2019 Pro Grill...
Discussion in '2.5 Gen Tundras (2014-2021)' started by James99, Feb 16, 2018.
  1. Feb 16, 2018 at 10:26 PM
    James99
    James99 [OP] New Member
    2018 Tundra Offroad
    Just starting
    I spoke with the parts department at my local Toyota and he said that the 2019 Pro grill will ONLY fit the Pro models, Toyota made it different.
  2. Feb 17, 2018 at 12:48 AM
    epa4wd
    epa4wd New Member
    Ed
    Don’t really trust parts departments. I’ll believe it when I see it.
  3. Feb 17, 2018 at 4:05 AM
    tmart
    tmart New Member
    Travis
    Shouldn’t be too hard to get it on there
  4. Feb 17, 2018 at 5:49 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    I don’t see why it wouldn’t fit since the body has not changed, I think it has been discussed here before, and never trust parts dept, 99.99% of the time they’re clueless.
  5. Feb 17, 2018 at 5:57 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Did they say when it would be available?
  6. Feb 17, 2018 at 7:38 AM
    [DELETED]
    [DELETED] New Member
    Jeff
    Hmmm... agree that they don't typically know more than the collective knowledge of the forum.
    I sure hope they're wrong. Was looking forward to this upgrade.
  7. Feb 17, 2018 at 8:09 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    My experience with most parts departments is that if the part you are after doesn't come up associated to your VIN their answer is it doesn't fit. In a way they are correct sometimes because they don't take into consideration that we as gearheads don't mind to make minor modifications to make things work.
    831Tun likes this.
  8. Feb 17, 2018 at 8:16 AM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    Why would they do that? That would mean less grills sold, less $$$$ made. Doesn't make sense.
  9. Feb 17, 2018 at 8:22 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    It makes sense form their point of view. If they order parts for you that almost implies that they will fit your truck. If they order something for the average Joe (not mechanically inclined) and it doesn't it they have to refund it and are out of the shipping charge and then just have a part lying around which in many cases nobody ever wants.
  10. Feb 19, 2018 at 7:35 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Do I fit into the 0.01% that do know what they're talking about? :D
    I HIGHLY doubt it will only fit the TRD Pro. I don't think Toyota is going to change mounting points on one truck. They didn't with the last Pro, and they're probably not going to with this one. I would answer with a hard "No", but I never go 100% on anything unless I have tested something myself or have seen it done.
    Dimmer23, Huckwheat and 831Tun like this.
  11. Feb 19, 2018 at 7:39 AM
    Dmas
    Dmas New Member
    FTL, FL
    you ARE that 0.01% :headbang:
    Roman[QUOTED] likes this.
  12. Feb 19, 2018 at 8:41 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yeah Roman, you're in the .01%.
  13. Feb 19, 2018 at 8:42 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    And that's why @Roman knows what he's talking about......
    Roman likes this.
  14. Mar 22, 2018 at 9:51 PM
    wes77
    wes77 New Member
    Where there’s a will there’s a way...
    Someone will be able to make it fit
  15. Mar 30, 2018 at 9:34 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    once you open the box and break the seal, you can't return it :evil:
    I agree it should fit, or you can make it fit, the hoods and headlights are interchangeable. So the grille must be.
