1UPPER’s 17 CM SC Platinum Custom Build
Discussion in '2.5 Gen Builds (2014-2021)' started by 1UPPER, Oct 20, 2016.
  1. May 9, 2017 at 6:53 PM
    #151
    FireAC
    FireAC New Member
    NB, Canada
    2016 Platinum Magnetic Grey Metallic
    Started looking into a Rigid SR series 30" for the bumper in my Platinum when I was at 4 Wheel Parts getting my front Bilsteins installed... I don't mind paying for quality... but are the Rigid lights really worth it? How difficult is it to install the one in the bumper. I have literally 0 experience with something like that... but they quoted me 2 hours labor for install...at $90 an hour (cad)... would love to be able to do it myself...
    By the way...your truck looks amazing!
  2. May 9, 2017 at 7:10 PM
    #152
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    Hey bud. If you do the Rigid SR light bar then you can use several brackets. You can either use Rigids bumper mount or Rago Fabrications bumper mount. If 4wheel parts is charging you for two hours for the lightbar, switch, relay and wiring then that's very fair for the time. The lightbar install is fairly simple. The wiring, relay and switch will take a little bit of planing if your not familiar with wiring. Let me know if you need any more help. Thanks for the compliment on my truck!
    FireAC[QUOTED] likes this.
  3. May 9, 2017 at 7:34 PM
    #153
    FireAC
    FireAC New Member
    NB, Canada
    Thanks for the quick reply. They didn't specify exactly what the 2 hours labor included... but supposed to be all said and done. Sounds like that might not be a bad option for me. As far as the bumper mount...why did you go with the Rago instead of Rigids own mount?
    It's probably hard for you to say, with all your other lighting... but do you think the bumper location would make you satisfied, if you could only have one in the front? I still have the Platinum grille (still considering the Pro Grill)... so that kind of limits my options if I want to keep it tucked in like that...
    I guess my worry is that it'll be too low to get the full benefit...
  4. May 9, 2017 at 7:41 PM
    #154
    1UPPER
    TEXAS
    Flux capacitor!
    The 40" grill light will be brighter than a single 30" bumper light. Several guys on here have the 40" light behind the TRD pro grill mesh. It's still very bright. You will only be able to use the light off-road since they are so bright. Even just a single row 30" bumper light is a lot of light. I liked the guy from Rago Fabrication and his product. Plus as a business owner I like to support small businesses whenever I can over a large company like Rigid. I also noticed the Rago Fabrication bracket was thicker than the rigid bracket.
  5. May 20, 2017 at 5:28 AM
    #155
    1UPPER
    TEXAS
    Flux capacitor!
    I decided to go with a different set of rear fox reservoir shocks. I wanted to have the reservoir stay black to match the front coilover reservoirs. These shocks also have better adjustability and a larger reservoir. Looking forward to these getting installed. IMG_7595.jpg
  6. May 20, 2017 at 5:49 AM
    #156
    1UPPER
    TEXAS
    Flux capacitor!
    I spoke with Auburn gears this week. I'm going to have the Auburn Gear 5420134 limited slip installed with my 4.88 gears. This will be just in the rear of the truck. I don't plan on any hardcore off roading so I'm not going with a full locker. Plus auburn didn't recommend installing a locker in the front of an independent front suspension truck. This limited slip will also help transfer the power to both rear wheels when under power or in loose conditions. Since I do plan on the Magnuson Super Charger I want the power transfer to both rear tires. This is an automatic limited slip setup. IMG_7659.jpg
    joonbug and zcarpenter92 like this.
  7. May 21, 2017 at 4:44 PM
    #157
    1UPPER
    TEXAS
    Flux capacitor!
    Here is my new grill design. It's going to house a 10" Rigid Radiance on each side of the center logo. The whole frame is double framed so I can do a two tone color to it. IMG_2982.jpg
    darkknight2014 and FireAC like this.
  8. May 27, 2017 at 7:46 PM
    #158
    1UPPER
    TEXAS
    Flux capacitor!
    I decided to go with the top grill design. I should get the grill in the next week or two. Then it's heading off to powder coating. Can't wait to get it mounted on the truck! I designed the grill to hold two 10" Rigid Radiance lightbars on the sides of the center emblem. I'm also having the backside of the center emblem done in plexiglass to backlight it with RGB lighting. So I'll have the center logo, my retrofit headlight and rock-lighting all controlled with RGB lighting. I'll have it controlled with a Bluetooth app.
    Achuop likes this.
  9. May 27, 2017 at 7:57 PM
    #159
    1UPPER
    TEXAS
    Flux capacitor!
    I ordered all my headlight retro fit parts last week. I ordered morimoto DS2 4.0 projectors with custom etching. I went with panamera shrouds and RGB backlight demon eye projectors and 110 mm halos. I'm also changing the side amber reflectors to smoke reflectors. I'll have the parts this next week. I found some bad ass switch back halos for the daytime running lights and turn signal surrounds. Here is how they look during normal running and how they look during turn signals. IMG_7751.jpg
    CTX84, Vizsla and FireAC like this.
