5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Feb 4, 2021 at 4:57 PM
    #421
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    Makes sense, thanks.
    Ruggybuggy[QUOTED] likes this.
  2. Feb 4, 2021 at 6:01 PM
    #422
    Genuine Cooling Systems [OP] New Member Vendor
    More photo's guys. Also, all backordered MHX kits will ship tomorrow. Setrab backorders will ship mid month.
  3. Feb 5, 2021 at 12:23 PM
    #423
    rothmigo
    rothmigo New Member
    DFW TX
    2020 Tundra Crewmax Platinum
    7" BDS/Fox, 5.29, 37x13.50 Nitto, 22x12 Hostile Rage,BAM
    @chasenicholas93 for the MHX I'm assuming you don't need to pull the bumper for install, just happened to have your bumper off? I don't have the Magnussen yet or maybe ever but should I request the SC friendly bracket/spacer if it is a possible future mod? Thanks.
  4. Feb 5, 2021 at 12:40 PM
    #424
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The bumper doesn't have to come off.
    Drainbung likes this.
  5. Feb 5, 2021 at 3:51 PM
    #425
    I only removed the factory bumper because I am installing a C4 bumper. The only thing you'll need to remove is the grill to complete the install.
  6. Feb 5, 2021 at 3:53 PM
    #426
    This is with the grill on. The cooler is designed to be placed directly behind the grill opening for max airflow.
    tundra_20, Wallygator and Drainbung like this.
  7. Feb 5, 2021 at 8:47 PM
    #427
    I can send you both spacers in case you choose to go either way.
    rothmigo[QUOTED] likes this.
  8. Feb 7, 2021 at 10:29 AM
    #428
    Just did some testing in 4x4 for about 30 minutes in southern California with the MHX 514. Pan temps never reached past 185°F.
  9. Feb 7, 2021 at 4:56 PM
    #429
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    I've got temps in the 220's ATF Pan and higher torque convertor temps just driving it without towing.
    I bought the MHX kit because I don't want any problems when towing, which I will be doing.
    Doxiedad and Lake.Life24 like this.
  10. Feb 7, 2021 at 4:59 PM
    #430
    JEHTUNDRA
    Do I qualify for the discount? I bought my kit on Jan 24th. :D
  11. Feb 9, 2021 at 5:56 PM
    #431
    Dallas007
    Dallas007 New Member
    Dave
    2021 Tundra Pro Max
    It looks like the cooler is very visible through the grill from this picture. Is it very noticeable? Could you apply a light coat of black spray paint. Thanks in advance,
  12. Feb 9, 2021 at 6:35 PM
    #432
    racerex
    racerex New Member
    Will
    Westchester County, NY
    2021 Limited CM TRD Off-Road
    Eastwood sells black paint that is specifically designed for use on radiators. I can’t speak for using it on a trans cooler, but I’ve used it on a number of radiators with no issues.....both on old-school copper/brass and modern aluminum radiators. It’s thinner than standard spray paint.
    Dallas007[QUOTED] likes this.
  13. Feb 9, 2021 at 6:59 PM
    #433
    I wouldn't spray paint it. If your looking for something black that won't be as noticeable you'll have to go with the Setrab kit.
  14. Feb 10, 2021 at 6:48 PM
    #434
    Dallas007
    Dave
    2021 Tundra Pro Max
    Yes, the color is better but the info seems to indicate it’s smaller and not as effective. I
    Thanks Nick but I thought on your website (and the many pages in this forum) that the Setrab was not quite as effective? Smaller, less capacity etc? Thanks again.
  15. Feb 10, 2021 at 6:57 PM
    #435
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Maybe that's why it's a little cheaper
  16. Feb 10, 2021 at 7:14 PM
    #436
    The setrab will be just as effective as the MHX if the thermostat is not bypassed. The Setrab by no means is a small cooler that will not keep transmission temperatures under control. I don't have official comparisons of each cooler tested under the same conditions however, the Setrab will maintain 185-205° ATF temperatures just as the MHX will with the thermostat not bypassed. Hope that makes sense.
  17. Feb 10, 2021 at 7:23 PM
    #437
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    Just to be sure, since I'm getting ready to order.
    Thermostat bypassed = pin installed
    Thermostat not bypassed = pin removed
  18. Feb 10, 2021 at 7:40 PM
    #438
    Dallas007
    Dave
    2021 Tundra Pro Max
    Yes sir, it’s crystal clear and sounds like the Setrab will be the one to get. I was like many here that was extremely surprised that there is no cooler on these anymore. I was honestly going to back away from buying one until I read about you and your cooler kit. The installation video was also extremely well done. Thanks again.
  19. Feb 10, 2021 at 8:17 PM
    #439
    That is correct.
    Drainbung[QUOTED] likes this.
  20. Feb 10, 2021 at 8:26 PM
    #440
    Great, you won't be disappointed with the Susa, I'm extremely impressed with the quality of their products. The install was very well done. Although it is a different cooler, the instructions to install all the Toyota plumbing and ATF level check remain the same.
    I reformatted my website a little bit to prevent confusion. I added "Toyota Plumbing Parts" as an add on to either transmission cooler kit. You'll need to purchase the Toyota plumbing parts from the website or through the dealership of your choice to complete the install.
    10% discount is still valid through the 15th of this month. Make sure you mention the forum discount in the order notes and ill refund the difference.
    KC.Tundra and Jmn like this.
  21. Feb 11, 2021 at 4:25 AM
    #441
    BrakeDust
    Hill Country, TX
    Ok the 10% pushed me over the edge. Setrab full kit ordered! Tow 6k miles/year, planning on even more than that once I retire.
  22. Feb 11, 2021 at 10:54 AM
    #442
    JEHTUNDRA
    Chase,
    Got my kit today. It was well packaged. Thanks.
  23. Feb 12, 2021 at 3:41 PM
    #443
    Jmn
    Jmn New Member
    Monitored temp for the past 400+ miles.
    Never went above 210 with 20 average exterior temp.
    Load was minimal (700lbs max with passenger).
    I do believe that with an external temp around 60-70 I will quickly go above the 220.
    Can you confirm an order on Monday (the 15th) will still benefit the 10%?
    Thanks!
  24. Feb 12, 2021 at 5:05 PM
    #444
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Does the 10% apply to the Toyota plumbing as well?
  25. Feb 12, 2021 at 5:56 PM
    #445
    It sure does.
  26. Feb 12, 2021 at 6:12 PM
    #446
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Thx!
  27. Feb 12, 2021 at 7:05 PM
    #447
    I am currently sold out of the Toyota plumbing parts. I have more on order however, it may be a couple weeks before I can ship kits that include the plumbing with the order.
  28. Feb 14, 2021 at 10:42 AM
    #448
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
  29. Feb 15, 2021 at 8:55 PM
    #449
    Toekneewin
    Toekneewin New Member
    Tony
    2020 Super White TRD Sport
  30. Feb 16, 2021 at 9:03 PM
    #450
    Jmn likes this.
