2019 Toyota Tundra Platinum center of gravity
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rlachermeier, Dec 19, 2020.
  1. Dec 19, 2020 at 10:06 AM
    Rlachermeier
    Rlachermeier [OP] New Member
    Randy
    2019 Toyota Tundra Crewmax Platinum Edition
    I have a 2019 Toyota Tundra Platinum edition crew cab. I will be installing a lift in my shop and was wondering what the center of gravity was for the tundra. I'm planning on installing the lift 15' away from the front wall and was wondering where that will put the grill (front end) of the truck. I would like to put a tool box between the front wall and the truck but don't know if i will have enough room.
    Thanks in advance!
  2. Dec 19, 2020 at 11:26 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    OK, I'm trying very hard to decipher what you are asking us. After careful re-reading of your query, it sounds like you are asking two different questions:
    1) you are installing a "lift" (ie. the type found at a repair shop which lifts the vehicle in the air so that you can access the underside and for some uknown reason, you wish to know the Tunedra's center of gravity. I'm not sure how the Tundra's center of gravity would be relevant to what you are wishing to do.
    2) your soon-to-be-installed shop vehicle lift will be 15 feet away from the "front wall" (I am assuming that you mean the back wall of your garage, opposite the garage door, right?) and you want to know about the length of your Tundra and how much room you will have between said Tundra and the back wall as you wish to place a tool box in between? Am I correct? The answer is, that would be IMPOSSIBLE to tell you because you gave us almost no relevant data. So, the "lift" will be 15' away from the "front wall"; 15' from the wall to the closest tip of the of the lift? 15' from the center of the lift? And then, how big is the lift relative to the size of the Tundra??? How could we possibly be able to answer your questions? They make almost no sense!?!?
    Tundyfundy and Saltyhero13 like this.
  3. Dec 19, 2020 at 11:31 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    You nailed it.
    The truck is 228.9″ OP
    https://www.cjponyparts.com/media/i...cles/body/center-of-gravity-infographic-2.jpg
    https://www.bendpak.com/support/products/training/balancing-safety/
    https://www.bendpak.com/blog/two-post-safety/
  4. Dec 19, 2020 at 12:46 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Lift at the factory recommended lift points in the owners manual, support the rear diff with a high reach jack stand for additional safety
  5. Dec 19, 2020 at 12:57 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Damn internet is killing the English language.
    ItsNickROFL and Tundra2 like this.
