2018 Lighting control
Discussion in '2.5 Gen Tundras (2014-2021)' started by FishingDik, Sep 4, 2019.
  1. Sep 4, 2019 at 6:05 PM
    FishingDik
    FishingDik [OP] New Member
    2018 Dark Grey TRD Sport
    Top of cab backup lights remain lit for 20 minutes after shutdown. Three minutes would be plenty. How do I change that time?
  2. Sep 4, 2019 at 7:22 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    In for a response, I didn’t know you could even change the time.
  3. Sep 4, 2019 at 7:47 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Sounds like the auto shut off to all the trucks power has kicked in. Make sure your cab light switch isn't set to on. If it's set to door it will turn off when you lock the truck or if you don't lock your truck it turns off when interior lights turn off (think it's 2 minutes)
    B737 and Omohundro like this.
  4. Sep 5, 2019 at 5:00 AM
    Omohundro
    Jody
    McMinnville TN
    Sounds good