  10. May 27, 2017 at 8:29 PM
    #160
    CTX84
    CTX84 New Member
    I saw those DRLs a few weeks ago online. They do look very nice! But the the price is too much for me to stomach. Can't wait to see how they look with your new grill. One of my favorite builds for sure!
    1UPPER[OP] likes this.
  11. May 28, 2017 at 7:10 AM
    #161
    CTX84
    CTX84 New Member
    Question for you. Do you do all these mods ur self? I've seen some of your handy work on IG is why I ask. jeremy_ersk is mine I think lol.
  12. May 28, 2017 at 7:15 AM
    #162
    1UPPER
    TEXAS
    Flux capacitor!
    Yes sir. I'm doing all the lighting and headlight retrofits myself. I planned and ordered all my lift but had it installed at a shop to have a warranty. Most of the work I do myself.
    CTX84[QUOTED] likes this.
  13. May 28, 2017 at 7:20 AM
    #163
    CTX84
    CTX84 New Member
    Well then. I'm just right up the road by Waco when you want to throw your old stuff away lol.
    1UPPER[OP] and FireAC like this.
  14. May 30, 2017 at 6:12 PM
    #164
    1UPPER
    TEXAS
    Flux capacitor!
    I got most of my retrofit headlight parts in today. I still have the LED switchback turn signal halos and LED switchback daytime running lights coming in later this week. It's going to be a lot of work but it's going to be nice when it's all done. I had the projector lenses etched with a left and right pattern. The projectors and the shrouds will have RGB LED lighting. IMG_7845.jpgIMG_7844.jpg IMG_7842.jpg
    Newm, FireAC and Kyle100 like this.
  15. May 31, 2017 at 3:44 PM
    #165
    1UPPER
    TEXAS
    Flux capacitor!
    My grill is almost done and ready to be shipped. So it will go to powder coat when I get it back. Can't wait to get it mounted on the truck! IMG_7861.jpg
  16. May 31, 2017 at 4:16 PM
    #166
    1UPPER
    TEXAS
    Flux capacitor!
    TheBeast likes this.
  17. May 31, 2017 at 4:27 PM
    #167
    TheBeast The Beach
    very nice ! lots of custom work for sure.
  18. Jun 1, 2017 at 2:47 PM
    #168
    1UPPER
    TEXAS
    Flux capacitor!
    My new grill turned out bad ass! I can't wait to get it back now! IMG_3129.jpg IMG_3130.jpg
  19. Jun 1, 2017 at 5:38 PM
    #169
    CTX84
    CTX84 New Member
    You doing a black or blue powder coat?
  20. Jun 1, 2017 at 5:44 PM
    #170
    1UPPER
    TEXAS
    Flux capacitor!
    Two tone color. I'm doing the back larger frame in the same blue as my wheels and the front frame in Black to match truck.
  21. Jun 1, 2017 at 5:56 PM
    #171
    CTX84
    CTX84 New Member
  22. Jun 2, 2017 at 1:02 PM
    #172
    1UPPER
    TEXAS
    Flux capacitor!
    My diode dynamics switchback LED boards for drls and turn signals came in today. I also ordered replacement interior & exterior LED lighting bulbs. IMG_7904.jpg
    Here are the LED boards for the drls and leds for the turn signals. IMG_7908.jpg
    CTX84 and Eclipsed & Floating like this.
  23. Jun 2, 2017 at 1:26 PM
    #173
    CTX84
    CTX84 New Member
    So are the factory DRL LEDs actual boards on the platinum/1794 and not just a strip or is the board just for the switch back feature?
  24. Jun 2, 2017 at 2:14 PM
    #174
    1UPPER
    TEXAS
    Flux capacitor!
    From what diode dynamics told me the factory leds are boards. These replace the stock boards. I haven't opened the headlights yet so I'm not 100% certain.
  25. Jun 5, 2017 at 1:52 PM
    #175
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Damn man.. killin it. Can't wait to see how the grill turns out with all the lights. We need to schedule another SA meet up!
  26. Jun 5, 2017 at 4:47 PM
    #176
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Damn @1UPPER your building a $175,000 beast!!! Looks awesome man
    GNTundra and 1UPPER[OP] like this.
  27. Jun 8, 2017 at 2:50 PM
    #177
    1UPPER
    TEXAS
    Flux capacitor!
    GNTundra and ColoradoTJ like this.
  28. Jun 8, 2017 at 2:54 PM
    #178
    1UPPER
    TEXAS
    Flux capacitor!
    I had a plexiglass insert made to backlight the center logo with an RGB LED lighting.
    ColoradoTJ, TheBeast and GNTundra like this.
  29. Jun 8, 2017 at 3:23 PM
    #179
    1UPPER
    TEXAS
    Flux capacitor!
    I like the logo detail on the top of the metal grill that replaces the stock plastic trim.
    Newm, GNTundra and PermaFrostTRD like this.
  30. Jun 8, 2017 at 4:05 PM
    #180
    1UPPER
    TEXAS
    Flux capacitor!
    Disassembled the grill so it's ready for powder coating tomorrow.
    Newm, GNTundra and CM-LENNY like this.
