5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Apr 4, 2021 at 11:59 AM
    #571
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Husky X-act, front windows tint, Xpel PPF, center console organizer and tray, TRD rear sway bar, touch screen cover, transmission cooler, wireless charger, keyless tailgate lock.
    A couple questions on the step of checking fluid level for those that already installed your kit. Getting ready to install but will be doing this myself so I want to make sure I understand the fluid level steps.
    1. When going through the sequential gears do I need to pause at each gear for a certain amount of time when cycling through?
    2. How long did it take your Pan temp to rise? I want to make sure I can get through the gears, back into park, and then back under to pull the overflow plug.
    Drainbung likes this.
  2. Apr 4, 2021 at 12:14 PM
    #572
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Here's vid that helps explain.https://youtu.be/pOrsNW2GXJs
  3. Apr 4, 2021 at 12:15 PM
    #573
    bflooks
    bflooks New Member
    Metrowest MA
    2019 Silver Sky Metallic Tundra Limited
    Nitro 5.29s Powertrax Grip Pro Bilstein 5100 middle setting CB shims (2 driver, 1 passenger) Bilstein 5160 rears Firestone Ride-Rite bags Daystar cradles Roadmaster Active Suspension (RAS) HD TRD rear sway bar 18" TRD wheels 275/70r18 Falken Wildpeak AT3W X2 Power Group 24 battery Power fold tow mirror (OEM) Genuine Cooling Systems Setrab kit Valhalla's Shields (front/rear) Dirty Deeds Bamf 12" Stainless
    For me, I had close to 5 for it to get up to the low 90s. Starting temp was around 57. Service temp took about 2-3 extra minutes and I had a many minute window to execute the leveling process.
  4. Apr 4, 2021 at 1:58 PM
    #574
    Genuine Cooling Systems [OP] New Member Vendor
    There isn't a book answer to how long you should be engaged in each gear but I recommend to keep running though each gear with a slight pause in each gear after it is fully engaged (1-2 seconds). Once pan temperatures reach 90 degrees put it back in park and prepare to open the overflow bolt at 99 degrees.
    Terndrerrr likes this.
  5. Apr 4, 2021 at 4:31 PM
    #575
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    There's plenty of time to before it comes up to 99. Granted, mine started at 47 but I spent a lot of time scratching my ass checking the phone...
    Dsptundra likes this.
  6. Apr 4, 2021 at 10:44 PM
    #576
    Toekneewin
    Toekneewin New Member
    Tony
    2020 Super White TRD Sport
    I followed a video install on youtube. He didn't go through the gears when doing the fluid level check. I didn't either. Any issues? Just installed it today...
  7. Apr 5, 2021 at 4:26 AM
    #577
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I tried to go through the gears but nothing happened. So I just went back and forth between R and D since that way I could tell that something was engaging.
  8. Apr 5, 2021 at 10:18 AM
    #578
    I wouldn't worry about it. As long as the truck was level and the transmission had time to fill the cooler and lines as you open the overflow plug at 99°-111°, you will be just fine.
  9. Apr 5, 2021 at 10:19 AM
    #579
    Hmm that's wierd, did you use sequencial or "s" then up or down to shift gears?
  10. Apr 5, 2021 at 3:51 PM
    #580
    BrakeDust
    Hill Country, TX
    Yes. But since I'm not moving, the truck doesn't need to shift at all, presumably it just stays in "1" even in "S" mode....
    After all, S mode just specifies a shift range, not an actual gear
  11. Apr 5, 2021 at 9:22 PM
    #581
    Toekneewin
    Tony
    Glad to hear. I pulled my dump trailer today and the trans didn't blow up so I think I'm good to go! Quality kit!
  12. Apr 7, 2021 at 11:51 PM
    #582
    fbingha
    fbingha New Member
    Bakersfield, CA
    No cooler installed
    65 degrees
    75 to 80 uphill
    2020 2wd SR5, not towing
    933C5714-0287-4A49-81F7-CB707ABD1404.jpg 2A69161A-31CE-4C13-937E-8764B2170A69.jpg
    Saltyhero13 likes this.
