2019 Cement Crewmax SR5, Need Help
Discussion in 'New Member Introductions' started by jackhole68, Mar 8, 2019.
  1. Mar 8, 2019 at 8:21 AM
    jackhole68
    jackhole68 [OP] New Member
    Patrick
    2019 Cement SR5 Blackout 2WD
    111.jpg I am going to be getting the TRD Grille/Lights/Rigid Fogs, front and back caps.
    Wanting to level, best option. Do not want it much higher just level, recommendations?
    Looking for a good tonneau, recommendations?
    What else guys???
    OR18TRD, Markman, drhntr and 6 others like this.
  2. Mar 8, 2019 at 8:22 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
    I think folks get the Bilstein's 6100's and set it at the top level. Folks that have done this will chime in soon.
    jackhole68[OP] likes this.
  3. Mar 8, 2019 at 8:29 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  4. Mar 8, 2019 at 8:33 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Welcome from SoCal.
    Tonneau, Bakflip is good. Had one on my '14 and loved it.
    As for leveling, the Bilstein suggestion is good. @Toytec Lifts can help with ideas and prices. IMO, avoid spacer lift/leveling kit unless you plan to have a pavement princess.
    Congrats on a great looking truck!
  5. Mar 8, 2019 at 8:38 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
  6. Mar 8, 2019 at 8:55 AM
  7. Mar 8, 2019 at 8:58 AM
    jackhole68
    Patrick
    Budget isn't a concern. I will have the truck for 12-15 years. I don't want to raise it just level.
  8. Mar 8, 2019 at 8:59 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Welcome to the party! We have a ton of different options to fit the needs of every style driver and budget!
    Whats your end goal for the truck?
  9. Mar 8, 2019 at 9:15 AM
    Welcome from Texas
  10. Mar 8, 2019 at 9:47 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    I’ll be that guy. You need to go back and read the rules. Learn to use the search button. Then understand every person is going to tell you something different. All of your topics have been discussed tons of times on here. You will find pages and pages of what you are looking for
    Wutachampion and jackhole68[OP] like this.
  11. Mar 8, 2019 at 10:00 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Hello and welcome from slc!
  12. Mar 8, 2019 at 10:19 AM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Welcome from SoCal!
  13. Mar 8, 2019 at 12:49 PM
    Welcome from Ohio.
  14. Mar 8, 2019 at 1:46 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Welcome from San Diego. I’ll 2nd what was mentioned above. Start with what you plan to do with your truck and then work backwards. There are plenty of options out there that will level the truck but range from the cheap end like Bilsteins 5100s up to OEM Kings. Both will accomplish the same look but will serve completely different purposes. If you plan to keep the truck for a long time, I’d start your search with Bilstein 6112s and/or any of the Toytec offerings and then work up from there depending on how much beating on the truck you plan on doing.
    Once you figure it out, be sure to let me know... I still haven’t decided myself.
  15. Mar 8, 2019 at 1:47 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Welcome from NE Ohio. I have the extang hard trifold (and l love it). Cement/White are pretty much tied for second best color IMO. Great looking truck sir.
    As far as a level goes, there's plenty of good info on this forum that I've seen already while browsing/dreaming. Best of luck.
  16. Mar 8, 2019 at 1:49 PM
    KnuckleHD
    Oh yea and I have the Toyota cover. I like it a lot. I also got a discount on it when I bought the truck otherwise I probably would have went the Backflip route.
  17. Mar 8, 2019 at 2:41 PM
    cpc0812
    cpc0812 New Member
    Cory
    2018 Cement 4 X 4 CM
    Welcome from NC. I have Bilstein 6112s on my truck. I have mine set at 1.3 inch lift. Most on here will go to 1.9 inch setting which should get you almost level or 2.5 inch setting which will get you level or maybe even nose high. Depends on the truck. They are all different. 6112s ride good to me and they are not too terribly expensive. They fit the bill for what I needed. Put some 5100s on the rear and you are still less than $1000 with a good ride.
  18. Mar 8, 2019 at 2:47 PM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Welcome. If you plan on keeping the truck that long, I would not advice the spacer. Bilstein is really a great way to go and will level things out nicely. Agree with the Toytec lifts advice as well.
  19. Mar 8, 2019 at 2:51 PM
    Markman
    Markman New Member
    Mark
    Utah
    2019 limited cement cm
    Tint airbags daystar cradles Elka suspension bushwacker flares
    If budget isn't a concern I love my Elkas can level the front easy and the ride is so much better then stock. Toytec can definitely hook u up!
    jackhole68[OP] and KnuckleHD like this.
  20. Mar 8, 2019 at 2:56 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from South Carolina
  21. Mar 8, 2019 at 3:20 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  22. Mar 8, 2019 at 3:36 PM
    KnuckleHD
    Definitely interested to hear more about the Elka’s. They look great on paper but are so new for Tundras that there isn’t a lot of feedback out there. Have any pictures of your set-up?
  23. Mar 8, 2019 at 4:02 PM
    Markman
    Markman New Member
    Mark
    Utah
    B0BD93F8-8A9D-468C-BA9E-F260A9CEFADB.jpg 1DA36DAE-F684-4A55-A070-AB358EFCD156.jpg I don’t have to many pics but can take more if you like. I have the front and rear set up 1” blocks on the rear.
  24. Mar 8, 2019 at 4:35 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Welcome! I like the diamondback hd tonneau.
  25. Mar 8, 2019 at 5:30 PM
    maxcala
    maxcala New Member
    Max
    L.A.
    2014 Limited Crewmax
    You're in the right place.
  26. Mar 10, 2019 at 11:53 AM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
