2019 Non JBL
Discussion in 'Audio & Video' started by Army_of_One, Mar 25, 2020.
  1. Mar 25, 2020 at 2:27 PM
    Army_of_One
    Army_of_One [OP] New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I started my new job as a stripper today. :D My boy and I removed all the way up to the stereo. It will be a slow process, but I hope to have it done by the weekend. I'm going to go with most of *********' setup, but I'm hoping to do the dash speakers differently.
    Inquiringone and jeremyd like this.
  2. Mar 25, 2020 at 5:29 PM
    Army_of_One
    OEM+
    Not worth it! If AJT Designs did a smooth cover, I wouldn't have done any of this.
    Black@Blue19 likes this.
  3. Mar 26, 2020 at 9:50 AM
    Army_of_One
    OEM+
    Noico on the rear, and EZQ harness ran.
  4. Mar 26, 2020 at 6:10 PM
    Army_of_One
    OEM+
    Made some tweeter blanks and a center blank. Ran the wiring from speaker mounts to center console. I'm going to use a different brand for the center tweeters, and I hope it's not over powering.
  5. Mar 27, 2020 at 9:11 AM
    Kung
    KG, VA
    Two (potentially dumb) questions for you:
    1. I assume you're replacing the factory speaker amp (under the passenger seat)?
    2. If so - are you mounting the amp like the factory amp was mounted, or does it just sit on the ground somewhere?
    Army_of_One[OP] likes this.
  6. Mar 27, 2020 at 9:40 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    That's some next-level anal retentiveness there brother! Love it! Yeah...that's the full monte right there. I ehhh...got 'er done. Nice work!
  7. Mar 27, 2020 at 1:43 PM
    Army_of_One
    OEM+
    I'm just putting my 5 channel under the driver seat. I might look into making a board for the passenger side though. Not there quit yet.
  8. Mar 27, 2020 at 1:58 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    If your driver's seat goes up and down that's a bad idea. My guess is the factory amp is under the passenger side because none of the passenger side seats move up and down.
  9. Mar 29, 2020 at 2:59 PM
    Army_of_One
    OEM+
    I got back into it today. More noico in the front doors and the wall behind the rear window. Finished running wire to the rear doors. Installed front mids. Next I hope to tackle the front highs.
  10. Mar 29, 2020 at 3:05 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    With those front door mid-woofers...can that adapter be flipped around so the speaker sits more rearward? I'm not sure with that adapter in particular but make sure it lines the speaker up with the hole in the door panel. The one I used initially had ⅓ of the speaker covered by the door panel because the hole is off-center but should be off-center towards the rear off the door and not the front of the door.
  11. Mar 29, 2020 at 3:49 PM
    Army_of_One
    OEM+
    The adapters won't flip around and recess on either side. I did recheck after you mentioned it though. :oops:
  12. Mar 30, 2020 at 8:08 PM
    Army_of_One
    OEM+
    Didn't get much done today. The vents are back in the middle though. Can anyone help me with bolt placement on the passenger side please? :(
  13. Mar 31, 2020 at 4:21 PM
    Army_of_One
    OEM+
    There was an attempt? Toyota dropped the ball on this one.
  14. Apr 2, 2020 at 5:50 AM
    Army_of_One
    OEM+
    Did some fine tuning yesterday. The door speakers were too deep, so I had to add a 1/4" trim ring. There was also a noticeable gap between the door and the speaker adapter. Got all 4 doors done with the exception of the rear tweeters. That's going to be an interesting setup.
  15. Apr 2, 2020 at 3:28 PM
    Army_of_One
    OEM+
    Getting ready for lockdown! Between errands and being teacher dad, I had time to put the dash back together, run power for the amp, run power for the rock light switch, and put the tweeters in the dash. Still need to figure out a center channel mount and mounting the amp and EZQ.
    MTRock likes this.
  16. Apr 6, 2020 at 6:40 AM
    Army_of_One
    OEM+
    Got quite a bit done over the weekend. I hooked up and tested the EZQ and amp, got x-overs installed, all speakers except the center channel, wired my light switch in, and put most of the truck back together. The mids and highs are ridiculously loud. I tested one speaker at a time and a front component alone was louder than the stock stereo. I got to the subs, and one is blown. :( I'm currently fighting the box to get it far enough back to put the rear seat in. Other than that I'm happy with how it turned out. I did have to modify a couple of things on the rear door though. The tweeters from the rear components were just small enough to fit into the factory location. The back was flush with the back of the mount, so I glued them into place. The speaker cutout for the door had a lip that would seal the factory foam, but it wouldn't allow my panel to seat. It was easy enough to trim out with an xacto knife.
    Platinum714 likes this.
  17. Apr 6, 2020 at 10:02 AM
    Army_of_One
    OEM+
    Got the rear done! I got to chat with someone on the "place that shall not be named" site and they said to tighten the rear bolts first. It worked and I'm happy to have it complete. I still haven't put the sill plates or kick panels on the front yet. I'm doing a bed light and pop a lock this week, so I don't want to pop them out a ton of times.
  18. Apr 6, 2020 at 5:52 PM
    Army_of_One
    OEM+
    Knocked out the center channel earlier. I ran two Boston Pro Series 1 inch tweeters(8 ohm per) as my center. I tried them in series(16 ohm) and could only hear them with my head in the dash. I redid them parallel(4 ohm) and now I have center stage again. These were ran to an independent crossover then to left/right bridged on the front of the amp.
  19. Apr 6, 2020 at 5:57 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    I originally made my own but it was to thin so i purchased the amp rack from *********. It uses the same factory mounting spots.
    You could prolly make a nice unit using the factory rack arms.
  20. Apr 8, 2020 at 5:07 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Nice second use for the cutting board. Lol. Guess wifey is happy not to find it.
    Wouldn't it be more balanced if you did the install the other way? Just saying.
  21. Apr 10, 2020 at 2:56 PM
    Army_of_One
    OEM+
    What do you mean by install the other way?
    I got into it today to tweak the center and install the bass knob. The ohm load on the Boston's was making it difficult to find a happy median for the sound stage. Both run in series was too low, but both run in parallel was too loud. I left i parallel, but put the crossover on "ambient." It sounds a lot more even now. I didn't like the location or method that TT suggests, so I place it differently and used double sided tape and a couple of zip ties. It's out of the way and I only have to worry about spilling water on it. :oops:
  22. Apr 10, 2020 at 3:19 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Good write up.
  23. May 4, 2020 at 3:45 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    WOW!! What a job!!! Good On Ya!!! I am driving over to TT here in Texas in a few!! Way to go!!!:)
  24. May 4, 2020 at 3:57 PM
    Army_of_One
    OEM+
    Which system are you going with?
  25. May 4, 2020 at 4:05 PM
    Black@Blue19
    Ken
    SE Texas
    To much to list:)
  26. May 4, 2020 at 4:35 PM
    TXTundra2722
    2015 Black Tundra
    Was this package purchased from taco tunes? Curious what you spent on the whole kit
  27. May 4, 2020 at 5:00 PM
    Army_of_One
    OEM+
    I got the Sub box, subs and EZQ from a guy locally($450). The components($410), baffle kit($36), Amp wiring kit($65), RCAs($20) and noico($60) were from Amazon. I got the speaker wire from the local car audio store($140 for two trucks worth). I did purchase the heavy duty speaker adapters from TT($100).
    TXTundra2722[QUOTED] likes this.
