1UPPER’s 17 CM SC Platinum Custom Build
Discussion in '2.5 Gen Builds (2014-2021)' started by 1UPPER, Oct 20, 2016.
  1. Dec 30, 2017 at 2:04 PM
    #271
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Nothing like new shoes bro.. nice look
    1UPPER[OP] likes this.
  2. Dec 30, 2017 at 2:36 PM
    #272
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    Thanks Jay! The new tires are always quieter and smoother.
    Jsena[QUOTED] likes this.
  3. Jan 3, 2018 at 12:35 PM
    #273
    1UPPER
    TEXAS
    Flux capacitor!
    The 2,100 mile drive to and from Coloroda with my Tundra was amazing! I used my NSV hood bulge LED light bar a lot on long dark roads. IMG_1717.jpg
    nk1794, PBH, DaBoro54 and 1 other person like this.
  4. Jan 14, 2018 at 4:56 PM
    #274
    1UPPER
    TEXAS
    Flux capacitor!
    I finally got my wiring for my rigid RGB rock lighting all done. It turned out amazing and super bright! I can change the lights to any color and set them on a a shuffle pattern and dim them.
    White Rock-lights
    Blue Rock-lights
    Green Rock-lights
    Red Rock-lights
  5. Jan 14, 2018 at 5:04 PM
    #275
    Joshea
    Joshea New Member
    JC
    2015 Tundra Limited Crewmax
    Bet, very nice
  6. Jan 19, 2018 at 1:54 PM
    #276
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    It appears you used the "Contura V" type switches and switch holder plates...do you remember what thickness works under OTRATTW "mounting plate" choices for the Tundra?
    Also, did you use their terminal housings to wire the switches with?
  7. Jan 19, 2018 at 3:45 PM
    #277
    1UPPER
    TEXAS
    Flux capacitor!
    I didn't have to use any mounting plate under the switch holder. I notched each one of the factory raised ridges so the plate lays flat.
    I made my own terminal switch mounts and soldiers & heat shrunk all my own wiring.
    Worriedman50[QUOTED] likes this.
  8. Jan 19, 2018 at 4:19 PM
    #278
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Thank you!
    1UPPER[QUOTED][OP] likes this.
  9. Jan 25, 2018 at 12:52 PM
    #279
    zlaneb
    zlaneb New Member
    Austin, TX
    @IUPPER - did you have to cut anything to get the 30 inch radiance installed in the bumper? Im being told by 4WheelParts that they don't think I can get one in that space. Feedback appreciated!
  10. Jan 25, 2018 at 1:13 PM
    #280
    Cfincke
    San Antonio
    You can fit a 40" bar with trimming.
  11. Jan 25, 2018 at 1:25 PM
    #281
    1UPPER
    TEXAS
    Flux capacitor!
    Nothing behind the bumper has to be cut. I used the Rago Fabrication bumper bracket. You can also use rigid Industries bracket. 4 wheel parts told me the same thing. No one had put a full size bar in yet. So I measured to make sure it would fit. You can see more pics on my install in my build thread. It's not a big deal to mount it.
  12. Jan 25, 2018 at 1:47 PM
    #282
    zlaneb
    zlaneb New Member
    Austin, TX
    Thanks Man, I'm headed BACK to your build page!
  13. Feb 1, 2018 at 8:02 PM
    #283
    1UPPER
    TEXAS
    Flux capacitor!
    I've got some plans to modify a set of 2018 Headlights. It's going to be something that hasn't been done yet. I'm looking forward to seeing the end results. IMG_2164.jpg
  14. Feb 12, 2018 at 4:53 AM
    #284
    Al92toyo
    Al92toyo New Member
    Alex
    2018 White Tundra Crew Max Platinum 4x4
    Hey @1UPPER, I noticed that you have the NVS hood bulge led light with their switch panel but you also have another switch labeled "Hood Vent Light". Does that control the same light bar and if so, what is the advantage to having 2 separate switches for the same light bar?
  15. Feb 12, 2018 at 5:03 AM
    #285
    1UPPER
    TEXAS
    Flux capacitor!
    Good morning. I actually had the switched labeled that way prior to my NSV bar. I used to have a 40" slim line LED in the hood bulge. I've changed my switch labels since that photo. The three switches for the NSV light bar functions are the full lightbar on, swipe back and forth and the strobe function.
    Al92toyo[QUOTED] likes this.
