5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Oct 18, 2021 at 11:28 PM
    #1081
    Allrsdup
    Allrsdup New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
    Installed mine today. (Setrab) Biggest pain in ass is the hoses connection to the hard lines. PXL_20211018_210344870.jpg
    SSPey, 1794TX, EatSleepTacos and 4 others like this.
  2. Oct 19, 2021 at 12:20 PM
    #1082
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Went on the maiden voyage today towing my setup. Trans cooler did its job really well. Did some surface street driving as a test, meaning constant acceleration to 40 and also sitting at red lights. Hottest I saw was TC temp of 215 and it quickly dropped back down to the pan temp of 190 once I started moving. I can definitely live with that. Trailer and tacoma weigh a combined 8,000 lbs.
    Mike59, WAtundra4x4, Saab95v6 and 5 others like this.
  3. Oct 19, 2021 at 12:25 PM
    #1083
    1794TX
    Steven
    N.TX
    '20 1794
    Dressed in a new tuxedo, carrying a threadbare briefcase. Great stuff.
    EatSleepTacos[QUOTED] likes this.
  4. Oct 19, 2021 at 12:27 PM
    #1084
    1794TX
    Steven
    N.TX
    '20 1794
    Should edit 'bulletproof' threadbare briefcase.
    EDDO likes this.
  5. Oct 24, 2021 at 5:41 AM
    #1085
    Wheresmytranscooler
    Wheresmytranscooler New Member
    Brad
    2019 Tundra SR5 TRD
    I found the temp check procedure for 2014+ using a jumper between 4-13 on the OBDll connector. Can anyone verify whether this procedure will work on a 2019 to place the trans. into temp check mode?
  6. Oct 24, 2021 at 9:20 PM
    #1086
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    Got the Setrab installation done today. Fantastic kit. Hardest part was battling the lack of space in my garage. I did have to "shim" a few tires with 1/2" boards to get it level. It wasn't dead nuts, but it was just within the line. Hopefully that doesn't make a huge difference.
    Also went "out of order" in steps. One could save some time by assembling the heat exchanger and bracket before hand.
    Watch out for the heat deflectors around the cats. They're sharp buggers.
  7. Oct 25, 2021 at 8:10 AM
    #1087
    Allrsdup
    Allrsdup New Member
    Joe
  8. Oct 25, 2021 at 8:37 AM
    #1088
    Dallas007
    Dallas007 New Member
    Dave
    2021 Tundra Pro Max
    Excellent video and information!! Thanks
    Allrsdup[QUOTED] likes this.
  9. Oct 25, 2021 at 11:14 AM
    #1089
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Thank you
  10. Oct 26, 2021 at 3:55 AM
    #1090
    EatSleepTacos
    Randy
    West Valley, AZ
    Last testament post and then I’ll stop spamming the thread, but I had to report back after a proper trip.
    800 miles round trip and PLENTY of hills once I got into PA, some were pretty steep and long. The highest temp I saw at any given point was a torque converter spike of 222 but as soon as I crested the hill, it swiftly dropped down to pan temp of ~195. I can’t even begin to imagine how hot my trans would have gotten without it.
    If anyone tows anything and has a 19-21, I would say this kit is a necessity, not an option.
  11. Oct 26, 2021 at 2:47 PM
    #1091
    Chip_Tundra
    Chip_Tundra New Member
    Even if you don't tow, it's a must have.
  12. Oct 26, 2021 at 6:21 PM
    #1092
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Just ordered my kit , can someone please provide some insight on the below
    1) when installing the thermostat , is it only the O rings from the spacer that needs to be replaced or also the ones on the puck
    2) when level check the fluid , you need to shift to all gears and reverse based on the install guide , do you need to do it once or keep doing it till it reaches 99?
    3) I have read couple of comments where the bottom bolt on the puck won’t thread and they had to replace it with the horn bolt , is it something common or expected with each install ?
    4) anyone tried running the hard lines without removing the skid plate or removing it is a must ?
  13. Oct 26, 2021 at 6:27 PM
    #1093
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 DC Attitude Black
    The new T-stat brings new o-rings.
    PDF for oil check on here https://www.tundras.com/threads/gen-3-transmission-fluid-level-check-temperature-range.18359/
    Havent read or ran into that issue, yet.
    Its a must. Have to get to bolts and lines.
    Jtundra81[QUOTED] likes this.
  14. Oct 26, 2021 at 6:42 PM
    #1094
    Jtundra81
    Joe
  15. Oct 26, 2021 at 6:48 PM
    #1095
    EatSleepTacos
    Randy
    West Valley, AZ
    I ran through gears until it reached temp, including hopping into S and bouncing through the gears. Dunno if necessary but that’s what I did.
