5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Sep 12, 2021 at 7:25 PM
    #961
    Chip_Tundra
    Chip_Tundra New Member
  2. Sep 13, 2021 at 7:18 AM
    #962
    blanchard7684
    blanchard7684 New Member
    My thermal degradation index hasn't moved but one value since cooler install. This is about 140 miles in 95 degree weather. Without cooler it would have gone up about 8-9 values.
    diablodalton and sd172 like this.
  3. Sep 13, 2021 at 7:29 AM
    #963
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    I will check my TechStream today. It’s been over 3500 miles since I’ve got mine installed.
  4. Sep 13, 2021 at 8:27 AM
    #964
    timsp8
    NY
    Your numbers are really good. I wouldn’t worry about 2-3 degrees. Like someone else said, you still have coolant running through the puck that’s warmer than 185. Pre 19s stay around 195.
  5. Sep 13, 2021 at 9:03 AM
    #965
    Oerterg
    Oerterg New Member
    2020 MGM sr5 sport crewmax 4x4
    I have a 7k camper im going to be towing. (Staying within the state of fl (for now) so im leaning towards the mhx cooler but i like the stealthy of setrab. I saw some paint the mhx with black radiator paint. Would that effect the performance of it?
  6. Sep 13, 2021 at 9:59 AM
    #966
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Well yeah i was never really "worried" about the 2-3 degress I was moreso just curious since it was able to maintain the 185 for over a week. I love the cooler though and i'm really glad I decided to put it on. I just wish the ATF level check wasn't such a pain in the ass. I added the valhalla cat theft plates on afterwards too. With those plates on, you can still do the TC and diffs, just gonna need to pull them off when i do a drain and fill on tranny.
  7. Sep 13, 2021 at 10:59 AM
    #967
    Chip_Tundra
    What values should we aim for? My truck has 20K miles and I've only done a drain and fill.
    And do you reset that value after every drain and fill?
    Been looking to get techstream solely for this.
  8. Sep 13, 2021 at 11:08 AM
    #968
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    I have a few ideas but would love to hear how people are ensuring their trucks are level if they don't have a level concrete slab to work on.
    mech_engineer09 likes this.
  9. Sep 13, 2021 at 11:23 AM
    #969
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    I have a gravel driveway that isn’t level at all. I crawled underneath and used a big level on the frame rails and crossmember. Used a couple jacks to slip 2x6 ends under the tires until level. It worked pretty good and took a lot less time than expected.
    TunsofFon[QUOTED] likes this.
  10. Sep 13, 2021 at 11:31 AM
    #970
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Jacks and jack stands, scrap wood under the tires, expensive RV leveling blocks. Lots of options.
  11. Sep 13, 2021 at 11:39 AM
    #971
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    The MHX is a work of art though.
    FlightMedicRN and Chip_Tundra like this.
  12. Sep 13, 2021 at 12:01 PM
    #972
    Kung
    KG, VA
    I've got what is likely a supremely stupid question. I keep reading about pinning the thermostat. I understand what it means, but my question is this - when does it need to be done, and is it a manual thing (e.g., requires rolling around underneat the truck)?
  13. Sep 13, 2021 at 12:11 PM
    #973
    Wyoming
    The pin is part of the thermostat that gets installed with the cooler kit. It only needs to be pinned when doing your fluid checks, I think? For regular operation it should be unpinned.
    There's a lot of people that think pinning it will make it run cooler, and therefore be better for hot climates, but it really is designed to operate without being pinned. By pinning it you keep the flow to the cooler open all the time and it will take longer for the ATF to reach proper operating temps. This might affect efficiency until it gets up to temp, but isn't likely to have a negative impact either. There's no actual benefit to pinning it for daily operations.
  14. Sep 13, 2021 at 12:14 PM
    #974
    Wyoming
    From the video in the first post, this link should pick up where he points out the pin.
    https://youtu.be/5DLkja6vXvc?t=786
    Pig Rig and Kung[QUOTED] like this.
  15. Sep 13, 2021 at 12:17 PM
    #975
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    The thermostat comes with a pin inserted to keep the thermostat open. This is so after installation, you can circulate transmission fluid through the new lines and cooler to ensure there are no leaks. Once you ensure there and no leaks (and check the fluid level if you think necessary) you pull the pin out so that the thermostat operates as designed.
