2018 Crewmax w/6" lift
Discussion in 'Suspension' started by kevin3272us, Jan 25, 2018.
  1. Jan 25, 2018 at 10:51 AM
    kevin3272us
    kevin3272us [OP] New Member
    Kevin
    2018 Crewmax
    6" lift with toyo mt 35x12.50r20 tires Toyo.
    I bought this new from a dealership a few months ago with the aftermarket mods already on it. I have Toyo 35" tires- mt 35x12.50r20. I am already noticing wear on the front tires only, outside edge of tire. Any suggestions?
  2. Jan 25, 2018 at 10:59 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    Check alignment (toe), which 6" lift is it?
  3. Jan 25, 2018 at 11:13 AM
    kevin3272us
    Kevin
    2018 Crewmax
    I had it aligned at 1000 miles because it was pulling. No pull anymore. I believe it's s spring Propump lift.
  4. Jan 25, 2018 at 1:46 PM
    I'd take it back to the dealer and make them get it right.
  5. Jan 25, 2018 at 1:49 PM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    agreed.. you paid for it, so make sure they get it right.. tires get $$$$ once you start wearing them down funny
  6. Jan 25, 2018 at 2:20 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Did they put new UCAs on it? They need to make it right. You can run in to a lot of problems with a 6" lift. I bet camber is off.
  7. Jan 25, 2018 at 3:37 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    I guarantee the alignment is off. I bought my 17' from the dealership with a 7" ProComp lift with 37" tires. It drove great. After I had the Custom King shocks installed the shop had it aligned by a different shop. It drove like shit. They did it 2 times and it sucked. The 4x4 shop finally got their own alignment machine so they could do all the alignments the correct way. I was told by my 4x4 shop that REGULAR auto shops only go by what Toyota recommends for a stock truck.They have NO clue how to align a lifted truck. Once my truck was aligned correctly I now had to do a BMC (body mount chop) That means that from the day I bought my truck the alignment was NEVER correct. I believe it was done that way so the tires would clear the body mount. Most likely for legal reasons because you need to cut the frame. You need to go to off road experts to make sure you get the correct alignment.
    GNTundra likes this.
  8. Jan 25, 2018 at 6:39 PM
    Otaku4life69
    David
    Bay Area CA
    2017 Black SR5 CM
    You can see it in my build thread.
  9. Jan 25, 2018 at 6:47 PM
    Have dealership fix it...its under warranty if they selling the truck lifted
  10. Jan 25, 2018 at 7:09 PM
    kevin3272us
    Kevin
    2018 Crewmax
    Thanks for the input. Called the dealership today and will be taking in.
  11. Jan 25, 2018 at 7:26 PM
    Welcome from Ohio!
    kevin3272us[OP] likes this.
