2019 Tundra Limited with JBL Audio Upgrade
Discussion in 'Audio & Video' started by rawn027, Jul 5, 2019.
  1. Jul 5, 2019 at 2:43 AM
    rawn027
    rawn027 [OP] New Member
    2019 Black Tundra Limited
    I am going to document my audio upgrade of my 2019 Tundra Limited with JBL Audio here. Everything is going to be gutted, but most likely going to start with the head unit.
    Requirements:
    • Must retain secondary display function as well as steering wheel controls.
    • Must look as good or better than factory.
    • Must be able to return to stock.
    • Must retain backup camera.
    Head Units:
    I will be looking at only mech-less units. I have no need for a CD player or navigation as I will be using CarPlay w/ Waze. I stream music using Tidal at high bit rates so audio quality is paramount.
    • Mech-less
    • Capacitive Screen (Much nicer touchscreen - like a Phone)
    • Wired or Wireless CarPlay (Will Be Using Wired for Better Audio Quality)
    The good news is there are only 5 options (with proper iDatalink support) after you narrow this down via the above list!
    Units WITHOUT iDatalink Serial Cable, Wired Remote Only
    So these are out.
    Every single one of these are 480p displays, so there is no difference in resolution between any of the units in this class. Some top-of-the-line nav models have 720p resolution.
    I was not impressed with my Pioneer unit previously, and Son'y pre-out voltage is low at 2V. I will be focusing my decision on the Alpine and Kenwood options.
    Alpine has the accessory kit to control lights/winches/etc, so that is a compelling feature that Kenwood doesn't have.
    iDatalink Maestro RR with iDatalink Serial Cable to retain all factory functionality (except turn-by-turn directions).
    More coming soon..
  2. Jul 5, 2019 at 3:09 AM
    rawn027
  3. Jul 5, 2019 at 3:46 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
  4. Jul 5, 2019 at 3:53 AM
  5. Jul 5, 2019 at 4:24 AM
    rawn027
    Did you keep the middle dash speaker? If so what did you drop in there?
    I’m considering converting the fronts to 3-way components and doing an active crossover. If I did that I’d just unhook the center dash speaker.
    Seriously considering AudioControl D series amps that include DSP.
    Focal makes a killer 3-way pair.
    I already have an ARC audio black 10” sub I’ll be reusing.
  6. Jul 5, 2019 at 5:27 AM
    timsp8
    NY
    I’m sure you are shopping around but if not those prices are anywhere from $50 to $150 less on Amazon for the head units.
  7. Jul 5, 2019 at 5:28 PM
    rawn027
    Yes, I am. However, my trust for Amazon is near-zero. Esp. if they're not listed as authorized sellers.
  8. Jul 5, 2019 at 5:39 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If you wanna keep your center channel, I'd take a look at tech12volts dual JL c1 tweeters, he makes a nice bracket for them to bolt right up. Actually the best deal on everything you need, plus great service and support will likely come from James @tech12volts.
    I do not think that there is any aftermarket head unit or integration unit(PAC or maestro) that will allow you to keep 100% of the features of you OEMsystem, specifically the turn by turn navigation display on the dash mini screen.
    You should be able to find an idatalink maestro RR for less than $140, maybe 140 including TO2 harness. Check ebay and Amazon, I'm talking brand new, not used.
    Wireless CP/AA is a cool feature but as far as CarPlay goes, I have not heard much good about it via wireless connection, android auto seems to have decent, at least better, wireless connection reviews.
    Good luck in your search. Don't forget to get in touch with James @tech12volts. Keep us posted
  9. Jul 5, 2019 at 6:19 PM
    rawn027
    I had wireless CP in my previous car BMW 230i. Audio quality was worse when wireless. GPS drains battery so much that you want to be plugged in anyway.
    Maestro RR apparently can do turn by turn on the Kenwood according to the iDatalink site. I found the features vary quite a bit depending on the radio selected.
    I am leaning towards the Alpine ILX-F309-TND just because it’s plug and play. Eventually will upgrade speakers and add an amp buy this is ready to go to support both the JBL system and future line out.
  10. Jul 6, 2019 at 1:07 PM
    rawn027
    Migraine likes this.
  11. Jul 6, 2019 at 1:23 PM
    rawn027
  12. Jul 6, 2019 at 1:32 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Love this headunit! It really woke the factory JBL system up. Probably 3x the volume capability. Still need to go through and adjust equalizer to tune it in. I use android auto with Waze. Factory steering wheel controls work except for the call and hang up buttons. Center screen on my 18 Limited remained functional as OEM standards EXCEPT the turn-by-turn nav on the screen. Actually good for me as I didn't have a way to turn it off on the factory head unit
  13. Jul 7, 2019 at 8:34 AM
    rawn027
    @YotaMan thanks for the side angle shot, this is what I think a lot of people are curious about. It looks very clean and a clear upgrade!
  14. Jul 7, 2019 at 10:52 AM
    rawn027
    So I have been doing some research on speakers, it is kinda crazy, but I have landed on a few options...
    Speakers
    1. Delete Center Dash
    2. Upgrade Dash Corners OR Install Front 3-way Components
    3. Upgrade Front Door w/ Components
    4. Upgrade Rear Door w/ Components
    Focal Access Series, 3-way in Front, 2-way in Rear
    • Front Door: Focal Access 165-as3 (Requires Bigger Modification)
    • Rear Door: Focal Access 165-as
    Focal Plug and Play
    I am trying to verify these can be used without an amplifier and/or are they truly plug and play in the 3rd gen tundra w/ JBL.
    AudioFrog Components in Front + Rear + Dash Corners
    • Front + Rear Door: AudioFrog GS60 + GS10 + GS610c + GS10 (Dash)
    Alpine X Series in Front + Rear
    • Front + Rear Door: Alpine X-S65C
    Focal Plug and Play
    https://www.youtube.com/watch?v=YjEKZjAS-6c
    Focal 3-way in Tundra
    https://www.youtube.com/watch?v=uf-4_HkwUQo
  15. Aug 9, 2019 at 3:45 AM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Any issues with Halo-9 and Sirius XM?
  16. Aug 9, 2019 at 3:59 AM
    rawn027
    You can get an adapter to reuse the antenna but you will need to buy a new tuner.
    HighonFirewood likes this.
  17. Aug 14, 2019 at 6:47 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    No issues. Factory antenna worked fine with it. Just need the module installed.
  18. May 13, 2020 at 12:44 PM
    kentran5397
    kentran5397 New Member
    Dallas. TX
    2014 Tundra 1794 Edition
    2019 Trd Pro LED Headlight 2019 1794 Grill LED Interior and Reverse Light LED Bedlight Vled Footwell LED Driver Side Grab Handle Bullet Fender Flares MX4 BakFlip Start X Remote Start Dual USB ports for the front and rear KO2 A/T Tires 275 60 R20 *Future Mods* TRD Rear Sway Bar Leveling Kit 38 gallon fuel tank swap
    Were you able to find out if these speakers were complete plug in play for the 3rd gen Tundras with the JBL audio system?
