    I agree, stupid idea and I hate it. I like your idea of cutting the DRL wire to them. Any idea where I can find which wire it is?
    Your Rigids look great btw, I will add it to my future mod list when wife approves more expenditures :anonymous:
