5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Nov 23, 2020 at 7:41 PM
    #211
    Saab95v6
    Saab95v6 New Member
    Thanks Patrick, Awesome video.
    2020Platinum likes this.
  2. Nov 23, 2020 at 8:19 PM
    #212
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    Thank you!!
  3. Nov 24, 2020 at 4:45 AM
    #213
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Great job Patrick, as always ! :thumbsup:
  4. Nov 24, 2020 at 5:16 AM
    #214
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Great video! My is already installed but definitely enjoyed watching. I had a mechanic do it because I didnt feel comfortable but after watching your video I definitely could have saved myself $200.
    But again thanks for the upload and you definitely have a new subscriber
  5. Nov 24, 2020 at 6:52 AM
    #215
    2020Platinum
    Patrick
    Northeast PA
    Thank you sir!!
    thanks Shawn, I appreciate the support!!
  6. Nov 24, 2020 at 2:10 PM
    #216
    AlexJet
    AlexJet New Member
    2021 TRD Offroad CrewMax
    Put on my watch list. Need to install it
  7. Nov 25, 2020 at 5:24 AM
    #217
    SShooterZ
    SShooterZ New Member
    Great video, thank you.
    My kit finally arrived yesterday. Perfectly packaged and with everything needed for the job. A really well done kit.
  8. Nov 25, 2020 at 11:54 AM
    #218
    2020Platinum
    Patrick
    Northeast PA
    Thank you!...Yepper, Nick puts together great kits for sure, let me know if ya need any help with the install!
  9. Nov 26, 2020 at 5:20 AM
    #219
    Airsavage
    Airsavage New Member
    Butch
    2020 MGM 4X4 4 Dr
    Great Kit Nick and thanks to Patrick for the video. Noticed alot of dirt where the hard lines get pushed thru. I took the caps off of the T-stat and put them on the hard lines before working them thru. Not sure if any crud would have gotten into the lines just being cautious.
  10. Nov 26, 2020 at 5:28 AM
    #220
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I did the same thing, even though my truck was still new. Better safe than sorry!
  11. Nov 26, 2020 at 11:18 AM
    #221
    2020Platinum
    Patrick
    Northeast PA
    Thanks Butch!...and that’s a great idea, wish I thought of it before making the video!...lol
  12. Nov 27, 2020 at 9:36 AM
    #222
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Damn it! Was gonna buy the partial kit with the black Friday deal. Got distracted and they’re gone!!
  13. Nov 27, 2020 at 6:21 PM
    #223
    Paulismydog
    Paulismydog New Member
    2020 Black Limited Double Cab
    I am planning of doing a transmission pan drain and fill at same time as oil changes. Is it OK to mix in the amsoil fluid in with the Toyota fluid? Thanks.
  14. Nov 27, 2020 at 7:06 PM
    #224
    Genuine Cooling Systems [OP] New Member Vendor
    I have been running AMSOIL in my transmission for 6 months with no issues.
  15. Nov 27, 2020 at 7:07 PM
    #225
    Paulismydog
    Thanks. But is mixing the two safe? I won't be doing a full flush.
  16. Nov 27, 2020 at 7:34 PM
    #226
    Yes, AMSOIL blue label meets specifications for WS. No issue mixing. I'd say I still have 20% Toyota WS still in my transmission.
  17. Nov 27, 2020 at 7:35 PM
    #227
    Paulismydog
    Thank you.
  18. Nov 28, 2020 at 9:46 PM
    #228
    Seven partial kits are back in stock and can ship next Thursday or Friday.
  19. Nov 29, 2020 at 7:56 AM
    #229
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    installed kit on thursday morning (yup thanksgiving day). tis' the season. took me about 3.5-4 hours, however, i took my sweet ass time, and spit shined anything and everything adjacent to where i was working.
    during test drive, with thermostat pinned, i could not get pan temps above 178*
    during subsequent drives, with thermostat NOT pinned, i could not get pan temps above 188.4*
    it is also very nice to see the pan and converter temps going DOWN while sitting at a red light!
    i do have a question, more of an observation really...
    prior to the cooler, i was seeing my engine coolant temps hanging out around 220-222, while my engine oil temps were around 210.
