2017 Tundra - Rear Air Bag System Recommendations
Discussion in '2.5 Gen Tundras (2014-2021)' started by NY98M3, Feb 16, 2018.
  1. Feb 16, 2018 at 5:55 AM
    NY98M3
    NY98M3 [OP] New Member
    Good Morning,
    Im in need of an rear air bag system for my 2017 Tundra CrewMaxx. I haul a car trailer back and forth to Pennsylvania several times a year. With the tongue weight, the rear of the truck drops significantly. I tried a weight distribution hitch but its still sagging in the rear.
    Looking for recommendations on which air bag kit to go with. I would like it to have an on-board compressor and have the wireless control.
    What are you guys using?
  2. Feb 16, 2018 at 9:29 AM
    NY98M3
    Thanks for the reply!
    What do the cradles do? What is the benefit of the air tank over the compressor?
  3. Feb 16, 2018 at 11:25 AM
    Billyclub
    Billyclub New Member
    Glenn
    2018 Platinum Sky Silver Tundra Crewmax
    Stay away from Air Lift. Had nothing but bad luck with the wireless air and bag leak. They threw parts at me but I got tired of fixing poor design problems. Finally just disconnected the compressor and installed the manual tire inflation valves.
  4. Feb 16, 2018 at 11:51 AM
    15whtrd
    15whtrd Mr. Blonde
    Have you tried re-positioning the car just slightly further towards the rear of the trailer? Or even backing onto the trailer to distribute the weight more over the axles of the trailer than towards the tongue.
  5. Feb 16, 2018 at 11:52 AM
    NY98M3
    yes, the problem is the trailer has a 4 ft dovetail, the rear wheels on the car are on the flat area right before the slope for the dovetail. The car is back as far as it can go without being on the slope of the dovetail.
    15whtrd[QUOTED] likes this.
  6. Feb 16, 2018 at 11:55 AM
    15whtrd
    15whtrd Mr. Blonde
    Is reversed possible?
  7. Feb 19, 2018 at 11:26 AM
    NY98M3
    The car is very balanced so doing so wouldnt help.
    For those using the firestone kit, how is the wiring to get power to the compressor?
  8. Feb 19, 2018 at 11:51 AM
    Mike's Custom Toys
    Mike's Custom Toys New Member
    You run a couple wires in the cab to the gauge and switch panel. I do prefer the wireless kits cuts down on install time as well as drilling holes in customers new trucks
  9. Feb 19, 2018 at 11:57 AM
    NY98M3
    Wireless is nice, I really dont want to start drilling and tapping into harnesses.
  10. Feb 19, 2018 at 1:14 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Is that an E36 M3? :burnrubber:
  11. Feb 19, 2018 at 1:40 PM
    Big Green Thing
    Big Green Thing My cause is to have no cause.
    Dallas, TX
    '17 Limited White 4x4
    DAP Tune. 1.5" level on front. Revolver X2 Roll Back. Firestone 2445 air bags. TRD sway bar.
    I run the Firestone Ride Rights with Daystar cradles and agree with all the above that it is a great set up. I keep 10 PSI in them when not loaded and it rides great. I just throw my little portable air compressor in the truck when I know I'm going to pick up a load. It seems I usually have it with me anyway, so there is no reason for me to add another to my truck just for air bags. Great upgrade for your $.
    Tundradrenalin and Watt maker like this.
  12. Mar 3, 2018 at 3:30 PM
    NY98M3
    Just got a killer seal at Summit Racing on the Firestone 2810, I did not pay the advertised price on it. Apparently it comes with additional brackets which comes free but with a different part number. Now just need to get the cradles!
    https://www.summitracing.com/parts/FIP-2810
    **Do the airbags get bolted to the cradles? Im asking because if you look at the video, you see the metal on bottom of the airbag when the truck is bouncing...
    Let me know your thoughts
    Mountun Goat likes this.
  13. Mar 29, 2018 at 9:31 AM
    NY98M3
    Installed! I didnt realize it came with a plate to attach the compressor and ECU to.
    Both bags are blown up and holding 70psi overnight
  14. Mar 29, 2018 at 6:43 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice looks good! My dc has bags with manual valve fill at the moment. I just ordered cradles to go with my new ome Dakar leafs:). Excited to see how they work in the vid clips. One day I’ll step my game up to a compressor. I’m used to playing with air as my summer beater is a bagged c10 with dual viair compressors.
    Watt maker likes this.
