2018 tundra with a ranch hand
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rider0120, Oct 8, 2018.
  1. Oct 8, 2018 at 3:57 PM
    Rider0120
    Rider0120 [OP] New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    so here is goes. About a year ago I started planing buying my truck and started pricing out all the things I wanted to do for my new truck. One of those things was a ranch hand full replacement with grill guard.
    It killed me hearing that Toyota was putting their safety sense on their whole lineup and later finding out that ranch hand had no intentions of making a compatable bumper for my truck ( even tho it says 14-18 on their website).
    I bought the truck in late April and researched up and down about this radar that was in the emblem, nothing on any forum, website or FB page. Then ARB came out with a Aussie style Bull Bar for the 2018 and I found one guy on a tundras FB page that bit the bullet and on a grill guard put cut out the center mesh. He said that he wasn’t having any problems with the active cruise control. I had a glimmer of hope then I found what I was looking for. The actual beam pattern that leaves the emblem. It talks about a 2016 Camry but it was the best info I came across here’s the link
    http://www.repairerdrivennews.com/2...replacing-a-radiator-support-is-more-complex/
    So with a couple of questions to 15yota with his install I pulled the trigger. So enough with the chat, here’s the porn
    4ABE7B74-DBBF-4DEA-B8F3-43E77ACDF8AB.jpg 4ABE7B74-DBBF-4DEA-B8F3-43E77ACDF8AB.jpg
  2. Oct 8, 2018 at 4:00 PM
    Rider0120
    Bucks County, Pa
    Pulled the tow hooks off while the paint dried and theyre was rust between the frame and tow hook
    bhuff92 and jewsNbrews like this.
  3. Oct 8, 2018 at 4:02 PM
    Rider0120
    Bucks County, Pa
  4. Oct 8, 2018 at 4:04 PM
    Rider0120
    Bucks County, Pa
  5. Oct 8, 2018 at 4:06 PM
    Rider0120
    Bucks County, Pa
  6. Oct 8, 2018 at 4:11 PM
    Rider0120
    Bucks County, Pa
    She only has a couple of miles under her belt, and she followed the car in front of me so tomorrow will be the real test because I’ve used the ACC everyday I’m on 95.
    Also I’m going to let the paint cure for a couple of days and I’m going to put automotive door edged trim around the mesh to clean it up and not have any sharp edges to bite me later.
  7. Oct 8, 2018 at 4:16 PM
    OkcthunderGuy
    OkcthunderGuy New Member
    Dustin
    OKC
    14 Tundra TSS
    the fun is just beginning
    Looks really good. If you had a way to cleanly remove those edges all the way to the bar, it should be too much work to sand them smooth and touch up that gloss black. But either way I like it. My tundra doesn’t have one, but I’ve got a very similar setup on my Ram Duallie and it looks badass
  8. Oct 8, 2018 at 4:52 PM
    Rider0120
    Bucks County, Pa
    Thank you. I wanted to in the worst way. But since the 2 center bars are angled ( and not exactly centered) I couldn’t get the diamonds to be even all the way down the sides. And ranch hand welded the mesh in a couple of spots too on the center bars so oh well. I think it will look ok once I get the edge trim on. This bumper is mainly for deer protection since I come home a lot at night and drive threw the pine barrens to get to my boat.
    zcarpenter92 and OkcthunderGuy like this.
  9. Oct 23, 2018 at 6:37 PM
    Lake.Life24
    Lake.Life24 Dogs > People
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Looks great! I want a ranch hand but was thinking it wouldn't work with the safety systems. I never use the ACC, so would I have to cut it out? This might be a dumb question but is the sensor in the emblem used for anything else? The reason I ask is that I turned everything off so I dont have to hear any beeps
  10. Oct 26, 2018 at 10:44 AM
    Rider0120
    Bucks County, Pa
    I would assum the emblem would need a clear line of sight. Strap a piece of cardboard in front of it and see what happens then with the cardboard on the emblem put a piece of aluminum or metal on top of the cardboard and see if that Pisses it of. I use the ACC everyday so I needed it work so that is why I went the route I did
  11. Nov 1, 2018 at 6:59 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Have you run into any issues? I think I am going to buy one and cut out the mesh like yours.
