2017 Voltage Issue
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ktemplet, Mar 18, 2020.
  1. Mar 18, 2020 at 10:50 AM
    ktemplet
    ktemplet [OP] New Member
    2017 Toyota Tundra SR5 TSS
    Two months ago I went to crank up my truck and it was dead. The battery was three years old, so I decided to buy a new battery. About a week ago the battery was dead again. After getting a jump I took it to the dealer. They said my aftermarket HIDs headlights/fog lights were causing the issues. So I took it home and put stock lights back in. I am still seeing my voltage meter on the dash jumping. I am also getting dimming cab lights when they are turned on. Idle is around 1100rpms. Any help would be greatly appreciated since my warranty has run out.
  2. Mar 18, 2020 at 10:55 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Start with a load test (often free) of that new battery, and make sure the posts / clamps and clean to bright metal and are tight. Just because a battery is only 2 months old doesn’t necessarily mean it’s good.
    JohnLakeman and 14burrito like this.
  3. Mar 18, 2020 at 11:03 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Do you have an amp clamp?
  4. Mar 18, 2020 at 11:11 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Make sure all the secondary grounds are all connected.
  5. Mar 18, 2020 at 11:15 AM
    ktemplet
    I will clean all the terminals and make sure everything is tight when I get home. I do not but they don't look too expensive. What would I be looking at the current from the battery? Are all the secondary grounds close to the battery? Thanks for all the help.
