2019 TRD Pro grille garnish kit alternative to Ares Fabrication
Discussion in '3rd Gen Tundras (2014+)' started by jones83, Oct 28, 2018.
  1. Oct 28, 2018 at 12:30 PM
    jones83
    jones83 [OP] New Member
    2016 Blue Tundra CrewMax 4x4
    Since ARES Fab. has said that he is no longer producing a garnish kit for the hole in the 2019 TRD Pro grille, does anyone know of an alternative piece to insert into the grille? The OEM piece is pretty expensive for what it is. I know one person used black plexiglass, but I was looking for something a little nicer.
    Maybe a forum vendor will step up and create an insert?
  2. Oct 30, 2018 at 11:16 AM
    slevin_senpai
    slevin_senpai New Member
    I'm looking for something as well, had mine on order from Ares two weeks ago and got refunded suddenly from paypal.
  3. Oct 30, 2018 at 12:19 PM
    jones83
    So I guess noone will make something for the 2019 grille? I'll just get the 2017 if that is the case. I'm not leaving a hole in my grille.
    lionix and LVLDUP18 like this.
  4. Oct 30, 2018 at 12:30 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Unfortunately, your options are limited. If you have a 2018/19 with the TSS sensor then your best bet is to stick with one of the stock grilles (Limited or honeycomb style) or pay up for the OEM garnish. The sensors on our trucks are very finicky and calibrated to work in stock configuration.
    The guy that used plexiglass fitted a 19 Pro Grille on his 17 and didn’t have the sensor to worry about. If you want to go the route of fitting a 17 Pro Grille you’ll still need a way to relocate the sensor. I’ve seen a few options for this including the Ares bracket, a 3D printed bracket, and another aftermarket company producing one. A quick search on the forum should produce what you’re looking for.
    ARES likes this.
  5. Oct 30, 2018 at 12:34 PM
    TNtundra18
    TNtundra18 New Member
    Charlotte, NC
    2018 Tundra Limited
    I’ve got a 2017 pro grille in my garage I’ve yet to install on my 2018 because of my TSS relocation fear
  6. Oct 30, 2018 at 12:34 PM
    jones83
    I have a 2016 so no sensor on mine. One more reason why it is hard for me to digest paying almost $400 for a plastic cover.
    Paulie likes this.
  7. Oct 30, 2018 at 1:50 PM
    ninjajay
    Jay
    Screwston
    2018 MGM 1794 TRD 4x4
    Exterior LEDs, Pioneer 4200NEX, iDatalink Maestro, Ambit RS02, Nitto Ridge Grappler, Toytec/Radflo
    Jomax customs
  8. Oct 30, 2018 at 4:36 PM
    Vizsla
    Vizsla Dinkus
    Dave
    Arizona
    2018 Cement Crewmax
    They are “sold out”, thinking you might not see anymore of them. You are so screwed if you cause a front end collision with anyone’s modded tss crap.
    ColoradoTJ likes this.
  9. Oct 30, 2018 at 4:54 PM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    One word..... liability.
  10. Oct 30, 2018 at 5:02 PM
    Vizsla
    Vizsla Dinkus
    Dave
    Arizona
    2018 Cement Crewmax
    I’m going to try and help you, don’t care if you can respect that or not. Because it can, and someone will use it on an 18+, you are screwed.
    LVLDUP18 likes this.
  11. Oct 30, 2018 at 5:47 PM
    Vizsla
    Vizsla Dinkus
    Dave
    Arizona
    2018 Cement Crewmax
    It’s not worth it, just being honest. It’s a garnish for a 2019 Pro grill, won’t stop someone from using whoever’s bracket is left floating around from the 15-17 Pro gill. It’s the world we live in. You need to look inside and understand what you have out there running around currently, think the members should know.
  12. Oct 30, 2018 at 5:56 PM
    T-Rex266 Moderator Staff Member
    There are things I mess with on Toyota’s, and there are some that just aren’t worth it.
    Erichudgins, ColoradoTJ and Vizsla like this.
  13. Oct 30, 2018 at 6:03 PM
    ColoradoTJ Professional Cat Herding Expert Staff Member
    White 3500HD
    Fuzzy Mirror Dice
  14. Oct 30, 2018 at 6:17 PM
    Vizsla
    Vizsla Dinkus
    Dave
    Arizona
    2018 Cement Crewmax
    And just so everyone understands, it logs and keeps every event in the system, if you get the brake warning, camera is capturing images, and those are permanently saved from every event as well. I can’t verify for sure, but myself, and 4 others in my research still get the brake warning with it off, its recording. Toyota is not gonna hang for it, they are well prepared and already litigated it. Its called gross negligence if you change the system, that includes putting a 19 Pro grill on a non Pro, even if done completely perfectly.
    aperezsh, LVLDUP18 and ColoradoTJ like this.
  15. Oct 30, 2018 at 6:54 PM
    jones83
    Is your ebay store back open?
  16. Nov 24, 2018 at 8:20 AM
    nmpeter
    nmpeter New Member
    Got in contact with “Ares”
    Any reason why he’s not in here anymore? He said he’s still producing a 2019 cover for the pro grill.
    JoshuaA likes this.
