2019 TRD Pro Grill
Discussion in '3rd Gen Tundras (2014+)' started by 3mxdivr, Sep 9, 2018.
  1. Sep 9, 2018 at 4:30 PM
    3mxdivr
    3mxdivr [OP] New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    Hello there!
    New member here from NorCal. Got our Limited Crewmax last august and finally got the 2019 TRD Pro grill. Only thing missing is the garnish. I am on the waiting list for one. I couldn’t wait for the garnish and had to protect the sensor temporarily, so i bought a piece of 1/8” thick Dark Smoke Plexiglass to protect the sensor in the meantime. Not that difficult to install! Not as pretty as @ARES piece of art!
    KnuckleHD, Spitfire, ARES and 3 others like this.
  2. Sep 9, 2018 at 4:35 PM
    captain_bij
    captain_bij New Member
    Bijan
    15’ Tundra Crewmax Platinum 4x4
    Looks awesome, where did you get the plexiglass from?
  3. Sep 9, 2018 at 4:39 PM
    3mxdivr
    NorCal
    TAP Plastic here in the area. But i am assuming all plastic stores would have it. You can also go 3/16 or 1/4 thick. In fact, I think 3/16” thick would look a little better IMO.
  4. Sep 9, 2018 at 4:46 PM
    bcpnick
    bcpnick New Member
    Nick
    Utah
    2018 Tundra TRD Sport DC
    Looks great! I want!
  5. Sep 10, 2018 at 8:36 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    This looks good
    ARES likes this.
  6. Sep 10, 2018 at 8:48 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Looks great, I’m waiting for my grille to arrive so I can finally make the swap. Are you still running the stock suspension? Any TSS issues so far with the new location of the sensor?
  7. Sep 10, 2018 at 10:22 AM
    3mxdivr
    NorCal
    @ARES awesome new garnish! what are the 2 extra screws in the middle for? (does this hold the honeycomb to the lexan?) Cause the grill has only for holes 2 upper and 2 lower. BTW, you aren't thread jackn' what so ever. It gives us more options to pick from besides the OEM version.
    @KnuckleHD no issues so far and yes stock TRD Off Road suspension. I would want to go level up front but only have 2" more til i hit the garage door!
    KnuckleHD and ARES like this.
  8. Sep 10, 2018 at 10:34 AM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    Thanks brother. Yes they are for securement. The only ones that are going to be visible is the top set.
  9. Sep 12, 2018 at 10:16 AM
    MTBShane
    MTBShane Build, Build, Build
    Shane
    2016 MGM TRD DC 4x4
    Just starting on the mods right..... now
    Great idea
  10. Sep 16, 2018 at 11:10 AM
    tundrarob
    tundrarob New Member
    3mxdivr,
    Looks good! I had a garage height clearance issue on my previous truck and had to remove the tilt-up garage door and replace with a roll-up door to get a few more inches.
    Did you have any issues mounting your sensor from your 2018 into the 2019 TRD Pro grille? I wanted to do the same but did not know if the opening for the sensor on the 2019 grille was the same size.
    I was also considering the Toyota garnish or the one from Ares.
  11. Sep 16, 2018 at 7:34 PM
    Heatonrx
    Heatonrx New Member
    Anyone know why the Tacoma TRD garnish is about 50 buck?
  12. Sep 16, 2018 at 10:20 PM
    ARES
    God Bless America
    Once the 2019 shield ventures into chinaland it to will drop but may be a year or so.
  13. Sep 17, 2018 at 10:51 AM
    ARES
    God Bless America
    The opening is exactly the same. You can take the radar from the 2018 homeycomb and swap it to the 2019. But you will need plexi, lexan, some form of polycarbonate to resist impact.
  14. Sep 17, 2018 at 12:07 PM
    3mxdivr
    NorCal
    @tundrarob no issues whatsoever. Same opening and mounting holes of the sensor.
    ARES likes this.
  15. Sep 30, 2018 at 8:45 AM
    Heatonrx
    Heatonrx New Member
    3mxdivr - still running the plexiglass? Any issues yet? I ordered a grill assuming it might take a while to ship. Going to have to paint or change out the surround since I have a Limited. You'd think the Toyota garnish would come down in price since all the others I see on Ebay are around $50. Looks great.
  16. Sep 30, 2018 at 9:11 AM
    3mxdivr
    NorCal
    @Heatonrx no issues whatsoever. Sometimes i don’t even realize it is just a piece of plexi when i look at the front end. Good luck!
    Heatonrx likes this.
  17. Sep 30, 2018 at 9:50 AM
    ARES
    God Bless America
    Dont forget about @ARES garnish
