2019 DRL Question?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spectre, Jul 3, 2019.
  1. Jul 3, 2019 at 8:44 AM
    Spectre
    Spectre [OP] New Member
    Huntsville, AL
    2022 Tundra TRD Sport 4x4
    I’m replacing my incandescent turn signals with LEDs. The 2019 Tundras with LED headlights don’t have the amber colored DRL. Does anyone know if I can activate the new LEDs to run as DRLs in addition to the white LEDs that are already on? I’ve searched and can’t seem to find anyone wanting to do this. Mostly just the opposite. Any suggestions or pointing me to the right thread would be much appreciated.
  2. Jul 3, 2019 at 8:47 AM
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    I dont think you can that on the LED headlight models.
  3. Jul 3, 2019 at 8:59 AM
    Spectre
    Huntsville, AL
    I’m beginning to think it’s more trouble than it’s worth. I miss the amber DRLs but also like the white LEDs. Guess you can’t have everything, and I’m not an electrical engineer to figure it out LoL
  4. Jul 3, 2019 at 9:11 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No. They are only wired to be used as a blinker.
  5. Jul 3, 2019 at 9:13 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    @xrunnerdude67 I wonder if something like this might be your forte given your talent with the Sequoia LED harness upgrade.....
  6. Jul 3, 2019 at 10:13 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    It is possible. I have retro fitted LED headlights with a prewired harness with the option of having LED and Turn signal DRL's on. My guess would be to wire them up to an IGN source with a fuse tap. Make sure you get LED bulbs that are meant for DRL and not just turn signals.
    GAknight, CaptSpaulding and Pudge like this.
  7. Jul 3, 2019 at 10:42 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    @iHacker may be able to help. It could be as simple as a pin swap or jumper wire but I'm not sure
  8. Jul 3, 2019 at 11:03 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I like the Amber DRL. In fact, I haven't added the new LED headlights to my 2017 specifically bc I don't want the LED strip DRL. To me, the amber DRL makes the Tundra stand out more from the sea of white LED DRLs on every other car on the road.
  9. Jul 3, 2019 at 11:22 AM
    jtav2002
    jtav2002 Retired Adult Film Sound Man
    Josh
    Reading, PA
    2019 GMC Sierra 1500 AT4 6.2
    I know nothing about this specific brand or how it operates on the Tundra so I’m not recommending this as much as just giving an example. I’ve seen people swap out the led boards on other vehicles and replace them with ones that allow you to change the DRL colors. You should be able to run the DRLs as amber instead of white with something similar. You’d have to take your headlights apart though. Note this looks like it’s for the older halogen headlights with bottom LED drl as opposed to the new all LED lights on the new trucks. But something similar may exist.
    https://www.ledconceptslighting.com/14-17-toyota-tundra-profile-pixel-drl-boards.html
  10. Jul 3, 2019 at 11:24 AM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    I love your truck Dan, I find myself drooling over any picture you post, ahaha. Ok, fanboy moment done.
    GiantsFanDan[QUOTED] and Pinay like this.
  11. Jul 3, 2019 at 12:01 PM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yes it is possible you need a jumper wire from Violet wire in side maker to the empty spot in turn signal plug.
    Or a more complex T adapters to have the Amber Bright and Dimmed DRL but soldering and 4 diodes are required
    Not sure if it’s worth all the trouble to get this
  12. Jul 3, 2019 at 12:22 PM
    Pudge
    CT
    I knew the master would have the answer :thumbsup:
    iHacker[QUOTED] likes this.
  13. Jul 3, 2019 at 12:40 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Interesting...
    Would there possibly be a way to reverse this? As in ... take the OEM LED drl lights and turn them into turn signals, instead of the amber bulb nobody can see anyways
    Spectre[OP], Migraine and Pudge like this.
  14. Jul 3, 2019 at 6:17 PM
    GiantsFanDan
    Thanks :thumbsup:
  15. Jul 3, 2019 at 7:32 PM
    Spectre
    Huntsville, AL
    Thanks everyone for your help. I may try the jumper wire like iHacker recommended when I get the time. I also like the idea of making the white LEDs flash like a turn signal.
    GiantsFanDan likes this.
  16. Jul 3, 2019 at 9:43 PM
    iHacker
    iHacker SW TRD PRO
    Spectre[QUOTED][OP] likes this.