  12. Nov 1, 2018 at 4:24 PM
    Rider0120
    Bucks County, Pa
    I have over 1000 miles with no issues. I use the ACC everyday and i even came up on a car pretty quickly one day and it told to brake. It acts the same with the bumper/grill graud as it did with out
    Boerseun likes this.
  13. Nov 2, 2018 at 3:47 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Sweet! I am going to put in my order this weekend. Thank you
  14. Jan 9, 2019 at 7:58 AM
    TexasCanesFan
    TexasCanesFan New Member
    Joe
    Rockwall, Texas
    2018 Silber Tundra Crewmax TSS
    Ranch Hand looks great. Still no issues with PCS interference? Been wanting a Ranch Hand for a year and seems I finally found the solution.
  15. Jan 9, 2019 at 8:00 PM
    Rider0120
    Bucks County, Pa
    Knock on wood no issues 14,300 miles
  16. Jan 9, 2019 at 8:37 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Nice job. Welcome from Northeast Connecticut New members.
  17. Jan 10, 2019 at 4:58 AM
    TexasCanesFan
    Joe
    Rockwall, Texas
    Great to hear. Thanks
  18. Jan 10, 2019 at 6:28 AM
    Rider0120
    Bucks County, Pa
    It your not pressed for time getting the bumper on you could even cut less of the mesh so it protects more of the radiator . The beam pattern is only 20 degrees horizonal and 5 vertical.
  19. Jan 10, 2019 at 6:31 AM
    TexasCanesFan
    Joe
    Rockwall, Texas
    I imagine I will end up removing the entire expanded metal piece.
    I wish I could just order one without the expand metal at all. Would be easier and no paint touch up.
  20. Jan 10, 2019 at 7:28 AM
    Rider0120
    Bucks County, Pa
    You can from a ranch hand dealer. It will take 6-8weeks and will not be returnable if they’re is any damage from shipping. Call ranch hand directly if you want to go with them with a custom order. They’re are other bumpers that don’t have the mesh and a little better fit and finish. Don’t get me wrong I really like my summit bumper because I feel it’s the best bang for your buck at 1200, but it is a production bumper and when you look really closely it is not Perfectly square or the powder coat does not get in all the nooks and crannies.
    For rust protection i use a silicone spray wax from Maguires for my truck and the bumper it’s $30 a gallon and I can spray it heavy in those areas that the powder coat might not have gotten. And it way cheaper then produxa and hydrosilx
    Luckydog likes this.
  21. Jan 10, 2019 at 12:57 PM
    TexasCanesFan
    Joe
    Rockwall, Texas
    This is the first truck I haven't had Ranchhands on in a long long time. I usually do at least the brush guard. Most trucks had replacements front and rear. PCS threw me on this one.
  22. Jan 10, 2019 at 1:19 PM
    Borgs
    Borgs New Member
    PA
    Dude, I saw the Thompson license plate and then did a double-take where you are from. We are neighbors! Thompson couldn't beat Conicelli so I bought mine from Conicelli. Awesome bumper.
    Rider0120[OP] likes this.
  23. Apr 17, 2019 at 7:27 PM
    bhuff92
    bhuff92 “Hi, I’m Rod and I like to party”
    Ben
    Columbus, Ohio
    2018 Charcoal Tundra SR5 Crewmax
    Iron Cross Front Bumper with Grille/Brush Guard.
    Excellent post, great job with the pictures and success. Looks great.
  24. Apr 17, 2019 at 8:29 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Dave is this you?
  25. Apr 18, 2019 at 5:49 AM
    abner
    abner New Member
    2017 CM 1794
    Seems like a lot of weight on the front end
  26. Apr 18, 2019 at 7:47 PM
    Rider0120
    Bucks County, Pa
    210lbs. I couldn’t feel the difference after I put it on
  27. Mar 1, 2021 at 3:22 PM
    Ardentangler
    Ardentangler New Member
    Frenchtown NJ
    I am looking at a Ranch Hand Summit for my 2016. Mostly for deep protaection. Sounds like the weight is a non issue but figured I would ask again as some time and miles have passed. Any mileage decreases due to this.
  28. Mar 1, 2021 at 3:23 PM
    Ardentangler
    Frenchtown NJ
    Sorry but deer protection
  29. Mar 1, 2021 at 4:35 PM
    Lake.Life24
    Shawn
    Upstate, NY
    I am sure there would be a little decrease do to the weight unless you aluminum
