2018 5.7 Ticking
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraXPLover, Oct 6, 2019.
  1. Oct 6, 2019 at 4:09 PM
    TundraXPLover
    TundraXPLover [OP] New Member
    Clif
    NC
    2018 CM 4x4 XP
    2018 CM 5.7 here... Flex fuel (Only use 87 regular)
    Serviced every 5000 miles.
    Only 28,000 miles.
    Hearing a ticking sound in the engine compartment. Can hear it pretty good from the passenger side front fender well and from the driver seat with doors and windows closed.
    Just curious if anyone has had this issue?
    It is under warranty and it will be taken in for evaluation.
    Tundra14Platinum likes this.
  2. Oct 6, 2019 at 4:15 PM
    Mr Badwrench
    Mr Badwrench New Member
    My 2018 with 20,000 miles ticks too, and comes from approximately the same location you described. Every Toyota I have ever owned has had a tick to it :confused:
  3. Oct 6, 2019 at 4:23 PM
    TTund16
    TTund16 New Member
  4. Oct 6, 2019 at 4:59 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I have found that when I use Mobil 1 0w-20 Advanced Fuel Economy the upper end of the engine is loud and makes a little racket. I can hear a ticking noise. I had my 20k Toyota are done last month and after the change it was quiet. I asked them what they use and of course it was Toyota 0w-20. The 2 times I have used the Mobil AFE it has been loud. That particular oil must be a little then even for 20w. On the next change I am going with the new Shell Rotella Truck formulation and see if it stays quiet.
    I like Mobil oil but the AFE grade is loud and creates a racket in my Tundra for some reason.
    TTund16 and TundraXPLover[OP] like this.
  5. Oct 6, 2019 at 5:06 PM
    TundraXPLover
    Clif
    NC
    2018 CM 4x4 XP
    TTund16[QUOTED] likes this.
  6. Oct 6, 2019 at 5:42 PM
    TTund16
    TTund16 New Member
    Is ticking a new thing or did it always do that?
    My car had a loud ticking sound when new but it got quiet after a couple month and I hadn't even change oil yet. Break-in maybe ...
    Maybe it will get noisy again getting old. lol
  7. Oct 6, 2019 at 5:55 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    My ticking seems to go away when I use 91 octane, typically 87 is in her...
  8. Oct 6, 2019 at 6:36 PM
    Mr Badwrench
    Walmart special, generally. SuperTech Synthetic or Pennzoil/Quaker synthetic. I use 0W-20, or whatever the manual calls for. I change it every 10K miles (non flex-fuel).
    I used to build engines, mostly older carbureted engines. I have always been a Pennzoil/Quaker fan. If you have ever disassembled/rebuilt an engine that used either... there was film and sludge. It looked bad, but honestly I have put many, many miles on my engines with no leaks. I had a camshaft go flat on me, but I had over 200K miles on an International 345 Wedge that I neglected.
    If there is an API stamp on the bottle and it is cheap, I am buying it.
  9. Oct 6, 2019 at 9:37 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Normal. The 5.7 is a noisy motor. I like to think of it as “the chattering of reliability”. Sounds like it’s ticking sometimes but it’s just the variable valves doing their thing. Don’t over think it. Enjoy your truck!!
  10. Oct 7, 2019 at 5:58 AM
    TundraXPLover
    Clif
    NC
    2018 CM 4x4 XP
    Appreciate all of your input!
    I will roll on and not worry with it.
    TTund16, OR18TRD and Tundyfundy like this.
  11. Oct 7, 2019 at 6:58 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    A former engine designer friend (retired from GM) recommended Rotella for classic Vettes designed to use heavier oils like 10W40 and leaded gasoline. I believe his recommendation was based on Rotella having more ZDDP than general use motor oils. Since it is formulated for heavy duty diesel engines, does it come in 0W20 grade?
    Edit: Just googled Shell Rotella. Rotella comes in several products and grades from full synthetic (T6), synthetic blend (T5) to conventional. Originally intended for diesel trucks, Shell has just introduced a Rotella Gas Truck Motor Oil that comes in 0W20, 5W20, and 5W30.
  12. Oct 7, 2019 at 8:27 AM
    knoxville36
    Knoxville, TN
    Shell just released a new line of Rotella Gas Truck oil and it is 0w-20. Have not ran it but we are running them in a few vehicles at work. GM 5.3 and 6.2 and it has quieted them down also so hopefully it works as good as the dealer blend Toyota oil, which is Mobil 1 with a few differences.
    TundraXPLover[OP] likes this.
  13. Nov 14, 2019 at 1:36 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    I've read that Mobil 1 AFE can be noisy in this engine. I went from TGMO to Mobil 1 EP and didn't notice any difference in noise level.
  14. Nov 14, 2019 at 2:25 PM
    timsp8
    NY
    It’s the VVT. There’s a lot of threads about it.
  15. Nov 14, 2019 at 2:35 PM
    Spakylpm
    Spakylpm New Member
    2020 Tundra
    As Jrharvey mentioned go with a premium octane fuel as a test that always reduces the chatter for me!