  15. Mar 30, 2018 at 5:05 AM
    NY98M3
    The reason I went with the compressor is because when I get to my destination I disconnect the trailer and use the truck to drive around. The compressor makes it alot easier than playing with the schrader valves and having to find a place to fill.
    Since I dont use it often, I am going to add a hidden switch so the ECU/compressor dont power up everytime I use the truck.
  16. Mar 30, 2018 at 7:54 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    That makes sense. Use it when ya need to. Anybody hear you shouldn’t leave healer bags empty? Someone told me I should leave 5psi in it at least at all times...
  17. Apr 22, 2018 at 7:05 PM
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5
    2010 SR5 CrewMax Silver Sky Metallic 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T Transfer Flow 46 gallon ICI Magnum front bumper PML Transmission Pan Hooke Road 18” bed rack Nature Nest Hard-Shell RTT Ironman 4x4 awning Coachbuilder upgrades SuperPro LCA Bushings Total Chaos UCA’s Energy rack bushings Moog LCA Cams 2020 SR5 Double Cab Voodoo Blue 40/20/40 Front Bench TRD Pro Grille TRD Pro headlights 17x9 Vision 351 285/70 Toyo A/T3 PML Transmission Pan RCI Skidplates eBay bumpers TRD rear sway bar
    Are these air bags just for towing purposes? Or can they be used as a adjustable rear lift? Looking to ditch my 4” blocks and wondering if these would work.
  18. Apr 23, 2018 at 7:48 AM
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Yeah that was my other plan, to go all leafs. Not to thread jack, but Deaver seems to be superior to Atlas springs. Does that sound right? Thanks for the reply!
  19. Apr 23, 2018 at 9:28 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    you should leave a few psi in them when 'empty'.
    these things really work well. yours came out great.
    one thing i didnt like about having airbags in my former, lighter truck, was they really made the ride hash when emptied. maybe on heavier truck like tundra this is less of an issue.
  20. Jan 28, 2019 at 5:45 PM
    JNome
    JNome New Member
    Jake
    Michigan
    2018 Tundra Crewmax SR5 Cement
    Need a little clarification here guys. I will be installing a Leer 100xr topper and Decked system in my truck so it will have a constant bed load of 500lbs approx. I had timbrens and an add a leaf on my previous Tacoma but think I would like to go the airbag route. Also tow a boat and travel trailer at times. If you don't have the cradles is the Firestone bag attached top and bottom allowing for the possibility of tear at full suspension articulation?
  21. Jan 28, 2019 at 5:52 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    yes
    15whtrd likes this.
  22. Jan 28, 2019 at 5:56 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Thumbs up for the ride rite airbags.
    Watt maker and Mnorris1206 like this.
  23. Jan 28, 2019 at 5:59 PM
    JNome
    JNome New Member
    Jake
    Michigan
    Thanks! I like the full suspension travel aspect. Any issues with the cradles trapping rocks or other debris causing a puncture?
  24. Jan 28, 2019 at 6:01 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I don't have any problems with mine. If you are into offroading with lots of articulation then these probably won't work.
  25. Jan 28, 2019 at 6:02 PM
    Mnorris1206
    08 tundra
    This is what I use no air rides a little bumpy at times but for as much as I haul it works for me .20190116_085233.jpg
    Rebel Tundra Man and jeremyd like this.
  26. Jan 28, 2019 at 6:03 PM
    JNome
    JNome New Member
    Jake
    Michigan
    I'm not, just the occasional dirt/gravel road.
    jeremyd[QUOTED] likes this.
  27. Jan 28, 2019 at 6:05 PM
    JNome
    JNome New Member
    Jake
    Michigan
    Yup. Timbrens are nice and simple. I guess I will see how much bed sag I get with the cap and Decked system and go from there.
  28. Jan 28, 2019 at 6:05 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I've even used a bicycle pump to air my bags up ! lol
    15whtrd and Mnorris1206 like this.
  29. Jan 28, 2019 at 6:06 PM
    Mnorris1206
    08 tundra
    Got to do what you have got to do .Lol:bowdown:
  30. Jan 28, 2019 at 6:20 PM
    fishing guy
    fishing guy New Member
    Billy
    2017 White Platinum 4x4 Tundra
    N/A
    question for you guys....I tow a boat about 9500 pounds which is right at the limit for my tundra....
    What are the benefits of using air bags in the rear? Just to prevent the sag? or is there better performance with it?
