2018 crooked front bumper
Discussion in 'General Tundra Discussion' started by wigsplitter, Nov 26, 2017.
  1. Nov 26, 2017 at 7:45 AM
    wigsplitter
    wigsplitter [OP] New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    Just wanted to throw out my experience of buying the 2018 and see if anyone else has had this issue. It took a week to notice (actually wife noticed first) but my front bumper was crooked from the factory. The passenger side of it had more space between the grill and the top of the bumper than the driver side did. I could get my fingers in between the bumper and grill on passenger side and could not on driver side. It was at least a half inch difference. When I took the truck back to the dealership they were all just as confused as I was. Turned out there were 3 other trucks in the parking lot that were just like mine. They had to keep it a few days and get a Toyota rep involved but I got my truck back a few days later and they fixed it for free. So if your a new owner of a 2018, take a look at your bumper and see if it is crooked.
  2. Nov 26, 2017 at 7:53 AM
    Marty McFly
    Morty McBoonJug
    That's good they took care of it :thumbsup:
    On another thread someone mentioned the bed was off on the 3rd gens, so I checked mine and it was a little off too but not enough to do anything about it :confused: you can't really tell unless you look really hard :burp:
    ColoradoTJ likes this.
  3. Nov 26, 2017 at 9:42 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Check your rear bumper too. My rear is crooked like that.
  4. Nov 26, 2017 at 9:59 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    My rear bumper is crooked too. There's a bigger gap between the body on the passenger side. I'm taking back to the dealer tomorrow.
    wigsplitter[OP] likes this.
  5. Nov 26, 2017 at 10:27 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    Sounds like my old Titan! You got me wondering so I went into the garage to check my '18... The passenger side has a slightly larger gap than the driver side, but maybe only 1/8" or so.
  6. Nov 26, 2017 at 10:34 AM
    wigsplitter
    DFW Texas
    damn, I will check it out thanks
  7. Jan 15, 2018 at 3:31 PM
    motorswin
    motorswin Back the blue
    2017 Tundra Limited TRD
    Maxtrac 3.5" lift Kmc Grenades with Cooper St Maxx 295/75/18
    Saw mine is crooked today...does anyone know a quick fix for this?
  8. Jan 15, 2018 at 3:42 PM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    you have a crooked rear end? sounds like a personal problem. you may want to get that checked.
    justfortun and joonbug[QUOTED] like this.
  9. Jan 15, 2018 at 3:53 PM
    motorswin
    Thanks I'll give it a shot
  10. Jan 15, 2018 at 3:57 PM
    epa4wd
    epa4wd New Member
    Ed
    No problem, nuts are 14mm (long socket needed) if I remember correctly.
  11. Jan 15, 2018 at 5:15 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Mine was crooked from the factory a good half inch just like the OP. I just dont want to dick with it. Looks like the truck is smirking at you. Am i surprised they are still having this problem?..no.
  12. Jan 15, 2018 at 5:59 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Mine was too. About 1/4" high on drivers side. Must be those slanty eyed engineers. Easy fix. Did it when I installed light bars
  13. Jan 15, 2018 at 6:07 PM
    gosolo
    Ray
    NW Oregon
    Much more common to find this problem on non-white trucks. The Super White, Super Fine, Super Fast Tundras rarely have the problem, starting their lives so close to perfection. Just saying...
  14. Jan 11, 2019 at 3:07 PM
    Jono
    Jono New Member
    2018 Tundra TRD 4x4
    Did you adjust the front bumper by loosening the nuts that hold it to the frame or did you go in through the front?
  15. Jan 11, 2019 at 4:39 PM
    AZTundra
    Paul
    Phoenix, AZ
    My 2017 is a bit off on the front bumper as OP noted and also the rear :facepalm:I'll post up some pics tomorrow. Wondering if I can just realign it myself since I'm at 35K miles I doubt the dealer will do much.
  16. Jan 11, 2019 at 5:14 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I did mine when I replaced grill and headlights. Pop the grille off and the plastic pieces under headlights to get access to bolts.
  17. Jan 11, 2019 at 5:23 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks, I'll give it a try. The plastic piece under the drivers side headlight might get repaired then at the same time (freeway debris chipped/marked up the paint on that panel)
  18. Jan 12, 2019 at 5:36 AM
    wigsplitter
    DFW Texas
    My truck came with the 3M protective film on front of the truck. Glad it did as it has already saved from a few rock chips.
