PLC721 2017 Tundra Build
Discussion in '2.5 Gen Builds (2014-2021)' started by PLC721, Feb 5, 2017.
  1. May 2, 2017 at 9:08 PM
    #151
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    At this rate he may as well get the XL80s right? :stirthepot:
  2. May 2, 2017 at 9:19 PM
    #152
    PLC721
    PLC721 [OP] New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Absolutely he should lol
  3. May 3, 2017 at 1:38 AM
    #153
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That's pretty coo. Setup.. who has that wife eject button... lmao I seen it somewhere
  4. May 3, 2017 at 2:01 AM
    #154
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    It'd be nice. Your setup is as clean as it gets. Just a little hefty for my wallet
  5. May 3, 2017 at 8:37 AM
    #155
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    Hefty but worth it once all set up!
    Lol thanks
  6. May 16, 2017 at 9:31 PM
    #156
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    Off to Lake Powell until Sunday!
  7. Jun 5, 2017 at 11:46 AM
    #157
    thr33c
    thr33c New Member
    Have you overheated your S8 again or was it just that once? I was concerned about the heat from the engine compartment overheating the S8 in that location.
  8. Jun 13, 2017 at 3:54 PM
    #158
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    It actually was my wiring, I gave the bar to baja they went through it and didnt find anything wrong with it. I made a new harness just havent had a chance to re install everything
  9. Jun 13, 2017 at 3:58 PM
    #159
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    Also switched the 40" to White and grabbed a 30" for the lower bumper on Rigid Industries brackets.
    Vision X Canons and 40" S8
    30" S8 in Amber
  10. Jun 13, 2017 at 4:39 PM
    #160
    thr33c
    thr33c New Member
    Good to know. I have another question for you - have you noticed the top of your hood bulge (where the S8 is installed) flop around or "buzz" while cruising down the road? I also have the S8 installed there with the SDHQ kit and I can hear mine buzz when I'm going 50mph or more and if I try to look over the hood, I can actually see it vibrating.
  11. Jun 13, 2017 at 4:41 PM
    #161
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    No I have not noticed that, but i'll keep an eye out!
  12. Jun 13, 2017 at 4:56 PM
    #162
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Did you have to cut the three vertical hood supports for your hood bulge light bar?
  13. Jun 13, 2017 at 5:05 PM
    #163
    thr33c
    thr33c New Member
    Yes, you do.
  14. Jun 13, 2017 at 5:10 PM
    #164
    1UPPER
    TEXAS
    Flux capacitor!
    Ok. That's what I thought. You may want to look into adding some of the self adhesive sound deadening materials to the inside metal of the hood behind your light bar. Or use a non expansive spray foam for window or doors to fill the gap. This would eliminate the movement. Just a suggestion. Don't use the yellow spray foam since it will keep expanding and press against the hood. Use the white spray foam if you do it.
    Watt maker likes this.
  15. Jun 13, 2017 at 6:00 PM
    #165
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
  16. Jun 16, 2017 at 10:00 PM
    #166
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    The Baja designs 30" fits perfect on the rigid industries brackets!
  17. Jun 17, 2017 at 4:36 PM
    #167
    Mejarrett9
    Mejarrett9 New Member
    Charlotte, NC
    16 Crewmax 1794 super white
    More on the way
    Love it. White rocks
    PLC721[OP] and Lilly like this.
  18. Jun 20, 2017 at 7:27 PM
    #168
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Great build. Almost exactly what I want to build mine to.
    Did you get the Camburg UCAs to get more travel or was it a tire clearance issue? Or was it for the KINGs?
    2 things:
    Could you post a pic from inside the cab of the hood bulge light?
    And post a pic of the mounting of that light if you have one. Thanks.
  19. Jun 24, 2017 at 6:56 AM
    #169
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    Generally people get aftermarket uca's to dial in alignment when lifting, and also to utilize a heim which is stronger than a ball joint. And yes they do usually give additional travel benefits.
    And do you mean like an output shot from in the cab? You can't tell the bar is there from in the cab physically
  20. Jun 24, 2017 at 10:51 AM
    #170
    Baja Mike
    South Bay, Ca.
    Yeah I know about UCA. My old Tacoma had a Camburg LT kit. Lots of fun but a pita when it came to alignment. No shop could do it correctly. Was just curious if it had to do with clearance because of the wider tires. I'd like to get the KING shocks but leave the rest of the suspension parts alone.
    Yes, an output shot from inside the cab would be great. I want to see how far the throw/distance is on the bar in that location.
    And where did you find that switch panel that fits in the center console pocket. That's perfect. Love this build.
    Thanks again.
  21. Jun 25, 2017 at 9:15 PM
    #171
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    I'll see if I have an output shot or i'll get one from my buddies truck with the exact same light set up. My bar isnt even wired up right now and i havent driven my truck in like a week lmao and i just have the flush mount switch pros and my buddy made a tray that snaps it into the card holder out of ABS plastic
    Baja Mike likes this.
  22. Jun 27, 2017 at 9:14 AM
    #172
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    These are available now as well. Let me know when you want to get it installed. We apologize about the delay, I know we mentioned that we were working on it back at the beginning of April.
    Watt maker and T-Rex266 like this.
  23. Aug 14, 2017 at 3:36 PM
    #173
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Saw you Sunday @ Dobson & Warner. Truck looks sick.
  24. Aug 14, 2017 at 5:27 PM
    #174
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
  25. Sep 4, 2017 at 4:00 PM
    #175
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    Well haven't done anything at all to the Tundra except wax it once a month, only have put 1,000 miles on it since I started the academy, thank god for mandatory carpooling. Stay tuned for leather and some more color matching in the near future.
    Mandatory post wax to show off that superwhite shine
    blue16 and T-Rex266 like this.
  26. Oct 16, 2017 at 12:34 PM
    #176
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    Havent posted anything in a while!
    geno0506, blue16, TRON and 5 others like this.
  27. Nov 18, 2017 at 7:21 AM
    #177
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    TRON likes this.
  28. Nov 18, 2017 at 7:24 AM
    #178
    Tacotundra
    Tacotundra New Member
    Vegas
    2017 Tundra
  29. Nov 22, 2017 at 5:16 PM
    #179
    Baja Mike
    South Bay, Ca.
    On your Switch Pros panel, the 'Off' button, is that wired to turn everything off at once? Because that would be great.
  30. Nov 23, 2017 at 6:35 AM
    #180
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    No my "power" button turns everything on but I have to individually turn everything off
    Baja Mike[QUOTED] likes this.
