2018 exhaust back fire on cold start.
Discussion in 'Performance and Tuning' started by MaticsSoCal10D, May 29, 2019.
  1. May 29, 2019 at 12:30 PM
    MaticsSoCal10D
    MaticsSoCal10D [OP] New Member
    2018 CrewMax Limited 4x4 Cement Grey
    TRD Rear Sway bar. NFab Running Bars. S&B air intake. Flowmaster 50 Series
    Hey everyone, kind of curious to see if anyone else with 2018 or newer have this issue. It seems that less than half the time I cold start my Tundra I get a back fire or "pop" from my exhaust. I originally had a flowmaster 50 series and it popped and now I recently switched to a flowmaster 40 series. And it still pops on cold starts. I've read that it's just trapped gasses in exhaust and it ignites on start up and there for you get the pop sound. It's very annoying and to be honest shouldn't be happening on a brand new truck. Anyone else have this issue?
  2. May 29, 2019 at 2:33 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Probably due to all of the stupid redirection baffles inside of flowshit mufflers. If it didn’t do it stock then it’s the aftermarket mufflers.
    Metro14536 and bdpeelgren like this.
  3. May 29, 2019 at 2:36 PM
    MaticsSoCal10D
    Flowmaster is one of the most popular brands. Quality may not be what it use to be, but no way I am the only one with this issue.
    Black Wolf likes this.
  4. May 29, 2019 at 2:37 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Had my 40 series FM for 3 years now and no issues.
  5. May 29, 2019 at 2:41 PM
    Danman34
    Danman34 New Member
    Danny
    Flowmaster just has great marketing and the fact that they design their mufflers to increase noise for cheap. Popularity doesn’t make it a great product. I have BAM exhaust on my 18’, which is basically a straight pipe design and my cold start ups are smooth as silk. The sudden burst of exhaust gas through the redirection chambers inside of the flowmaster is most likely the cause of the popping
  6. May 29, 2019 at 2:42 PM
    Aurora CO
    My cold start ups are as smooth as silk.
  7. May 29, 2019 at 2:58 PM
    Blueknights75
    Ron
    Clayton, NC
    Did you have this problem when the exhaust was stock?
    GODZILLA likes this.
  8. May 29, 2019 at 3:03 PM
    Aurora CO
    Pics of exhaust setup?
  9. May 29, 2019 at 7:02 PM
    MaticsSoCal10D
    No not with stock muffler.
  10. May 29, 2019 at 7:03 PM
    MaticsSoCal10D
    I'll snap a pic and post it. But just basic setup with side outlet.
  11. May 29, 2019 at 7:28 PM
    Aurora CO
    Need to see the pipes from FM to outlet tips.
    Tundyfundy likes this.
  12. May 29, 2019 at 8:16 PM
    Pinski
    Pinski New Member
    Mark
    Western New York
    2018 SR5 TRD Crew
    Volant (Corsa) cat back,tint
    My Corsa does the same thing on a warm start up. Never does it on cold start, I love it...Also backfires coming down a hill when I’m using the gears to hold me back. I give it a little gas then let off and it pops every time....
    14crewmax likes this.
  13. May 29, 2019 at 8:22 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I have a 2018, no pops or backfires with the stock exhaust or the TRD system either...
  14. Jun 5, 2019 at 12:33 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I get it with my BA 8 inch single outlet exhaust once in a while. To me it’s no big deal.
    equin likes this.
  15. Jun 5, 2019 at 12:48 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    I have dirty deeds 6" system and it happens from time to time on start up and like @Pinski when I'm using gears to brake. Doesn't bother me though
    AZBoatHauler and 15whtrd like this.
  16. Jun 5, 2019 at 12:52 PM
    15whtrd
    15whtrd Mr. Blonde
    Mine does it occasionally as well. I like it! It doesn’t do it upon start up but it will do it if I’m on the gas and then off it when the truck is slightly cold driving down the street.
    I have the BAM 6”
  17. Jun 5, 2019 at 12:54 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    Same here, I kinda like it haha I cut my tailpipe at the axle turn down so maybe that makes a difference
    15whtrd[QUOTED] likes this.
  18. Jun 5, 2019 at 12:55 PM
    15whtrd
    15whtrd Mr. Blonde
    That could have something to do with it. The OP has a side outlet. Which could very likely make it more prominent.
    scpete24[QUOTED] likes this.
  19. Jun 5, 2019 at 12:58 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Agreed!! If there is an exhaust leak it can also cause the pop. Like a small gap where the gaskets on the pipe is can cause this. The cold can open the gap more due to contraction, then when Warmed up it will seal. If no leaks then it seems the TRD exhaust is in your future!!
    I’m running the TRD and smooth as silk since day one. Not one backfire, ever.
  20. Jan 7, 2020 at 6:41 PM
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    I have this issue every once in a while. I had a 07 that did it to. I have a Pro now and the trd exhaust did it also but it not very loud and you probably won’t even notice unless you were listening for it. I had a Flowmaster super10 installed yesterday and I heard this afternoon. Sound like a backfire on start up. I think it’s some kind of gasses that ignite on start up.
  21. Dec 19, 2021 at 8:56 AM
    14crewmax
    14crewmax New Member
    Oroville Ca
    2014 TRD off road crew max 4x4 silver sky metallic
    Stock
    Mine did it last night I kinda liked it, scared the shit out of my gf, I have a flowmaster super 44 it also does it when I’m going down a hill coasting and I lightly touch the gas pedal.
  22. Dec 19, 2021 at 11:40 AM
    14crewmax
    Oroville Ca
    Stock
    Same here I’ll have it in s3 or s4 and lightly tap the gas and it pops