    AFTER the cooler, i am seeing my engine coolant temps around 200, with my engine oil temps around 195.
    i believe, that since the puck is no longer HEATING UP my coolant trying to dissipate transmission heat, that i am seeing an added benefit of the cooler. And, since my engine block is cooler, so is my engine oil.
    CAN ANYONE ELSE CONFIRM LOWER ENGINE COOLANT AND OIL TEMPS?
    kudos nick for a great kit!
    kudos patrick for a great install vid!
    planning to keep the tundra 250k+ miles. cooler tranny temps, cooler engine coolant / oil temps, and regular drain / fills of each fluid will help me get there.
  20. Nov 29, 2020 at 8:02 AM
    #230
    That is a good observation about coolant temperatures. It would make sense to me that coolant temperatures would decrease if the radiator could not keep up with the excess heat from the transmission. Unfortunately, I did not have data prior to a cooler install on my truck.
  21. Nov 29, 2020 at 11:01 AM
    #231
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    I have a 2017 but can confirm my coolant temp runs about 10 degrees cooler (from 195 to 185) when I have the trans thermostat pinned open.
  22. Nov 29, 2020 at 11:02 AM
    #232
    First World Problems
    First World Problems New Member
    2021 Tundra TDR Pro - Lunar Rock
    Any word on the upgraded cooler pricing and availability?
  23. Nov 29, 2020 at 1:31 PM
    #233
    JWB
    JWB New Member
    2020 Tundra Limited TRD Off Rd
    TRD Exaust, Scanguage II, Tundra inserts for Tundra under radio, Husky X-Act w/Red Tundra inderts,TRD oil cap and Grey/Tundra center console insert
    Rusty, how are you monitoring oil temps? After install my coolant stays around 195-200...prior to cooler was 200-205.
    My pan now stays between 185-190 and convertor rapidly cools back down as well.
  24. Nov 30, 2020 at 6:45 PM
    #234
    shackleford rusty
    TEXAS!
    using the veepeak odbcheck ble+ in combination with the odb fusion app on an iphone. i did buy the toyota 2019 enhanced diagnostics add-on under purchase extras.
    in the engine and electronic controlled transmission category, choose the engine oil temperature pid.
    may not be available in the basic app.
    JWB[QUOTED] and 2020Platinum like this.
  25. Nov 30, 2020 at 7:42 PM
    #235
    The MHX 514 kits will be available third week of December and very limited quantity. I will be installing the MHX 514 on my own truck prior to putting them on the market. Price will be $619. Photos and install instructions will be posted as soon as the install is complete.
    KC.Tundra likes this.
  26. Dec 1, 2020 at 12:37 AM
    #236
    KC.Tundra
    KC.Tundra New Member
    Kevin.
    Kamloops, BC
    2019 SuperWhite Platinum Tundra CrewMax SB
    20’ KMC Grenade OR. TRD Skid Plate. TRD Rear SwayBar. Toyota Door Sill Protectors. Toyota Hardflip Tonneau cover.
    Is it just going to be a limited quantity release for the month of December? Or will there be more available after the initial release?
  27. Dec 1, 2020 at 3:39 AM
    #237
    I will have more MHX 514 brackets on order once the design is test fitted. It may be mid Jan before I receive another order of brackets.
    KC.Tundra[QUOTED] likes this.
  28. Dec 1, 2020 at 7:50 AM
    #238
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
  29. Dec 1, 2020 at 8:29 AM
    #239
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Did you pull a sample by chance to send to Blackstone?
    Wallygator and Saltyhero13 like this.
  30. Dec 1, 2020 at 8:30 AM
    #240
    14burrito
    2014 SR5 CM 4x4 5.7
    Did you pull an ATF sample to send to Blackstone?
    Saltyhero13 likes this.
