2018 tundra fog light wire separation
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra_Enthused, Feb 24, 2021.
  1. Feb 24, 2021 at 4:59 PM
    Tundra_Enthused
    Tundra_Enthused [OP] New Member
    Vancouver Island, BC
    2018 Quicksand Tundra TRD Off Road 2015 Toyota 4runner Sr5
    Fuel 18" Vector wheels, toyota tonneau cover, trd pro suspension upgrade, back up lights wired into reverse lights, tow mirrors
    Hey all,
    Just trying to figure out what my next step is, tried searching this issue on here and no luck.
    So one of the wires in the plug that plugs into the oem foglight has separated from the plug, is there a way to re attach the wire, or am i looking at a whole new plug wire assembly.
    The toyota parts guy here in town was not much help at all. Sorry i do not have a photo i thought i took one when it was apart.
    Thanks!
  2. Feb 24, 2021 at 6:24 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Is it the contact that came out with the wire or just bare wire? If contact is still on wire, just insert into plug. Make sure its the correct orientation. If not, you'll have to remove the contact and crimp it. Isn't your truck still under warranty?
  3. Feb 24, 2021 at 6:25 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
  4. Feb 24, 2021 at 6:29 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If what @danz75 mentioned doesn’t work or you did something to void the warranty, you can just get a new female H11 pigtail off Amazon and splice it in.
    edit: or just do what @thomasbus337 said
  5. Feb 24, 2021 at 6:52 PM
    Tundra_Enthused
    Hey guys thanks for the fast responses, definitely just need an h11 pigtail. I have to say though toyota sure dropped the ball on these fog lights. Very poor design
  6. Feb 24, 2021 at 7:04 PM
    So the 2018 was H11? My 2020 is H16. Found that out when swapping my bumper and wiring the Rigids. The H11 adapter from my 13 wouldn't fit.
  7. Feb 24, 2021 at 7:12 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, not sure when they made the switch, but mine are definitely H11.
  8. Feb 24, 2021 at 7:13 PM
    Tundra_Enthused
    Oh interesting. Yeah h11 on my 2018. I prefer not to deal with warranty on these small things and just deal with it myself in the garage.
    TRDFerguson likes this.
  9. Feb 24, 2021 at 7:14 PM
    Tundra_Enthused
    I was going to change the bulb and let the whole assembly hang and the wire just slid out just the wire
  10. Feb 25, 2021 at 5:14 AM
    Rubberdown
    You can buy a contact and crimp tool and fix it if you do some research. Probably cheaper to get a new pigtail and solder it on.
