2018 Sequoia Platinum Chrome Side Trim Removal
Discussion in 'Sequoia Builds' started by Adamdsgn, Sep 11, 2020.
  1. Sep 11, 2020 at 6:58 AM
    Adamdsgn
    Adamdsgn [OP] New Member
    2018 Toyota Sequoia
    Anyone attempted to remove the chrome side panel trim (running along the bottom center of the front and rear doors) on 2018 and up Platinum? Wondering if it's just adhered to the body with adhesive or if there are trim clips holding it on and some sort of pre-drilled holes in the body...
    Not sure I want to tackle removing the door panel to find out and thought I would check here first to see if anyone has attempted to remove it. TIA.
  2. Sep 11, 2020 at 7:02 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    It's just double sided tape. You can use a pry tool or a dental floss. Pry tool is easy but you have to be extra careful.
  3. Sep 11, 2020 at 7:18 AM
    Adamdsgn
    2018 Toyota Sequoia
    The chrome piece looks to be seated inside of a black trim piece. So you're saying I can pry off the black piece (carefully) and then buff off tape residue or adhesive?
    You just made my day if that's the case because I got a quote to get it color matched to the car and whew!
  4. Sep 11, 2020 at 7:25 AM
    SprinterAE86
    Ian
    I dechromed both the Sequoia and Tundra. It's not like the cats in the before the 90s. Everything all badges are just stick on.
    No, you might have some color variations between the exposed paint and non exposed paint.
    Beesta likes this.
  5. Sep 11, 2020 at 10:48 AM
    Adamdsgn
    2018 Toyota Sequoia
    I removed the Platinum badges and had to some slight buffing, but I'm talking about the strips pictured below. I'm not sure what year they were added (I think maybe 2018 when they changed the headlights and hood shape). You can tell the chrome is seated in some sort of black channel. I'm not sure if the channel is attached to the body with some sort of adhesive or if there are holes drilled thru the body.
  6. Sep 11, 2020 at 10:58 AM
    SprinterAE86
    Ian
    @Roman Is this secured only with tape?
  7. Sep 11, 2020 at 11:00 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    I doubt you can just remove the chrome and have it look good, my bet would be that the chrome is welded to the black part. So if you remove the just the chrome there will be holes in the black, which would look not very nice.
    And Toyota at times loves to put alignment holes in the panels for the moldings. I would try and remove from the passenger side first, and see how it goes. If there are holes, then you can retape the mldg and reinstall it. And not have to look at it every time you get into the truck.
    **** Never mind about the holes in the door panels, just looked it up, and they are a dealer option, so the are tape/glued on. ****
    SprinterAE86 likes this.
  8. Sep 11, 2020 at 1:21 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    It doesn't show in the diagram, but there is only one part number for the door shell. Should just be held on with adhesive.
    SprinterAE86[QUOTED] likes this.
  9. Sep 14, 2020 at 4:58 AM
    Adamdsgn
    2018 Toyota Sequoia
    Thanks for all the help guys. The striper were indeed held on by adhesive strips. An hour and several blisters later... The strips have been removed and the area cleaned and ready to buff. Will post a picture of the finished project. Extremely happy that I didn't have to pay to get them color matched. The Sequoia looks MUCH better without the chrome strips.
    Bama and War Machine like this.
  10. Sep 14, 2020 at 1:31 PM
    Adamdsgn
    2018 Toyota Sequoia
    After a quick buffing with some polishing compound you can’t even tell they were ever there.
    S. Equoia, owb2gp, Beesta and 5 others like this.
  11. Sep 14, 2020 at 2:04 PM
    Bama
    Bama Member
    2016 MGM Tundra 2015 MGM Sequoia
    Looks so much better!
  12. Sep 14, 2020 at 3:11 PM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    Damn, I am soooo glad my 2018 Platinum didn’t come with those. It would have been a deal breaker
    **EDIT** just seen you have a Sequoia. Glad to hear you got it off ok
  13. Sep 14, 2020 at 3:23 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Wow that does look so much better
    Great job
  14. Sep 15, 2020 at 2:03 PM
    fjc8871
    fjc8871 New Member
    Bruno
    2012 Sequoia Platinum 4x4
    That does look much better without the chrome! Great job.
  15. Sep 17, 2020 at 6:35 PM
    Sequoiar
    Sequoiar New Member
    I was going to suggest a heat gun, dental floss, and "goop" to remove the residue..
  16. Sep 23, 2020 at 7:54 AM
    Adamdsgn
    2018 Toyota Sequoia
    I've used fishing line to remove the smaller emblems. These were a little tougher. I actually ended up using a wooden shim to and some slight prying with the opposite hand to split the two strips of adhesive tape holding the strips on.
  17. Mar 15, 2021 at 3:01 AM
    Talon
    Talon New Member
    2018 SR5 Sequoia
    Lifted, TRD swaybars,
    Do you still have the door trim?
  18. Mar 15, 2021 at 5:56 AM
    Adamdsgn
    2018 Toyota Sequoia
    I don't unfortunately. You pretty much have to destroy the molding in order to get it off. It's a very thin metal-ish material and when you pry it off it bends, warps and creases all to hell.