  16. Feb 18, 2018 at 11:24 AM
    #286
    1UPPER
    TEXAS
    Flux capacitor!
    Got the 2018 LED Fogs. Looking forward to having more light that doesn't blind everyone and I can adjust the light focus down. IMG_2460.jpg
  17. Feb 20, 2018 at 5:02 AM
    #287
    Barnj001
    Barnj001 New Member
    2017 Silver Tundra CM 4x
    Fabtech 6" + Lift 20x12 Moto Metals 35" Toyo's Stereo Upgrade
    Any change in your MPG's after the new gears were installed? Trying to figure out if I want to re-gear too. Any help would be appreciated.
    BTW, nice truck!
  18. Feb 20, 2018 at 5:47 AM
    #288
    1UPPER
    TEXAS
    Flux capacitor!
    Yes I did see an increase in MPG. I'm not a good example as to how much your MPG can increase since I like to use my gas pedal a lot. Lol What size tires are you running? By the way welcome to the forum!
  19. Feb 20, 2018 at 6:57 AM
    #289
    Barnj001
    Barnj001 New Member
    Thank you, I am running 35x 12.50 Toyo MTs. I definitely lost 2.5 MPGs when I put the lift kit on with the bigger tires. Most of my drive is at highway speeds and the truck wants to downshift on small hills. Plus if I tow I want the low end power back. I know these tires and wheels weigh a lot more than the stock ones.
    Also, from deciphering all your posts, it looks like you did a 6" ProComp drop bracket kit and then basically added a mid travel kit on top to get extra height?
    Thanks again for the quick response.
  20. Feb 20, 2018 at 6:58 PM
    #290
    1UPPER
    TEXAS
    Flux capacitor!
    I originally ordered the 7" BDS lift but decided to sell it without the fox Coil overs. I have a 7" Pro Comp lift now with fox Coil overs, fox rear reservoir Shocks, coach builder shackles, steering ends, icon upper control arms and a few other stuff. I'm very happy with my setup.
    ZPMAN likes this.
  21. Mar 9, 2018 at 5:42 PM
    #291
    1UPPER
    TEXAS
    Flux capacitor!
    Today was the perfect weather to detail and wax my Tundra. I got some photos of my truck at Toyota.
  22. Mar 11, 2018 at 9:31 AM
    #292
    1UPPER
    TEXAS
    Flux capacitor!
    Time do some fishing!
  23. Mar 11, 2018 at 12:44 PM
    #293
    Al92toyo
    Al92toyo New Member
    Alex
    Who makes the rotors and pads?
  24. Mar 11, 2018 at 1:39 PM
    #294
    1UPPER
    TEXAS
    Flux capacitor!
    Power stop rotors and pads.
    darkknight2014 and Bdh1983 like this.
  25. Mar 18, 2018 at 8:45 PM
    #295
    Bdh1983
    Bdh1983 New Member
    Somerset ky
    14 tundra cm trdoffroad
    Gtr headlights, fogs. Wet okoli covers, nsv light bar, bak flip mx4.
    Awesome truck @1UPPER. I am new here and had question if anyone has heard how to get the strobe function back on the gen 2 nsv bar? I thought about wiring per old instructions but hate to mess up brand new light
  26. Mar 18, 2018 at 8:49 PM
    #296
    1UPPER
    TEXAS
    Flux capacitor!
    Welcome to the forum. I can call the NSV rep and ask. I personally don’t think changing the wires back to the stock setting would damage your light. I’ll send him a message tomorrow. Did you look at the original instructions I posted on the NSV thread?
  27. Mar 18, 2018 at 8:51 PM
    #297
    Bdh1983
    Bdh1983 New Member
    Somerset ky
    It looked like the only difference was the #8 and #3 pin. Correct? Is that what your referring to? That would be awesome if you could find out!
  28. Mar 18, 2018 at 8:53 PM
    #298
    1UPPER
    TEXAS
    Flux capacitor!
    I haven’t compared the wiring differences between the two. I can ask him tomorrow if it’s just a wiring change. He is a cool guy who works directly with the engineers.
  29. Mar 18, 2018 at 9:08 PM
    #299
    Bdh1983
    Bdh1983 New Member
    Somerset ky
    Do that if its not to much trouble and report back please. I'd really like to find out. Thanks so much for offering. Glad to be a part of this group
  30. Mar 20, 2018 at 6:03 AM
    #300
    Bdh1983
    Bdh1983 New Member
    Somerset ky
    @1UPPER did you find out anything?
