2019 TRD Sport Wheel & Tires Setup
Discussion in 'Wheels & Tires' started by cangulay, Dec 16, 2018.
  1. Dec 16, 2018 at 8:37 PM
    cangulay
    cangulay [OP] New Member
    This is my first truck ever and i was reading old posts but decided to ask,
    I ended up buying ridgegrappler 295/65/20 tires and thinking to buy 20x9 (or maybe 20x10 if better fit?) fuel vapors after i install 3/2 leveling kit. Since bold pattern is 5x150 they offer +1 or +20 offset. Which one will be a better fit i have no idea. Thanks for replies.
  2. Dec 16, 2018 at 8:40 PM
    Welcome from NY.
    Check the tire threads for all your options.
  3. Dec 16, 2018 at 8:53 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    Here’s a 35x12.50 on my 20” fuel assaults with a +20 offset. I wanted it as close to flush as possible. These still stick out over an inch. If I had gone +1, I think my rubbing would have been worse, and they would have definitely stuck out further.
    94D8AF65-2B2F-48BF-86D0-09F31008B82A_zps_af7ab7709df1a4582f82edf1d0d2e44308ce8723.jpg
    Down the side shot.
    0F8974F5-B203-4770-8897-2A28E1C85443_zps_61b559f6af5d71c1d152ef3d41708856dffb67e0.jpg
    So I would suggest +20 to stay as close to flush as possible, your trucks paint will thank you!
  4. Dec 16, 2018 at 9:04 PM
    cangulay
    Thanks for the info. Assaults offer +20 offset, vapor is +18. How hard to fit +18 offset ? What do you think?
    TuFerLife likes this.
  5. Dec 16, 2018 at 9:11 PM
    cangulay
    They also have +35 offset for vapors
  6. Dec 17, 2018 at 9:33 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    So there’s a formula out there that will tell you how far they will poke out depending on tire size and offset. You should be able to search in here to find it.
    Since your tires are slightly smaller than mine, but offset is a little more aggressive, I think you’ll still see over a 1” poke with this offset.
    I bet +35 might be slightly tucked. It depends on what look you’re going for. I am looking for flares or midflaps or something because the side of my truck just gets nasty because tires are throwing everything on the side.
    I think the overwhelming consensus you will get is that a little bit of a poke is a better look than it being tucked in. But it will be more work to keep the truck clean.
  7. Dec 17, 2018 at 9:50 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    You want some flares? I have some I bought for mine. They are Bushwacker (not pocket style) painted Super White
    TuFerLife[QUOTED] likes this.
  8. Dec 17, 2018 at 9:53 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    Sent PM
  9. Dec 17, 2018 at 7:28 PM
    cangulay
    @TuFerLife at this point i am only worrying about better fit. Doesnt really mattet how 20 or 35 offset looks, so what you are saying is 35 offset will be better fit ?
  10. Dec 17, 2018 at 7:52 PM
    TuFerLife
    Taylor
    Chattanooga, TN
