5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Dec 10, 2021 at 3:04 PM
    #1231
    Genuine Cooling Systems [OP] New Member Vendor
    Hmm that is interesting. Not sure why they said they would need that as the hoses don’t rub on each other or the frame if you cut the hose to the correct length.
  2. Dec 10, 2021 at 3:10 PM
    #1232
    Kentuckytundra
    Kentuckytundra I love spam calls, we talk for hours
    I'll snap a pic tomorrow of the hoses, seems they were left a little long.
    Nothing crazy though. I think they were trying to make it as close to the way the stock 18s were.
  3. Dec 10, 2021 at 3:11 PM
    #1233
    It will be an easy fix to cut them to the proper length. Please let me know if you have any questions.
  4. Dec 10, 2021 at 3:13 PM
    #1234
    Kentuckytundra
    Will do. Thank you, I'll take a few pics and you can tell me if I should cut them or leave them be or use that little routing/hose holder thingy.
  5. Dec 10, 2021 at 5:09 PM
    #1235
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Went to homedepot and got 6 rubber clamps and separated the hoses , they were not rubbing but did it just in case and it cost me like 5$
  6. Dec 10, 2021 at 5:30 PM
    #1236
    Kentuckytundra
    Excellent idea! Thank you.
    Jtundra81[QUOTED] likes this.
  7. Dec 10, 2021 at 6:01 PM
    #1237
    Undercover
    Undercover New Member
    Maryland
    2021 Tundra TRD Pro CM MGM
    I'm trying to figure out what area this is??
  8. Dec 10, 2021 at 6:08 PM
    #1238
    Jtundra81
    Joe
    This is at the back of the wind deflector where the rubber hoses connect to the hard lines at the bottom
  9. Dec 10, 2021 at 6:13 PM
    #1239
    Undercover
    Maryland
    Got it. Thank you!
  10. Dec 10, 2021 at 6:14 PM
    #1240
    Just so everyone is aware and not going out buying hose separators. If you remove the excess slack from the hose properly there is no reason to worry about the hose rubbing on anything to include the other hose to cause premature wear.
    There will be a install video coming soon which will detail this process and the rest of the install.
    camron1039 likes this.
  11. Dec 11, 2021 at 11:44 AM
    #1241
    Undercover
    Maryland
    470FF20D-6EE0-4138-8076-33ED74C1A907.jpg 713C9D3D-6434-4F3F-91B9-E98AD1803EB2.jpgMy lower hose slightly touches the fender metal and brake fluid hose. Should I be concerned? Really don’t want to take it back apart just to cut about 1/2 inch off.
  12. Dec 11, 2021 at 11:50 AM
    #1242
    It shouldn’t be an issue however, if you do decide to cut some slack on the hose I’d recommend pinning the thermostat open to allow the cooler to drain back to the pan. This will allow you to remove the fittings, slip off the hose, trim and reinstall without losing ATF.
    tundra_20 and EDDO like this.
  13. Dec 11, 2021 at 12:00 PM
    #1243
    Undercover
    Maryland
    Thank you. I was wondering if a bunch of fluid would come out of the line. I think I’ll just monitor the hoses for wear at this point and make adjustments if necessary.
  14. Dec 11, 2021 at 12:23 PM
    #1244
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD Praux
  15. Dec 11, 2021 at 12:46 PM
    #1245
    Undercover
    Maryland
    I thought about something like that also. I’d rather not take the clamp and hose off to put the sleeve on. The hose will be stretched out where it was on the nipple and I feel it wouldn’t have as tight of a fit/seal as it initially did. I wonder if there is something that would slip around the line without having to take anything apart.
  16. Dec 11, 2021 at 2:04 PM
    #1246
    Undercover
    Maryland
  17. Dec 12, 2021 at 2:56 PM
    #1247
    Another happy customer with a 2019-2021 Tundra MHX-514 (Discontinued)
    ryanwgregg and Dsptundra like this.
