2019 Key wont come out of ignition
Discussion in '2.5 Gen Tundras (2014-2021)' started by luckitundra, Jan 10, 2022.
  1. Jan 10, 2022 at 12:55 AM
    luckitundra
    luckitundra [OP] New Member
    Please help
    I just got home from work but my key wont come out off the ignition. I have tried to wiggle the key, shift my gear back and forth, pull and truck out and reverse back in my spot, all nothing. I have another key but unable to lock it, Im worried if i leave it in all night my truck might die tomorrow before I head out to work.
  2. Jan 10, 2022 at 1:42 AM
    evilcartman187
    evilcartman187 New Member
    Travis
    2020 Cement Tundra TRD OR DC
    AJT Designs shifter, console vault, Toyo Open Country M/T P275/65R18
    If wiggling the shifter while trying to remove your key doesn't work, check out this video. It's an older Tundra, but might still apply to yours. Good luck. https://youtu.be/0EcgsigaQZU
    blanchard7684 likes this.
  3. Jan 10, 2022 at 5:40 AM
    blanchard7684
    blanchard7684 New Member
    try moving steering wheel back and fourth.
    ljburns and Tundra2 like this.
  4. Jan 10, 2022 at 11:28 AM
    luckitundra
    Hello!
    Thank you so much! There was a small mental ring from a key chain that I put my key through accidentally while I put my key in the igniton. That might have caused some magnet malfunction, after Ive cut out that key chain ring I was able to remove my key!
    Thank you so much everyone!
