2019 Tundra and Jayco Jay flight 264BHW
Discussion in 'Towing & Hauling' started by peter2516, Sep 23, 2019.
  1. Sep 23, 2019 at 12:41 PM
    peter2516
    peter2516 [OP] New Member
    Peter
    2019 Metallic Tundra
    none yet
    New member here. Below are the numbers from my 2019 Tundra. Newbie here as in no experience towing except a small utility trailer. But none with travel trailers. We bought a travel trailer with dry weight of 4425 lbs and payload capacity of 2075 so GCWR? GVWR is 6500. We don’t intend to use the payload capacity. Can the Tundra tow this Jayco without any problem? Weight wise? Thank you so much.
  2. Sep 23, 2019 at 12:48 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Yes, a Tundra can tow that without issue so long as you use 1) a WDH, 2) sway control bar and 3) understand how to use the brake controller. If you’re going to tow it regularly, you’ll probably want to upgrade to load E tires when you replace the factory set.
    ETA don’t expect more than 10 mpg towing. Worse in the mountains.
  3. Sep 23, 2019 at 12:54 PM
    peter2516
    Peter
    none yet
    Thank you so much. I will make sure the sway control bar, And make sure I understand and learn more about that brake control feature. Already got a WDH Eaz lift elite the trailer came with it. But I am interested in Equalizer 4.0 or dive in to one of the Hensley. Reconditioned Hitches Hensley
  4. Oct 14, 2019 at 12:13 PM
    Tundraman479
    Tundraman479 New Member
    Barry
    2018 Tundra CM Limited TRD Offroad Cement
    5100's top setting 295/70/18 Cooper Discoverer AT4's
    I tow a 26' travel trailer with my Tundra, and it does great but that 5.7 is thirsty! Make sure you get a WDH and get it setup correctly. Also take your time and don't get in a hurry because even with the factory trailer brakes it still takes longer to stop the truck and travel trailer. I general get around 8-9 mpg when towing my travel trailer, that is with me taking it easy on the accel and usually trying to run about 65mph or so on the interstate.
    peter2516[OP] likes this.
  5. Oct 15, 2019 at 6:13 AM
    peter2516
    Peter
    none yet
    Thank you very much. I will keep that in mind. Much to learn about the integrated brake control. Our trailer will be ready in 2 weeks. Nervous and excited here.
  6. Oct 15, 2019 at 6:21 AM
    Blueknights75
    Ron
    Clayton, NC