  13. Apr 8, 2021 at 4:35 AM
    #583
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Ordered my kit yesterday.
    Ryan
  14. Apr 8, 2021 at 5:08 AM
    #584
    Looks like I'm ahead of schedule on my move to Tennessee. I'm going to have everyone's kits shipped out next week.
  15. Apr 8, 2021 at 4:45 PM
    #585
    fbingha
    fbingha New Member
    Bakersfield, CA
    In a few thousand miles, I'm going to do a fluid change and send a sample to Blackstone. Let's see what 25,000 miles of driving like this has done to the fluid.
  16. Apr 10, 2021 at 5:26 PM
    #586
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Had one of Nick's original kits for about 8 months (or more) now lol. Just got around to installing. Solid :thumbsup:
  17. Apr 10, 2021 at 6:15 PM
    #587
    Solid kit. I put one on back in Dec.
    Ckatz53[QUOTED] likes this.
  18. Apr 10, 2021 at 6:18 PM
    #588
    Ckatz53
    Ckatz53 Newish
    MD
    I bought this maybe late 2019 or early 2020 can't remember. Better late than never lol.
  19. Apr 10, 2021 at 6:19 PM
    #589
    After I installed mine, I pulled a 4K lb trailer and bed full of camping gear. Avg temp was 192 :thumbsup: Where do you get commands for OBD Fusion? I saw that you have gear and Alt.
  20. Apr 10, 2021 at 6:20 PM
    #590
    Lol. I'm like a kid at Christmas when I get a package in the mail lol.
  21. Apr 10, 2021 at 6:28 PM
    #591
    Parts are starting to show up to the new place. Just waiting on the Susa package to arrive next Tuesday and I'll have all pre-orders orders mailed out on Wednesday.
  22. Apr 10, 2021 at 6:50 PM
    #592
    Damn, look at you go! :thumbsup:
  23. Apr 13, 2021 at 4:15 PM
    #593
    RicksCTTundra
    RicksCTTundra New Member
    Rick
    2019 SR5 TRD OFF ROAD
    Tonneau, Side steps, 12 volt solutions remote start
    Any one concerned about their warranty being voided? My dealer said it void the warranty.
  24. Apr 13, 2021 at 4:39 PM
    #594
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    tundra_20, Saltyhero13 and Terndrerrr like this.
  25. Apr 13, 2021 at 5:42 PM
    #595
    Dallas007
    Dallas007 New Member
    Dave
    2021 Tundra Pro Max
    I ordered a kit from Nick as I think I have a far greater chance of having future transmission issues from the high temperatures vs having to deal with a dealership on a possible warranty issue. I plan to keep my truck a very long time. I’m a big boy and willing to accept the risk and will live with the consequences. Good luck!!
    sask3m likes this.
  26. Apr 13, 2021 at 5:59 PM
    #596
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Shifting through the gears allows all the fluid to flow through all the passages and valve body and expelling any air and old fluid even when the truck doesn't move.
    tundra_20 and French Avocado like this.
  27. Apr 14, 2021 at 7:17 AM
    #597
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Good news I have the funds to hold Toyota accountable if I am ever denied warranty on my transmission because Toyota feels the cooler caused an issue. The key with any manufacturer is get past the customer service idiot.
  28. Apr 14, 2021 at 7:18 PM
    #598
    eagleguy
    eagleguy New Member
    I asked 3 local dealers and was told by all that the mod WOULD void the warranty.
  29. Apr 14, 2021 at 7:47 PM
    #599
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    It seems like dealers are all over the place on this one. Some say yes it will, others say it won't , and I think there were a few posters here that said the dealership would install the kit for them. The kit being sold here is nicely done and basically what the truck came with just a few years ago if not better. I would definitely buy one if I thought I needed it. That being said, if you really want one but are worried about warranty problems, you could easily pull it off and put it back to stock if you ever encountered any trans problems, which I personally think are pretty few and far between as transmissions go.
  30. Apr 14, 2021 at 9:30 PM
    #600
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    Will this cooler interfere if I am upgrading to a Harrop supercharger?
