2017 tundra bed lights AGAIN
Discussion in 'Lighting' started by Rowdy, Mar 11, 2018.
  1. Mar 11, 2018 at 1:19 PM
    Rowdy
    Rowdy [OP] New Member
    Jeff
    2017 Toyota tundra platinum
    I'm trying to connect bed lights to my 2017 tundra. The company claimed I can just tap into my tail lights for my 12v source. Unfortunately that didn't work unless I'm pressing the break light. These lights come with a switch wired on them. I'm just wanting to be able to turn them on ANYTIME I need to without ignition being on. Does anybody know a way I can do this? I figured I could run wire from battery to back under truck but really not wanting to go that route if i don't have to. Anyone know a place in rear of truck I can tap into for a 12v source that stays hot? Any help is greatly appreciated!
  2. Mar 11, 2018 at 1:22 PM
  3. Mar 11, 2018 at 1:23 PM
    Welcome from Texas
    Rowdy[OP] likes this.
  4. Mar 11, 2018 at 1:26 PM
    NewImprovedRon likes this.
  5. Mar 11, 2018 at 1:33 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Any 12v source that lights up the test light with the truck off. Check wires in the vicinity of your wiring, but be careful not to overload the circuit. Once you find a 12v constant, do a little research to find out what it's for before tapping it. Or run a new wire and fuse from the fuse panel on a constant 12v receptacle and wire it through a switch.
    Black Wolf likes this.
  6. Mar 11, 2018 at 1:36 PM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    I use a wire to the battery for my kits.
    Prostar 190 likes this.
  7. Mar 11, 2018 at 5:06 PM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    Check the wiring from the trailer 7 pin connector , one of those wires , usually red or black has 12v battery power
  8. Mar 11, 2018 at 5:50 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    I prefer a wire from the batt but to each there own,need to get a bed kit and hood kit for this truck soon.had it in my tacoma and miss it
  9. Mar 11, 2018 at 7:02 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    I like mine to be on its own power wire and not off the key,so i can mess with my fishing and hunting gear in the bed as needed and not fuss with my keys but thats a cool way to wire them in for sure
  10. Mar 11, 2018 at 7:32 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
