2017 TRD Pro and King 3.0
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Cavalry98, Dec 5, 2018.
  1. Dec 5, 2018 at 6:41 PM
    Cavalry98
    Cavalry98 [OP] New Member
    Georgia
    2017 Tundra TRD Pro
    Kings 3.0 front and rear Alcan Leaf pack Coachbuilder shims and shackles BAMF full bed rack Bedslide 1500
    AFF2FB99-59B4-45C5-81C3-8788229C3552.jpg Hello everyone! I want to check with everyone and get their thoughts regarding my front King 3.0 setup. Hard to explain but towards the bottom of the shock, their looks to be a large metallic washer that rattles if I drive over a sharp speed bump. Took into the local shop and they mentioned it was a safety bump inside that protects the shock if I push it too hard.
    Thing is, that silver metallic washer rattles no matter what size bump I drive over. Again, I may not be explaining this well enough but hope you can use the picture for context. You should be able to see the small opening on the bottom of the shock where I can push the washer up a little and it drops back down. Making the metal clanking sound when I drive over small bumps.
    Any ideas what is going on here? I can provide other pictures too if needed.
    TRD15559 likes this.
  2. Dec 5, 2018 at 6:44 PM
    Cavalry98
    Georgia
    2017 Tundra TRD Pro
    BD0A3CC8-9832-437A-B989-07323360179A.jpg Just in case here is a another photo for my front setup, if this helps.
  3. Dec 5, 2018 at 6:46 PM
    TheBeast The Beach
    is the noise on both sides ?
  4. Dec 5, 2018 at 6:52 PM
    Cavalry98
    Georgia
    2017 Tundra TRD Pro
    Yes, driver and passenger side both spin and freely move up along the bar about a half inch. This is what is causing the weird metal sound when the washer shakes around and drops to the bottom of the shock.
  5. Dec 5, 2018 at 6:57 PM
    Cavalry98
    Georgia
    2017 Tundra TRD Pro
    If needed I can use a ball point pen to show you the washer, just in case I am not describing what I am talking about in the picture.
  6. Dec 5, 2018 at 7:44 PM
    Vizsla
    Vizsla sGU #2
    See the black cushion bump on the shock shaft, slide it down tight to the washer.
    xma, Voyagermike, BTBAKER and 2 others like this.
  7. Dec 6, 2018 at 7:01 AM
    Cavalry98
    Georgia
    2017 Tundra TRD Pro
    Like to add that this fixed the problem. Thank you!
  8. Dec 6, 2018 at 7:08 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    I'm here just for the pictures, so much yumminess here! That tie-rod too! Glad you got help with your issues!
    xma and Voyagermike like this.
