2018 tundra alarm/remote start
Discussion in '3rd Gen Tundras (2014-2021)' started by SocaliTundra958, Dec 11, 2017.
  1. Dec 11, 2017 at 8:23 AM
    SocaliTundra958
    SocaliTundra958 [OP] New Member
    Temecula
    2018 SR5 CREWMAX TUNDRA
    stock
    looking into purchasing an aftermarket alarm/remote start, anyone have any recommendations for the 2018 tundra models, can’t seem to find any for the 2018 models, if you can post model # and cost for set up that would be appreciated, thank you
    Stulloh and Laz1388 like this.
  2. Dec 13, 2017 at 10:21 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
  3. Dec 13, 2017 at 10:58 AM
    iHacker
    iHacker Well-Known Member
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    ccdawnpatrol likes this.
  4. Dec 13, 2017 at 12:20 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I actually talked to the guy from Tech12Volt and he told me that the Fortin EVO One in his son's 2018 Tundra works with the OEM key but others (with 2018's) didn't. I don't understand why but obviously it is still a hit and miss. The price is good and the installation with the T-harness doesn't look to awfully difficult. I was reading somewhere here where a member installed one (might have been iHacker) and if I remember correctly his is working just fine.
  5. Dec 13, 2017 at 1:39 PM
    iHacker
    For the ones not working on 2018 Probably they forget something when flashing the unit, if the guy at tech12volt said it work then it should be, they flash the unit for your specific vehicle, I recommend to buy the flasher tool to keep your fortin evo updated.
  6. Dec 13, 2017 at 4:36 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I want in if there is a group buy!
    71_340 and ccdawnpatrol like this.
  7. Dec 13, 2017 at 4:42 PM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
  8. Dec 13, 2017 at 4:42 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I still like to know when Toyota offers an OEM remote start kit for the 2018 and if they will program so it doesn't kill the engine when you open the door.
  9. Dec 13, 2017 at 4:46 PM
    ccdawnpatrol
    Salt Lake City, UT
    Totally, seems silly to have the engine start and stop when the door opens. Just set it up like all the other after market remote starts where you have to put in your key, turn it to a certain point and put your foot on the brake.
    71_340 likes this.
  10. Dec 13, 2017 at 5:00 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I think everybody agrees with that assessment, hopefully Toyota is listening.
    Stulloh and ccdawnpatrol like this.
  11. Dec 13, 2017 at 5:48 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Or just get evo one. Problem solved!
    PermaFrostTRD likes this.
  12. Dec 13, 2017 at 5:54 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I would/will once I know for sure that it will work (start and open doors while running) with my existing remote key, I don't want to use an additional fob. trust me, I much rather spend 200.00 vs. 500 for the OEM version. I can install it myself.
  13. Dec 13, 2017 at 6:06 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have an evo one on my other car. 2015 Camry w H key. So if it works on that I’m sure it will work on the tundra. Maybe they haven’t released the firmware yet.
  14. Dec 13, 2017 at 6:55 PM
    Vendeta2k
    Jay
    Montana
    2018 Limited Cement CM
    Remote start is done. 3x lock is working to start the truck. It’s an compustar remote starter using an idatalink blade module. The only downside is that the factory fob will not unlock the door when it’s running so I will have to use the key....but I’m ok with that...seems like a factory Toyota thing to render the fob inoperative once the vehicle is started remotely.
    71_340 likes this.
  15. Dec 14, 2017 at 1:54 AM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    My Evo One should be in my mailbox today or tomorrow. From what I've heard, some Tundras will unlock with the remote while running, some won't. Not sure if it's a roll of the dice, or if different trim levels are wired differently. I figure I need the key in my hand either way...needs to go into the ignition. It sure will be nice to get into a warm truck when I leave my cabin!
  16. Dec 14, 2017 at 3:45 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Are you doing a self-install and is yours pre-programed for your truck? I know, the seller on eBay send them out programed for your specific vehicle.
    Keep us updated.
  17. Dec 14, 2017 at 7:14 AM
    iHacker
    There’s a lot of options to turn ON/OFF In the flashing tool software, if someone is having problems of some sort like the mentioned in your post should be something forgotten to select. That’s why I recommend to buy the flashing tool is cost around $40-$45 and is really useful to have it on hand to keep the evo updated.
  18. Dec 14, 2017 at 7:24 AM
    iHacker
    At some point I considered the option to sell the Fortin EVO One kit with all the unused wires removed and flashed for specific truck of course for less than tech12volt suggested price but parts became more expensive so this never get accomplished, now I lost contact with my parts supplier.
  19. Jan 6, 2018 at 11:22 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Did you get your remote start installed and working? Also, which T-harness did you use and did you get separate key fobs?
    Thanks.
  20. Jan 6, 2018 at 1:08 PM
    Theonlyway
    Theonlyway I am all that is man
    User
    2015 Tundra crewmax trd or
    I’m going with compustar pro t11. 3 mile range, waterproof, can setup anything with it.
  21. Jan 7, 2018 at 12:11 PM
    Diverguy
    Leon
    PA, USA
    Got it all up and running. I used factory remotes. One out of maybe 10 times, the alarm goes off when I trigger the remote start. The trick seems to be to hit lock once (if the truck's not locked) and give it a second or two before hitting the 3 lock sequence to activate the start. I'm still getting used to it. It will be easier to confirm start from a distance when I have my new exhaust system on.
  22. Jan 7, 2018 at 6:35 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Thanks for the reply, did you use a T-harness?
    Also, I guess that is one way to have a 2-way remote.....just add a loud exhaust.:)