  17. Nov 24, 2018 at 9:01 AM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Damn what a PITA. I got a 2018 and I guess I'll never get to install an aftermarket grille. Didn't realized the damn truck had a freaking black box too.
  18. Nov 24, 2018 at 9:05 AM
    JoshuaA
    JoshuaA Modding will be the death of me
    Southern Ontario
    Haven't decided here which, might do the plexi as I'm installing a front cam
  19. Nov 24, 2018 at 11:24 AM
    Nick452
    Nick452 New Member
    So if you change out the honeycomb grill with a stock limited grill on an 18+ it will be ok? No doom and gloom?
  20. Nov 24, 2018 at 1:52 PM
    AirborneGrunt
    AirborneGrunt New Member
    Shannon
    2014 Black Tundra
    Pro Comp 6 inch lift, Pro Comp skidplate 20' Fuel Full Blown wheels, MT2 tires, NFAb prerunner bar
    Following, as I am currently doing a build on a 2018 SR5. I purchased a Quicksand surround, bulge etc to replace the chrome/honeycomb that this truck came stock with. The dealer WILL NOT replace the honeycomb as it messes with the TSS. The truck came with the TSS sensor stock and I wanted to put the TRD center in to replace the honeycomb. . So, according to this thread, the relocater bracket for the TSS sensor is a bad idea if you want to run the TOYOTA TRD grill, or any aftermarket grill for that matter ? I am definitely concerned about liability , etc for the TSS. Am I shit out of luck and HAVE to run the honeycomb? ....or am I just taken to many hard knocks to the head and not fully understanding this?front end1.jpg front end.jpg
    aperezsh likes this.
  21. Nov 24, 2018 at 2:38 PM
    ninjajay
    Jay
    Screwston
    You have to run the honeycomb (or limited/1794 bars). Anything else is at your own risk.
    Nick452 and KnuckleHD like this.
  22. Nov 24, 2018 at 5:46 PM
    KnuckleHD
    You should be able to switch back and forth between the honeycomb and limited grille without issues. Many people here have done it without issue. The sensor, bracket and mounting points are all identical.
    The issues arise when trying to replace one of the above options with an older model or current model pro grille.
    Nick452 likes this.
  23. Nov 24, 2018 at 6:20 PM
    Norfolk757
    Norfolk757 Zionist Life
    Tom
    Norfolk, VA
    Can you please tell me how I can order one from you. I have a 2015 SR5 With a 2019 TRD Pro grill.
    He is no longer selling on this site.
    Check eBay
  24. Nov 24, 2018 at 6:30 PM
    White 3500HD
    Fuzzy Mirror Dice
    His own request, then has tried making duplicate accounts to get back on.
    He still sells on eBay.
    I agree with @Vizsla, start messing with the TSS system...no bueno.
    Vizsla and KnuckleHD like this.
  25. Nov 24, 2018 at 8:26 PM
    Pigglet222
    Pigglet222 New Member
    Are you saying that you couldn't use the 2019 TRD Pro grille with TRD Pro Garnish on your SR5?
    Bates5450 likes this.
  26. Nov 24, 2018 at 8:29 PM
    Pigglet222
    Can you confirm that 2019 TRD Pro grilles cannot be installed on a non-TRD Pro truck (e.g. SR5) even if you buy the radar/garnish?
  27. Nov 24, 2018 at 9:15 PM
    2ndgenny
    2ndgenny Support oil pipelines...we drive Tundras.
    Oh8 Limited DC
    Arb bumper/2” rigid led fogs. Pocket fender flares. Debadged. Smoked tailights/3rdbrake. Magnaflow catback.
    All this makes me appreciate my 08’:eek2:
    Thegr8punkin and ColoradoTJ like this.
  28. Nov 24, 2018 at 9:42 PM
    KnuckleHD
    It’s not that they cannot be installed. It’s just not recommended as it’s tampering with a safety system and obviously a major liability issue should you ever get in a accident. I am assuming it will likely affect the warranty as well.
    That being said, quite a few have done it, some have issues and others don’t. Keep in mind though that just because it’s not throwing codes doesn’t mean it’s working properly.
    One of the members here @Vizsla did a great write up on it including the purchase of a new grille, sensor, garnish, recalibration etc. He does a much better job explaining it so I’ll let you read it but after all that he stuck with the stock configuration. Hope that helps...
    Vizsla and ColoradoTJ like this.
  29. Nov 25, 2018 at 6:01 PM
    Pigglet222
    Please send or post a link to that. I cannot find his content specific to this topic.
  30. Nov 25, 2018 at 6:17 PM
    ninjajay
    Jay
    Screwston
    One thing to consider is what constitutes TSS failure. IF it's throwing error codes everywhere and disabling things, definitely that's undesirable. If it's just an occasional false positive, consider whether that's a huge deal on a supplemental system or not.
    I haven't relocated my TSS but have had things like false positives in extremely rare cases like torrential rain and steep hills/bridges. I don't consider either of those a "failure". The non-defective hardware failures in my view are way overblown. My job has a lot to do with software and sensored equipment so I get the fact that sometimes the designed "conditions" are met to set off alerts in unintended situations.
    Vizsla likes this.