  16. Nov 14, 2019 at 2:44 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  17. Nov 14, 2019 at 2:54 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Are we sure we're not hearing injector tickety-tick?
    Cuz they do that. Tickety tick tick tick.
  18. Nov 14, 2019 at 2:57 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Be careful with ZDDP. It can foul the catalyst rich surfaces of a converter.
    Kwikkenney likes this.
  19. Nov 14, 2019 at 3:00 PM
    timsp8
    NY
  20. Nov 14, 2019 at 3:09 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    My 3.4 liter V6 in the T100 has ticked for all of its 263,000 miles.
    Look >>>>>>>>> a squirrel.
  21. Nov 14, 2019 at 6:35 PM
    Badger Co-Op
    Badger Co-Op Blood sausage, cheese, and lutefisk; hit me!
    Kenny
    WISCO
    Amsoil for 21 years; bikes, trucks, cars, race bikes. The Rotella T6 can be had for super-deals in the 5 gallon pails w rebates to mail in.
  22. Nov 14, 2019 at 9:28 PM
    MNBighead
    MNBighead New Member
    2015 CREWMAX TRD OFF ROAD
    I agree and have also found that when I have used Mobil 1 0w-20 Advanced Fuel Economy in the past, the upper end of the engine is loud and makes a little racket. This has been true of my FJ Cruiser, 4Runner, and now Tundra. All have been trouble free for miles and miles and miles. They all quiet down a bit if you use 5W-20. That's what I run in the summer and is allowed per the owners/service manual.
    knoxville36 and Badger Co-Op like this.
  23. Nov 15, 2019 at 4:53 AM
    JohnLakeman
    Good point. My friend's rec was for using the old diesel truck Rotella in 60's-70's Vettes without catalytic converters. It appears that the Rotella brand has been broadened out into virtually all services, not just heavy duty trucks.
  24. Nov 15, 2019 at 6:37 AM
    Badger Co-Op
    Kenny
    WISCO
    Try (3) things; go to ethanol free fuel, you'll probably see about a 10% increase in your MPG, and you are less likely to get water in your fuel.
    Switch to the appropriate Amsoil synthetic, you can go about 10K on an oil change, but swap out the oil filters at 3500 and 7K. (Within that 10K mile window.) Change intervals vary on which oil you buy, your usage of the truck, and your budget.
    Lastly, and most important; when you first start up the vehicle, give it about 60 seconds before you go anywhere. The purpose is NOT to "warm up the engine" but to get oil pressure at 100% in the head before putting a load on the engine. Old Ducati trick that works wonders in EVERYthing with cams and valve-trains.
  25. Nov 15, 2019 at 8:03 AM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Maybe the tick tick tick is just a reminder... Toyota was started by making textile machines so we just have large powerful sewing machines under our hoods!
    TTund16 likes this.
  26. Nov 15, 2019 at 8:30 AM
    knoxville36
    Knoxville, TN
    I forgot about this thread and I posted earlier about Mobil 1 AFE 0w-20. I buy at least 8 gallons at a time as after rebate it is only $12/gallon. It is loud in both our 4Runner and Tundra! I changed the oil in both 2 weekends ago and used the Shell Rotella Gas Truck 0w-20. Both vehicles are completely quiet with no valve train noise whatsoever. It has completely quieted the engines down. Looks like to me that the Shell Rotella truck oil is in the "thicker" side of 0w-20 oil. As mentioned before we are now using this oil in our company gas trucks at work and they are quieter for sure now also.
    My noise is for sure valve train. Has nothing to do with fuel or the injectors. 100% sure the noise is valve train. It is feint and not bad, but for sure there with Mobil 1 AFE. Probably would rock all the way to 500,000 miles.....
    Call me crazy, and not being mean but I do not see how in any form premium fuel will calm down the valve and lifter noise? Has nothing to do with it? Only thing it can effect is the bottom of the valves in the combustion chamber and keep them clean?
    Black Wolf likes this.
  27. Nov 15, 2019 at 1:03 PM
    mundra
    mundra New Member
    2019 platinum 4x4
    I agree on the fuel. I try and run top tier for a better cleaning of 87 octane. Figure if I run it and top tier I’m still getting cleaned. I fun Costco 99% of the time
  28. Nov 15, 2019 at 1:16 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Mine tics as well. It doesn't bother me.
  29. Nov 15, 2019 at 1:24 PM
    Badger Co-Op
    Kenny
    WISCO
    There's good reasons that the diesel community has used Rotella for years, synthetic or regular. Fluids and filters is the diesel mantra.
    Mobil 1 starts to literally burn off around the 3500-5000 mile mark, and you have to monitor the levels if not changing it out.
    Yes, ethanol-free gasoline has less water in it, and therefore your (electronic) fuel pump is LESS LIKELY to die, wear out, or make strange noises.
  30. Nov 15, 2019 at 1:38 PM
    plumber802
    Andy
    Vermont
    I'm not calling you out Kenny but I'm not convinced that as you stated : "Mobil 1 starts to literally burn off around the 3500-5000 mile mark, and you have to monitor the levels if not changing it out."
    Cpl_Punishment and 14CRWMX like this.
