2018 Tundra Trd onroad
Discussion in 'New Member Introductions' started by Terdonroad, Nov 26, 2021.
  1. Nov 26, 2021 at 9:57 AM
    Terdonroad
    Terdonroad [OP] New Member
    Seth
    PA
    2018trdonroad
    JL Audio TW1 Sub Sony AX8100 Headunit Fuel Shok 18x9 +20 Dirty Deeds 6in Exhaust
    Hello all, This is my 3rd Toyota truck. 2 Tacoma’s a 2012 that was lifted on 33’s and a 2021 off-road 6 speed manual. I hated the 3.5 liter v6 in the 2021 Tacoma. I always wanted a Tundra but it just wasn’t in the cards for me until recently. Very happy with it. I have a question about wheel fitment.
    I have a set of fuel shok wheels coming. They are 18x9 +20 offset. Will these fit without further modification? The truck is on stock 18in off-road wheels and tires.
    Thanks
    TRDFerguson and mattgecko like this.
  2. Nov 26, 2021 at 10:15 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    The +20 offset brings the wheels out from the truck vs the stock offset of +60. So, you could have some rub on plastics, but that can be corrected easily. Of course tire size matters as well, taller wider tires could rub a bit more.
    But, +18 to +25 is very common for aftermarket wheels and lots of people run them, so you should be fine. May need to remove front spats or trim mud flaps, heat up the wheel well liner and you can bend it with a basketball or other item for additional clearance. If you search the wheel/tire forum here you will find posts and details where people needed to make some adjustments like that for clearance.
    Terdonroad[OP] likes this.
  3. Nov 28, 2021 at 7:04 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  4. Nov 28, 2021 at 7:47 AM
  5. Nov 28, 2021 at 7:50 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Welcome. Cute pup.
  6. Nov 28, 2021 at 8:34 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  7. Nov 28, 2021 at 4:15 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Dec 5, 2021 at 6:07 PM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
  9. Dec 6, 2021 at 6:03 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome from so cal
