2019 Platinum Tundra Fuse Diagram
Discussion in '2.5 Gen Tundras (2014-2021)' started by GasGuzzler, Aug 30, 2019.
  1. Aug 30, 2019 at 9:15 PM
    GasGuzzler
    GasGuzzler [OP] New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    Wondering if someone with a 2019 Tundra can take a pic of the cabin fuse diagram and post it for me? I see plenty of 2018 & older but unfortunately they are very different. I have a power outlet (armrest) that is out & all of my fuses check out. Wondering if it is possible that I have one missing.
  2. Aug 30, 2019 at 9:31 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The diagram should be on the cover of the fuse box, both the interior and under hood. How do you know the 2018 and 2019 are different?
  3. Aug 30, 2019 at 9:36 PM
    GasGuzzler
    2019 Tundra
    If I had the cover I wouldn’t be asking. I know because I own a 2019 & my fuses look nothing like the 2018 diagram. Not even similar.
  4. Aug 30, 2019 at 10:56 PM
    GasGuzzler
    2019 Tundra
    IMG_1225.jpg IMG_1226.jpg Here is a pic of mine. If you compare it to the previous models you will clearly see no similarities other then the fact that they both use fuses.
  5. Aug 30, 2019 at 11:12 PM
    GasGuzzler
    2019 Tundra
    That I don't know but soon to find out. :thumbsup:
  6. Aug 31, 2019 at 5:58 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Boy, that sure looks an awful lot like the panel on my 2018.... But maybe it's just the fuses and stuff. :thumbsup:
    Did you throw yours away when you installed the add-a-fuses?
  7. Sep 2, 2019 at 10:31 AM
    GasGuzzler
    2019 Tundra
    Thanks a bunch guys. That’s the one I needed.
    I put In the door when I added The front camera (add a fuse) & I believe the car wash might have thrown it out.
  8. Sep 2, 2019 at 10:40 AM
    GasGuzzler
    2019 Tundra
    Sure enough, I was Missing that 15A Power Outlet #2. Thanks again.
    Migraine likes this.
  9. Nov 17, 2019 at 6:11 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Is there just the one size fuse, MINI for the 2019 Tundra?
    I'm going to order an assortment of 5-30a and have seen some posts about Mini and some Low Profile Mini.
  10. Nov 18, 2019 at 9:19 AM
    GasGuzzler
    2019 Tundra
    Just one size used for both fuse boxes.
  11. Mar 14, 2020 at 3:50 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    @GasGuzzler , I see that you have two different fuses (different amps) installed into the add-a-circuit. I'm being told that they need to match. The instructions in the add-a-circuit itself says don't use higher than 10 amp. I'm being told I need to use a 15 amp minimum (I'm trying to get power fold mirrors to work).
    Have you guys had any issues with using higher than 10 amp in add-a-circuit/add-a-fuse, or using fuses with different amps?
    Also, are any of the blank spaces in the fuse bank constant hot? I was not able to find any that are (which would prevent me from having to use an add-a-circuit.
  12. Aug 14, 2021 at 1:29 PM
    augatundra
    augatundra New Member
    2021 Toyota Tundra Limited 4X2 Double Cab
    There are like 10 fuses for ECU. To reset ECU all 1 has to be pulled out and back in?
  13. Aug 14, 2021 at 1:35 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    What’s your end goal here? If you’re just wanting to do a soft reset on the ECU to relearn driving style, air/fuel mix, etc, just disconnect the neg battery terminal for 15 mins. I don’t think I’d run the truck with an ECU fuse pulled since you could end up damaging the truck if the wrong module is down.
  14. Aug 14, 2021 at 1:39 PM
    augatundra
    Yes ECU reset to relearn. I wouldn’t run the truck with fuses pulled out. I was looking for another way to do this since I already pulled battery cables for an hour and not even radio stations are reset.
  15. Aug 14, 2021 at 1:41 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Radio stations have nothing to do with the ECU. I’m not sure where you’d go about resetting the stereo, but there should be an option for that in the head unit menus itself.
  16. Aug 14, 2021 at 1:44 PM
    augatundra
    I don’t have a scanner so how do I tell if the reset was successful?
  17. Aug 18, 2021 at 7:21 AM
    augatundra
    ECU reset was completed but the slight knocking engine noises still present (my distance to empty numbers went up to like 700+ miles so this is how I knew the reset was done. normally I was getting 470 miles or so at full tank before the reset). I was able to test drive with a Toyota master technician this morning and he stated that it was a slight spark knock and no cause for concerns that all Tundra's have this noise to some degree including his own truck. there wasn't any other Tundra in the dealer lot for me to test drive. At least I am glad a Toyota tech agrees that he hears what I have been hearing and complaining and it is now formally documented. I don't agree that spark knocking (even slight) is no cause for concern for longevity of the engine so will be contemplating my next move. Perhaps let this dealer buy my truck if they will make me whole on what I paid back in March.(Since nothing is wrong per their master tech)..........
  18. Oct 24, 2021 at 3:35 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Know if anyone sells an extended cover for the tundra interior fuse block? I see them for tacos and 4runners...are they the same?
  19. Nov 21, 2021 at 10:18 AM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Well, at no additional cost to the company, I found a vendor who makes an extended cover for the interior fuse block. He's from Etsy - HldMyBeerEngineering, Ohio. This dude knocked it out of the park - he didn't have a Tundra cover, went out, bought one, and hit me up. Part fits perfectly with the add-a-fuse tap in the block.
    I have pictures, so it happened!
  20. Dec 1, 2021 at 11:19 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    Where is the second fuse box located?
  21. Dec 1, 2021 at 11:22 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The other is the huge box next to the battery under the hood.
  22. Dec 1, 2021 at 11:23 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    I know where that one is, I’m looking for the smaller secondary one.
  23. Dec 1, 2021 at 11:25 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That one is up behind the parking brake
  24. Dec 1, 2021 at 11:26 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    Ok great thanks..
  25. Dec 1, 2021 at 11:39 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    Well I found it but it does not have the fuse for the cigarette/USB charger in the center consul.
  26. Dec 1, 2021 at 11:50 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That should be running off of the 15amp fuse at P/OUTLET N.O2
    RobertD likes this.
  27. Dec 1, 2021 at 11:53 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    I see that one , man this site is the best!!!
  28. Dec 1, 2021 at 11:56 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :fistbump:
    TS1794 likes this.
  29. Jul 22, 2025 at 2:46 PM
    Sr5Sebas
    Sr5Sebas New Member
    Sebastian
    2019 toyota tundra sr5 4 door
    So when i wrecked my truck all of my steering wheel buttons stopped working i cant do anything off my steering wheel i cant even turn up my volume or change my music thru my steering wheel
  30. Jul 22, 2025 at 3:04 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Does your horn work? I'm guessing your clock spring that runs signal to your horn and steering wheel controls needs to be replaced.
