2017 Tundra brake fade
Discussion in '2.5 Gen Tundras (2014-2021)' started by marlon671, Dec 17, 2017.
  1. Dec 17, 2017 at 1:32 PM
    marlon671
    marlon671 [OP] New Member
    Marlon
    2017 MGM Tundra SR5 4x4
    Not sure what section to post this so I hope it's ok to post here.
    After my lift and 35's I've noticed when I'm going downhill especially on the hill going down to my apartment, I feel the front brakes fading. And what I mean by that is I feel a slight chatter on the pedal before it slowly loses pressure. A few pumps of the pedal and pressure comes back. I've read that upgrading to stainless lines is ideal when running bigger tires?
    Has anybody had this experience and find a fix? I can take it to the dealer but they can never seem to replicate any issues that I have. And really, with my run in with them last week, I just don't feel like giving them any business right now. I can take it to another dealer but if this is something I can remedy myself, I'd be willing to try before going to the dealer. My work schedule makes it hard for me to catch them during business hours.
    Today I placed the truck on jackstands, removed my wheels and inspected my brake lines for any damage, leaking etc. all looked nice and clean. Brake fluid was full. Pads and rotors look good. And I also bled the brakes.
    On the way back to home, still experienced the same thing. This only happens downhill, actually this I've only experienced this on that same hill going to my apt. Pretty steep grade. And I've noticed it happens when I hit the bumpy part of the pavement.
    Any ideas would be appreciated. Thanks!
  2. Dec 17, 2017 at 1:33 PM
    marlon671
    Marlon
    I also read somewhere, to go to a free area and drive about 40 mph then slam on the brakes to get the ABS system going. Supposedly that'll shake up the ABS system a bit in case something was seized?
  3. Dec 17, 2017 at 1:54 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    If it only happens on that hill, and on that particular section of pavement.....
  4. Dec 17, 2017 at 2:02 PM
    marlon671
    Marlon
    It does. Atleast that's the only place I can replicate it.
  5. Dec 17, 2017 at 2:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Then, wouldn't logic dictate....that it's the hill/pavement?
    netranger6 likes this.
  6. Dec 17, 2017 at 2:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    My truck does something similar on steep hills. Almost feels like the ABS is kicking in. Not sure about the losing pressure part though. My Grand Cherokee used to do it too.
  7. Dec 17, 2017 at 2:41 PM
    marlon671
    Marlon
    True, however not a good logic to go by considering my other vehicles don't exhibit the same behavior. Plus, I wouldnt want to use the logic of certain road conditions towards the importance of stopping.
  8. Dec 17, 2017 at 2:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are your other vehicles set up exactly like your Tundra, including actually being Tundras? If not, then you'd be changing the variables, which we'd like to try to keep to a minimum. My Tundra probably (most likely) doesn't do what yours does on that same hill, but it's not enough like yours to be a fair comparison. What might be helpful, would be to try to find a hill as much like the one heading to your apartment, and see if you have a similar experience.
  9. Dec 17, 2017 at 2:51 PM
    marlon671
    Marlon
    Yea true again. I'll probably give that a try.
    Wynnded[QUOTED] likes this.
  10. Dec 17, 2017 at 2:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    We'd be interested in your findings. Experiences like this can truly dampen the enjoyment of our vehicles.
  11. Dec 17, 2017 at 2:59 PM
    marlon671
    Marlon
    I'll definitely document what I find. Otherwise, I enjoy every 1 of the 13 miles per gallon that I get. #noragrets
  12. Dec 17, 2017 at 3:33 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I had something similar but it was when slowing (ie..to stop light) and it would never fully lock.
    Took it to dealer and they replaced the master cylinder and found the front brakes never to even touch. After the replacement I’m good as new
    Wynnded likes this.
  13. Dec 17, 2017 at 4:12 PM
    marlon671
    Marlon
    Was the dealer able to replicate the problem?
  14. Dec 17, 2017 at 9:59 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Yes, and gave me a rental because they had it while they ordered the part
  15. Jan 2, 2018 at 10:30 AM
    marlon671
    Marlon
    ***Solved***
    My issue was a simple fix. Front driver side ABS sensor was acting up. Kinda put the pieces of this puzzle together as my brake fade seems to be focused on the frint drivers side. Went to local pick n pull, pulled out another ABS sensor from a donor truck and BAM! Issue resolved. However, dissapointed by my local toyota dealer who decided to give me the run around when I brought in my truck for another issue which was related to this issue. But now, truck runs great! Thought id share my findings and maybe this will help someone along the way. Happy 2018 folks!
    Heres the link to my other post if you want to see it:
    https://www.tundras.com/threads/2017-tundra-warning-light-all-on.19311/
    jtwags, Wynnded and joonbug like this.
