2018 AC not cold enough
Discussion in '2.5 Gen Tundras (2014-2021)' started by Eric104, Jun 19, 2018.
  1. Jun 19, 2018 at 9:23 AM
    Eric104
    Eric104 [OP] New Member
    Eric
    2018 Crewmax
    When it’s 90 plus degrees outside my ac on LO and max fan speed seems very weak. At night it works just fine, won’t quite ice you out but it’s pretty good.
    Has anyone else experienced lack luster air conditioning performance?
    I remember reading some other people mention something similar but couldn’t find the thread. I’m at the dealer right now and of course it worked just fine when I pulled in but it’s only 74 degrees outside. I’m having them check it out. Hopefully they find something.
  2. Jun 19, 2018 at 9:29 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Any difference when using the re-circulate mode?
  3. Jun 19, 2018 at 9:30 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Most A/C systems can handle about a 20 degree drop in temp from ambient. So if your above 90, you will likely be at 70 degrees plus. This is dependent on several factors, humidity being a big contributor. You will cool more effectively in a dry climate than in a very humid one.
  4. Jun 19, 2018 at 9:36 AM
    Eric104
    Eric
    2018 Crewmax
    I have played with the reculate button. It is usually on. It has been humid here but nothing like it will be later this month.
    I never thought about the humidity factor. It just feels weak. My 2010 Silverado blew ice cold from day one until I traded it in on the new Tundra.
  5. Jun 19, 2018 at 9:41 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    I read in another forum that 2018 has the new refrigerant r1234yf.
    Abrams65 likes this.
  6. Jun 19, 2018 at 9:43 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    I've noticed some systems just run colder than others from car to car. Dodge Ram sucks ass when it's hot, Sierra 3500 sucks ass when it's hot, Lexus IS350 is ice cold when it's hot, Nissan Pathfinder sucks ass when it's hot, old ass 1996 4runner is colder than shit when it's hot, Tundra - I would say is on the sucks ass when it's hot list - at least until the rig warms up and you get moving.
    4x4_Angel and Eric104[OP] like this.
  7. Jun 19, 2018 at 9:45 AM
    15whtrd
    15whtrd Mr. Blonde
    Check your cabin air filter. Your issue sounds different as a clogged cabin air filter will usually just not work properly all the time. But it doesn’t hurt to check.
    Black Wolf and Eric104[OP] like this.
  8. Jun 19, 2018 at 9:47 AM
    15whtrd
    15whtrd Mr. Blonde
    Yes. Mine is ice cold out on the highway but sitting still especially after just starting the truck it is not very cold. I think it must have something to do with the location of the condenser. Sometimes mine is so cold I have to turn down the temperature even with the fan on low. This is even out in the middle of the desert.
  9. Jun 19, 2018 at 9:51 AM
    Eric104
    Eric
    2018 Crewmax
    I live 7 miles away from work and everywhere I run to is pretty close to the house. Maybe I need to turn beast mode on and really get things spinning.
    I may just come to the dealership on a hot day and see how the other 18’s perform if they don’t find anything today.
    Abrams65, 4x4_Angel and 15whtrd like this.
  10. Jun 19, 2018 at 9:56 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    I turn mine to full fan lo temp and all windows down until I get positive cold airflow then I close all windows starting with the rear then rear pax then fronts and lastly sunroof which I tilt up and close once the heat soaking has dissipated
  11. Jun 19, 2018 at 10:00 AM
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    2018 here and the A.C. In the Tundra is even colder than the other car, which I thought " kicked ass! ".
    I have to turn it down after 15 mins.
    Black Wolf and 15whtrd like this.
  12. Jun 19, 2018 at 10:01 AM
    RonW
    RonW New Member
    I do not have that problem. It's been really hot here in MS with humidity and mine is cold. So cold I have to turn it down sometimes.
    Now it does sometimes take a bit to cool off the cabin. But I just attribute that to it being 500 Sq ft. Ha.
    landphil and Abrams65 like this.
  13. Jun 19, 2018 at 10:14 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    HVAC is weak in the Tundras and has been since 2007, common complaint if you do a search.
  14. Jun 19, 2018 at 10:42 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    my 2015 AC rocks and I am in Mississippi . Sun shade are a must while parking and I have tinted windows (dark but legal) , roll the windows down to change out the air after parking etc. Start out in max (recirculate) . I have to turn mine down after a short while and I drove through the baking ass hot southern Delta this weekend .
    CCATT-RN and Eric104[OP] like this.
  15. Jun 19, 2018 at 10:48 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    In my experience it takes awhile to cool down even on full blast and recirculate. Once it's cooled down it can maintain it fine. I've noticed it cools down more quickly when driving the highway or constant road with air flow going. Light to light it takes longer and doesn't feel like it's blowing as cold.
    I live in Florida.
  16. Jun 19, 2018 at 11:03 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Same here. 07 and still can get too frikin cold at times.
