2019 JBL Stereo Upgrade Decisions
Discussion in 'Audio & Video' started by Tsack10, Sep 28, 2019.
  1. Sep 28, 2019 at 12:33 PM
    Tsack10
    Tsack10 [OP] New Member
    2019 Toyota Tundra Platinum
    3/1 Low Range Off-road 35x12.5x20
    Hey All, I am currently trying to upgrade my terrible JBL system... I just received the Rockford Fosgate DSR1 and need help on choosing the remaining components.Keeping the stock head unit. My main hurdle is figuring out what amp to go with. At a minimum I want to do a 10” JL Sub but am considering 2 10’s or possibly a 12” I do not want overwhelming bass but a good all around sound with some punch. I at a later point plan on changing out door speakers and tweets but not on the list right now. I just want them to have some more power for now. I’m not looking to splurge on a stereo so I have to keep it fairly simple and on the cheaper side of things. Any recommendations would be appreciated.
  2. Sep 28, 2019 at 1:08 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You are on the right track! Dsr1 is a great option for those with jbl that want to keep the factory head unit.
    Start looking at 5channel amps. Something 75x4 +500x1.
    As far as door speakers, you really depends on your budget. I have jl c5-650 up front and they are amazing, but pricey.
    I would send James at tech12volt (he's a vendor here) and let him know what you are trying to accomplish. He has great prices and even better customer service.
    tech12volt@gmail.com
  3. Sep 28, 2019 at 5:07 PM
    Fire123
    Fire123 New Member
    2015 White 1794 Edition
    7" BDS w/ Fox, Fuel Wheels
    Per the advice of so many, I am currently working w James on building up my system as well. He seemed very well versed on the best way to attack this common issue.
    Give him a holler.
  4. Sep 28, 2019 at 6:18 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I emailed James also. Same issue with the stock unit
  5. Sep 28, 2019 at 7:15 PM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    I did 4 Kicker amps under the back seat, 2,800 watts total. A pair of Kicker 10’s behind the seat, Kicker components in the doors, Kicker 3.5” in the dash and new speaker wire ran individually to each speaker (even the tweeters). I also did the Rockford processor. It rocks even if I say so myself.
    YotaMan, Maxi13 and phogallen like this.
  6. Nov 11, 2019 at 7:27 PM
    FLMallCrawlr
    FLMallCrawlr New Member
    2019 Tundra limited
    20x9 pro comp wheels Custom built exhaust w/magnaflo S&b intake 6112 front Fox back Rigid ditch lights Infinity speakers with kenwood amp 2 10” mtx subs
    How much did all that run you if you dont mind me asking?
  7. Nov 12, 2019 at 8:59 AM
    FLMallCrawlr
    2019 Tundra limited
    Thanks man thats not as bad as I thought
  8. Nov 12, 2019 at 10:05 AM
    Danimal86
    Daniel
    Sacramento, CA
    Dang. Baller!
    I always wondered how you get signal for more than 2 amps if they don't have a pass thru.
    Shark Bait[QUOTED] likes this.
  9. Nov 12, 2019 at 10:55 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    I just recently upgraded my system, keeping the head unit and door speakers.
    with a Kenwood X801-5, 5 channel amp and a AudioControl LC7i line out converter
    and a rockford fosgate 12 inch sub. Even with the factory speakers this things sounds
    amazing. Prolly will upgrade the speakers at some point.
  10. Nov 14, 2019 at 11:15 AM
    FLMallCrawlr
    2019 Tundra limited
    So did you also use the dsr1? Sorry for the questions just trying to do something similar.
  11. Nov 14, 2019 at 2:43 PM
    purplenova
    Tom
    Ohio
    I did not. I used the Audiocontrol lc7i. Does the same as DSR1 basically from what I've read.
  12. Nov 14, 2019 at 2:53 PM
    purplenova
    Tom
    Ohio
    Don't you have the JBL system in your Limited?
  13. Nov 14, 2019 at 5:29 PM
    FLMallCrawlr
    2019 Tundra limited
    Yes just trying to figure out what to buy for the audio shop to install
  14. Nov 15, 2019 at 5:07 AM
    purplenova
    Tom
    Ohio
    FLMallCrawlr[QUOTED] likes this.