  16. Sep 13, 2021 at 12:24 PM
    #976
    timsp8
    NY
    Pinning keeps the “poppet valve” open all the time.
  17. Sep 13, 2021 at 2:24 PM
    #977
    Oerterg
    Oerterg New Member
    Well just placed the order for the mhx cooler
  18. Sep 13, 2021 at 4:16 PM
    #978
    Chip_Tundra
    Pulled the pin out today, and I can confirm that the transmission does in fact run significantly cooler overall when the thermostat is pinned. I've been able to test this in consistent 100+ degree weather.
  19. Sep 13, 2021 at 4:26 PM
    #979
    Kung
    KG, VA
    Well, I live in Missouri, which is not exactly what I'd call a hot climate; but still, it can't hurt.
  20. Sep 13, 2021 at 4:28 PM
    #980
    Kung
    KG, VA
    That raises a different question - do I need to (or should I) keep it pinned when it gets colder outside?
  21. Sep 13, 2021 at 4:33 PM
    #981
    Chip_Tundra
    I personally feel like you can't go wrong either way. These trucks have a fluid warmer that will get the eventually get the transmission close to the water temperature. I believe Toyota considers WS "warm" around 100 to 130 deg. It definitely won't take long to get that temperature driving these trucks, even in the winter.
  22. Sep 13, 2021 at 5:29 PM
    #982
    timsp8
    NY
    You don’t need to pin at all. Let it run as designed.
  23. Sep 13, 2021 at 5:31 PM
    #983
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Husky X-act, front windows tint, Xpel PPF, center console organizer and tray, TRD rear sway bar, touch screen cover, transmission cooler, wireless charger, keyless tailgate lock.
    Agreed. If it’s hot it will open soon, if it’s cold it will open when reaching the proper temp. Engine thermostats aren’t pinned for the same reason.
    TXBrit, GODZILLA and timsp8[QUOTED] like this.
  24. Sep 14, 2021 at 5:59 AM
    #984
    blanchard7684
    Not sure. I think the fluid is technically spent at a reading of 50,000 or something in that range.
    Curious how to reset that myself.
  25. Sep 14, 2021 at 6:14 AM
    #985
    Kung
    KG, VA
    Nice. Now I know what I'll be spending my money on next. :D
  26. Sep 14, 2021 at 6:53 AM
    #986
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    I painted mine with eastwood radiator matte black. looks amazing. can't even see it behind the grille. i can snap some pics for you later.
    rothmigo, cowboyjack and GODZILLA like this.
  27. Sep 14, 2021 at 6:55 AM
    #987
    Wyoming
    Definitely want to see those. The only draw for the setrab is the color. When you put up pics would you mind detailing the paint process? Prep, number of coats, dry time, etc.?
  28. Sep 14, 2021 at 7:37 AM
    #988
    Oerterg
    Oerterg New Member
    That would be awesome and the process u did to paint. I wonder if it effects cooling.
  29. Sep 14, 2021 at 8:23 AM
    #989
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    it's a thinner paint, used specifically for radiators and i spoke with someone from eastwood and they said it will not affect the cooling at all. my temps have been steady at 185F once the cooler kicks in on my 30 minute drive to work, where they would normally be at like 225 by that time. I took a 2 hour drive to my parents house pushing it hard on the highway and it stayed steady at 187-188.
    As far as the process I bought these from Amazon.
    https://www.amazon.com/gp/product/B00MBPT0F8?ie=UTF8
    scuffed up everything but the fins and the spec plate on the cooler, wiped it down a few times with acetone, got some painters tape and cut it into a circle to cover the inlet and outlet and did like 2 layers of that just to be on the safe side with some overlapping on the edges. it really turned out great. Just be patient. i laid it on one side and sprayed it, waited an hour and turned it over and sprayed the other side. 2 light coats. just make sure you don't apply too much to the fins, while still getting them covered as that is what affects the cooling capability of the heat exchanger.
  30. Sep 14, 2021 at 9:32 AM
    #990
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    Here’s some pics don’t mind the dirty truck it’s getting washed this weekend you can’t even see it if you aren’t right up against the grille which is exactly what I wanted.
    Pig Rig likes this.