  18. Dec 12, 2021 at 3:23 PM
    #1248
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Installed my Hayden cooler Saturday on my 21 CM , took off my 19 before sell ,
    32 oz fluid put in, went through procedure running it until hitting 103deg on scangauge
    Checked fluid level got 33 oz back out , cooler pinned , double checked today same ,
    Anyone here that’s installed there’s ran into this on there 21 overfilled ,
  19. Dec 12, 2021 at 3:26 PM
    #1249
    Was the truck level when conducting the procedure? If so, it’s not unheard of Toyota overfilling transmissions.
  20. Dec 12, 2021 at 3:40 PM
    #1250
    Bradleybb
    Georgia
    2021 CM TRD OR
    Leveled yes , yea if I Hadn’t been installing cooler wonder if I would have
    Experienced any transmission issues at some point in time,
  21. Dec 12, 2021 at 7:32 PM
    #1251
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Summer of 2020 bought Nicks kit for my 4 month old truck, checked the fluid level before starting the install. I was surprised when I pulled the level check plug a full stream came out, not even close to a trickel.
  22. Dec 13, 2021 at 5:15 PM
    #1252
    ColoradoCub
    ColoradoCub New Member
    Have any of you noticed the transmission shifting erratically when cold after installing the cooler. Mine will do some weird stufff when cold, rpms jumping up and down and some multiple shifts until the temp gets up over about 140. It’s done this to about every other morning when the truck is cold. Once it’s warm it shifts perfectly and does what it is supposed to as far as cooling. Just got back from a 700 + mile road trip and it did it both mornings when cold.I’ve checked the fluid twice and it was a little overfilled the first time but it looked perfect the 2nd time, still does it though.
  23. Dec 13, 2021 at 5:44 PM
    #1253
    Jtundra81
    Joe
    Haven’t noticed any difference, I always warm up the truck though before I drive , only thing I can think off is your oil level but you already Double checked it
  24. Dec 13, 2021 at 6:09 PM
    #1254
    I believe Toyota has a different shift logic based upon the transmission temperature. That is why I recommend removing the pin from the thermostat so the transmission get to operating temperature as quick as possible as designed.
    68rs75z28 likes this.
  25. Dec 13, 2021 at 6:15 PM
    #1255
    ColoradoCub
    The pin is removed on mine, I’m letting the thermostat work as designed. I’m just not understanding why I didn’t experience this prior to installing the cooler, I was certain it had to be fluid level related but who knows.
  26. Dec 13, 2021 at 6:18 PM
    #1256
    Besides the ATF level, the colder weather is the only other factor I can think of.
  27. Dec 13, 2021 at 6:23 PM
    #1257
    steved0xTD
    steved0xTD New Member
    2020 Tundra SR5 4x4 TRD Off-road
    Here is a preview of the installation instructions for the Genuine Cooling Systems transmission cooler for 2019-2021 Toyota Tundra with the Setrab Series-9 15-row cooler. When Nick posts the official version I'll edit this post and point to his version. I had already bought this kit a while back but hadn't got to installing it, and it was a pleasure to work with Nick both as a customer buying the kit, and working with him to make this install video. Thank you Nick.
    Pig Rig likes this.
  28. Dec 13, 2021 at 6:25 PM
    #1258
    Thanks Steve!
    Pig Rig and steved0xTD[QUOTED] like this.
  29. Dec 13, 2021 at 8:18 PM
    #1259
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Is there a reason this was discontinued? Any issues? I just bought this kit and haven't installed yet, if there is a design flaw or something I don't want to install it.
  30. Dec 13, 2021 at 8:48 PM
    #1260
    Improved Racing is is redesigning the MHX-514 and increasing the price of the cooler by $50. Although the MHX-514 is a larger cooler, the Setrab Series 9, 15-Row cooler will maintain pan temperatures within operating range. Due to these reasons I decided to only offer the Setrab kit to keep it affordable.
    ryanwgregg and Green Thunder like this.