    The horn bolt wasn’t for the puck. The horn bolt was up front, for the cooler itself. I had to use it on the lower most bolt for the bracket where the bracket bolts onto the truck.
  16. Oct 27, 2021 at 3:29 AM
    #1096
    batman900
    batman900 Yep
    24-RAM 2500, 05-Tundra, 11-Accord
    I have the RCI skid plate and did not need to remove it, I don't know if that will be different with the OEM. Removing the RCI skid plate wouldn't have made anything any easier.
  17. Oct 27, 2021 at 7:50 AM
    #1097
    Wheresmytranscooler
    Brad
    2019 Tundra SR5 TRD
    Does the OBDFusion app with Toyota enhanced diagnostics allow the user to reset the transmission thermal degradation estimate?
  18. Oct 27, 2021 at 8:01 AM
    #1098
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    I haven’t found an OBD app that allows for that. I’ve got myself a very basic Asus laptop with deleted WiFi card that runs Techstream.
    http://blog.obdii365.com/
    You will probably need a 2.0.4 firmware cable that supports newer ECUs and live data.
  19. Oct 27, 2021 at 8:07 AM
    #1099
    Asimov2025
    Asimov2025 Not Sure
    North Texas
    Non-stop mods
    Possible Supercharger in the future is why I went with the Setrab.
  20. Oct 27, 2021 at 9:39 AM
    #1100
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I just ordered the Setrab.
    On the day I install, I cannot guarantee that the universe will not run out of cuss words.
    sd172, Jtundra81 and Saltyhero13 like this.
  21. Oct 27, 2021 at 9:40 AM
    #1101
    :rofl: That was me while trying to install my S8 in the hood bulge.
  22. Oct 27, 2021 at 9:43 AM
    #1102
    Jtundra81
    Joe
    Got mine too yesterday , I think I will hook up the cooler and hard lines first and keep the thermostat / refill as last steps , let us know how it goes . Will be doing mine in the next couple weeks
    nobodyintexas[QUOTED] likes this.
  23. Oct 27, 2021 at 9:45 AM
    #1103
    Allrsdup
    Allrsdup New Member
    Joe
    I ran the hard lines without removing my TRD pro skid plate Is it a little bit tricky Yes but it can be done.
    I shifted the transmission through all the gears a couple of times and then waited for attempts to reach 99° before checking fluid.
    No issues with the bolts they line up right up it's an OEM part shouldn't be any problem.
    When you remove the spacer the o-rings will be stuck to the side of the transmission take them off the thermostat replaces the spacer and has its own o-rings
  24. Oct 27, 2021 at 9:46 AM
    #1104
    Jtundra81
    Joe
    Thank you
  25. Oct 27, 2021 at 9:48 AM
    #1105
    nobodyintexas
    nobodyintexas What?
    South of Houston
    if Lazy-Boy made a creeper that lifted you off the ground....I wouldn't even ask the price.
    Pig Rig, Saltyhero13 and Bammer like this.
  26. Oct 27, 2021 at 10:35 AM
    #1106
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    1) the orings from the spacer stuck to the mounting surface of the transmission when I removed the spacer. If this happens just ensure you remove them as the thermostat has its own orings. The puck reuses it’s orings.
    2) I had my wife continue to cycle through the gears til the pan temp reached 99f, maybe about 2 or 3 times.
    3) I did not have an issue with any of the bolts.
    4) I removed my RCI skid before install. Didn’t even look to see if it could be accomplished without removal. If anything it adds a little more clearance to roll around on the creeper.
  27. Oct 27, 2021 at 2:42 PM
    #1107
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    To my understanding the thermostat switch opens at 195f. I assumed it would be triggered by the pan temp however it seems to be opening when the TC hits 195+. I only have a few country drives since installing the aux cooler but I haven’t been able to get the pan temp above 185f since install. Does anyone know the relation between the pan temp and TC temp in reference to triggering the thermostat? Just curious is all.
    Saab95v6 likes this.
  28. Oct 27, 2021 at 3:08 PM
    #1108
    EatSleepTacos
    Randy
    West Valley, AZ
    I was wondering that too, just out of curiosity.
  29. Oct 27, 2021 at 8:16 PM
    #1109
    Allrsdup
    Allrsdup New Member
    Joe
    It's not a full open or full closed situation It will partially open similar to a thermostat in your cooling system.
    batman900 likes this.
  30. Oct 30, 2021 at 11:03 AM
    #1110
    Wheresmytranscooler
    Brad
    2019 Tundra SR5 TRD
    I was told by my local dealer that the 2019 trans temp check mode was the same procedure as earlier models. I was not able to get it to work. The issue I had with using an IR thermometer on the pan is that I was seeing about 20+ degrees difference depending on where I was measuring temp.
