2019 Entune Plus Question
Discussion in 'Audio & Video' started by ncorry, Mar 29, 2019.
  1. Mar 29, 2019 at 7:53 AM
    ncorry
    ncorry [OP] New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I've got a 2019 SR5 CM. WIndow sticker says "Etntune Audio Plus 7" Touch Screen"
    While driving with the windows up, I have to have the volume set to 35 /60 (I think) to hear talk radio.
    It's been a very long time since I screwed around with auto audio. I don't even know if my rig has an amp or if it is the JBL system. I listen to music some, but don't need or want a sub.
    My questions:
    What system do I have?
    Would my $ be best spent on speakers or something else?
  2. Mar 29, 2019 at 8:03 AM
    Does it say JBL on doors, over the speakers? Does it say it on the headunit? @james@tech12volts can take good care of you either way.
  3. Mar 29, 2019 at 8:19 AM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    I agree with @T-Rex266 . James did a great job with my setup and it was a prepackaged deal.
    If your just trying to clear up the audio to hear it better and it's going to be talk radio, maybe just an amp to power the stock speakers would be a quick and relatively cheap option.
  4. Mar 29, 2019 at 8:53 AM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    2019 SR5 CM, JBL not an option. Check your settings on the equalizer, set the bias towards the front and driver's side (worth a shot).
  5. Mar 29, 2019 at 8:55 AM
    ncorry
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Thanks to all..... Now i have to go re-read the 700 page manual in an attempt to find the equalizer..... I've set the bias toward the front and it helps, a bit.
  6. Mar 29, 2019 at 9:23 AM
    Both JBL and non-JBL sound like garbage. Do yourself a favor, and contact @james@tech12volts
    His customer service is beyond top notch, and is available pretty much 24/7 for assistance / guidance with install or whatever else is needed.
