2017 Tundra Turn Signal Problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by usmcchris881, Nov 28, 2021.
  1. Nov 28, 2021 at 11:46 AM
    usmcchris881
    usmcchris881 [OP] New Member
    2017 Tundra CM
    Hello All,
    My passenger side flashers have decided to stop working. I checked the bulbs and fuses, but they were all fine. I then replaced the flasher assembly, but that did not solve the issue. The odd thing iss that the dashboard turn signal indicators for the passenger side ticks at double speed (link video below). Any advice on what to check/fix next?
    https://youtu.be/1IN6_dIwiL0
  2. Nov 28, 2021 at 11:55 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Faster flashing means less resistance. Are both front and rear out?
  3. Nov 28, 2021 at 11:58 AM
    usmcchris881
    2017 Tundra CM
    Yes, both front and rear passenger flashers are out.
  4. Nov 28, 2021 at 12:00 PM
    1UP
    1UP Truck Gang
    Do your Hazards work or is one side out also?
  5. Nov 28, 2021 at 12:05 PM
    1UP
    1UP Truck Gang
  6. Nov 28, 2021 at 12:07 PM
    usmcchris881
    2017 Tundra CM
    I have not done any mods. The flasher lights on the front and rear passenger side are both out and do not work with the lights on or off. Hazards only work on the driver side.
  7. Nov 28, 2021 at 12:09 PM
    1UP
    1UP Truck Gang
    Parking lights on only, do you get them on both sides?
  8. Nov 28, 2021 at 12:13 PM
    usmcchris881
    2017 Tundra CM
    not even parking lights. just straight dead on the passenger side (the headlights and taillights work, just not the bulb that is used for the flasher/parking light)
  9. Nov 28, 2021 at 3:08 PM
    1UP
    1UP Truck Gang