  17. Jun 19, 2018 at 11:09 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    Get a small probe type thermometer and put it in one of the dash vents. That'll tell you what the output temp is. It's hard to judge how well the system is working on sunny days since the sun will heat up the dash, you, and everything else in the truck. Radiant heat can be a real problem.
    These work quite well.
  18. Jun 19, 2018 at 12:32 PM
    Eric104
    Eric
    2018 Crewmax
    That is what the tech said. I will give it a whirl. He took it for a drive and said it frosted the chrome bezels. Maybe I just haven’t driven it long enough. He said it takes 15 minutes to get peak performance. I guess I’m not use to the switch yet from my old truck that would cool me down super quick when it was set to 70.
  19. Jun 19, 2018 at 12:42 PM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    Its been 95+ here in TX lately and I've noticed the same thing on my 2018. My 2013 didn't have this issue. I have to drive with the fan on high and recirculation on with temp on max a/c most of the time. We also have a Scion Xb and that thing will freeze you out! Funny how that little toasters a/c works better than a $45K truck.
    Eric104[OP] likes this.
  20. Jun 19, 2018 at 12:59 PM
    Eric104
    Eric
    2018 Crewmax
    That’s what I was thinking to. My roommates Denali pumps cold air from the start.
    I hoped something was wrong but the tech said mine cooled better than spec. Of course today in Omaha it was in the 70’s and muggy when I took it in. Hopefully opening the windows and having recirculation off will help put some fresh air through the system.
  21. Jun 19, 2018 at 1:08 PM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    North Texas and my 2013's ac works really well. I'll report back in August...;-)>
    b
  22. Jun 19, 2018 at 1:53 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Mine's cool, not as cold as some vehicles I've had/been in. Doesn't help I'm in a black box. I usually open all the windows for the first few minutes to let that greenhouse heat out. I also turn and angle the vents so the air hits me in the face, didn't know they turned when I first got the truck lol.
  23. Jun 19, 2018 at 2:25 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I rarely use recirc. When I do it is only after the cabin cools. Pulling in outside air at 95 degrees when you first crank it up is a lot better than 140 degree inside air. I thought my cabin filter was clogged a couple of days ago until I looked over and realized the selector was on floor setting.
  24. Jun 19, 2018 at 6:54 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    My 2017 CM cools pretty good. I got limo tint on the back 3 recently, upgraded the drivers side tint to reflect out more heat without going darker. Max legal all the way around.
    I’ve also been better about using my windshield cover when I’m parked. It hasn’t been nearly as hot in there when I load the kids into it. Since the truck hasn’t been baking the heat into the inside as much I notice it cools down much quicker, even in the Houston humidity (last week, only high 80s this week lol). After a few minutes on the freeway it’s nice and cool (I’m about 10minutes from the freeway so the 15 minute guide line others have mentioned makes sense).
    I drop the back window and slowly bring it up about 1/4 of the way every few minutes while the system is cooling everything off. I leave it on circulate to encourage the hot air to rise out the back with the cold air blowing out the dash vents as well as at my feet. I usually leave it one setting off of full dash.
    Last week it was hot out and I just had my tint done so I couldn’t roll my windows down for a few days. Luckily I have remote start, so as long as I remember to set my AC settings before getting out of the car it’s not scorching hot when I get in.
    It does take MUCH longer to cool down than other vehicles I’ve owned, but that makes sense as it probably has twice the cabin space LOL
  25. Jun 19, 2018 at 8:30 PM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I turned my ac down when it was 97 degrees yesterday after 8 min of driving. So far this AC has been the coldest I have ever had in a vehicle but maybe my past/other vehicles had/have suck worthy AC systems.
  26. Jun 19, 2018 at 8:37 PM
    tundraj
    tundraj New Member
    The Tundra has wimpy A/C. I really miss my 2008 4Runner.
  27. Jun 19, 2018 at 9:26 PM
    trdprobped17
    trdprobped17 New Member
    Take it in to the dealership and get them to check it out. I had that problem with my 1st Gen Tundra. They had to drain the freon and fill it with new one. It got a few degrees cooler afterwards.
  28. Jun 19, 2018 at 9:54 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    My 18 is pretty dang cold, but it does take a minute to get there.
    trdprobped17 likes this.
  29. Jun 19, 2018 at 11:46 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    No issues on my 16. I use recirculation often, and auto start. I've been in temps up to 106F. I check the HVAC filter when I check the air filter.
  30. Jun 20, 2018 at 3:24 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Depending on your location, humidity has a lot to do with cooling. I would recommend tinting the windows with a strip on the windshield, also a set of vent visors "so you can leave the windows cracked open" while parked and a good sunshade never hurts. This has always done the trick living in Fla.
    Your short drive doesn't help too much either, if you can try to find some shade to park under if you can, you will notice a big difference.
    -Jason
    HecticEnergy likes this.
