2019 Transmission Slipping
Discussion in '2.5 Gen Tundras (2014-2021)' started by Flanny2789, May 6, 2020.
  1. May 6, 2020 at 7:10 AM
    Flanny2789
    Flanny2789 [OP] New Member
    Nick
    2019 Cement Gray Crewmax
    Black badge overlays, TRD Exhaust
    Hey guys,
    My transmission has been acting funky lately. Last night when i was stopped and went to accelerate it almost felt like i was rear ended. It’s been shifting really weird too, hunting for gears. I’m wondering if it’s due to my new exhaust? It didn’t start doing it until i had it installed. I wouldn’t think I’d need a tune. Do i? Thanks for the help in advance
  2. May 6, 2020 at 7:40 AM
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    Exhaust work wouldn't be causing that. Has nothing to do with it, unless something got damaged or moved while installing the exhaust. Try resetting the ecu by unplugging the battery for about 15-20 min. Then drive it and see what happens.
    Flanny2789[OP] likes this.
  3. May 6, 2020 at 7:40 AM
    Kanobi13
    Kanobi13 New Member
    What kind of exhaust? I have cat back drop in air filter and accelerator no issues here in my 18
  4. May 6, 2020 at 8:34 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Sounds like you need fluid in your tranny...the symptoms you describe revolve a similar issue...that or your transmission needs to relearn itself since the additions of the exhaust...more power means relearning how to drive "right."
    Wynnded and Flanny2789[OP] like this.
  5. May 6, 2020 at 9:01 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    I agree with the low on fluid thing. I had a van once that did the exact same thing he's describing when the fluid was low. I'd definitely check it. Make sure you didn't damage a line or something causing a leak when you put the exhaust on.
    I can't believe that 'unlearned' transmission settings would cause what he's describing.
    snivilous and Flanny2789[OP] like this.
  6. May 6, 2020 at 9:03 AM
    Flanny2789
    Nick
    Thanks guys! It’s a TRD exhaust. I will check the tranny fluid and unplug the battery. It need serviced in a couple hundred miles too. So if it’s low i will have them fill it back up.
  7. May 6, 2020 at 9:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Unfortunately the trans fluid is really hard to check. Human error happens, my 2010 was overfilled from the factory
  8. May 6, 2020 at 10:11 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Rear-ended feeling is usually from the driveshaft slip yoke. The leaf springs let the pinion rise from driveshaft torque or drop under braking. Sometimes the slip yoke can stick a bit between the bit of idle torque and the brakes fighting against each other. Usually it'll reach an equilibrium right when you stop but if it sticks, as soon as the brakes are released the pinion pops up and it feels like someone gave your truck a love tap.
    Normal for 4wd yotas, you can't regrease the yoke without disassembly. Even if you do it usually comes back within 10k miles.
    Gear hunting would be something else. That's all controlled in the computer. Does it hunt with a steady foot?
    HulkSmurf14 likes this.
  9. May 6, 2020 at 10:50 AM
    Flanny2789
    Nick
    Only when accelerating
  10. May 6, 2020 at 10:51 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    2019? Power train warranty. Don't mess with it...take it in to dealer right away.
  11. May 6, 2020 at 10:56 AM
    Flanny2789
    Nick
    Hopefully the don’t say the infamous phrase “we couldn’t recreate the problem”
    2018Tundra likes this.
  12. May 6, 2020 at 12:01 PM
    HulkSmurf14
    2014 Tundra Limited
    Do the first things that are "free"/cheap...re-grease the drive shaft and take it in if it continues...
    Hbjeff likes this.
  13. May 6, 2020 at 12:41 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    All 3hp your exhaust gained isn't doing that. Take it in under warranty. Tranny acting weird leads downhill very fast if it's not addressed.
    HappyGilmore likes this.
  14. May 6, 2020 at 12:44 PM
    StanggoneTundra
    StanggoneTundra New Member
    2017 Tundra XP 4x4 CM
    X2 use that warranty!
  15. May 6, 2020 at 2:10 PM
    HappyTraveller
    HappyTraveller New Member
    Smalltown, Virginia
    02 Tacoma-13 4Runner-19 Crew
    Did the installer disconnect the battery during install? If so, did he/she reconnect the battery afterwards then road test driving more aggressive than normal? Disconnect the battery (fuzzy logic) for 20-30 minutes, reconnect and drove normal for approx 20 minutes.
  16. May 6, 2020 at 2:37 PM
    Flanny2789
    Nick
    I’m not sure the dealer installed it.
