2017 Sequoia 4x4 sway question
Discussion in '2.5 Gen Tundras (2014-2021)' started by zachn131, Jan 11, 2020.
  1. Jan 11, 2020 at 1:29 PM
    zachn131
    zachn131 [OP] New Member
    I am trying to see if there is a product for front end sway bar...I have a SST READY LIFT 3x2 and only running 33's on my sequoia but at times it feels squirrelly. I had a 12' tundra on 35's with a pro comp lift and that truck never felt squirrelly. Any advice or could point me in a good direction it would be much appreciated.
  2. Jan 11, 2020 at 1:31 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is your alignment dead on? Caster issues can cause steering to feel crappy
    AZBoatHauler likes this.
  3. Jan 11, 2020 at 1:47 PM
    zachn131
    Caster is good and Alignment could use probably a little tuning but it doesn’t feel as stable at 75 as my tundra did
  4. Jan 11, 2020 at 2:47 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    I agree an alignment would be my first move. Make sure they know why you’re there.
    What tires are you running and at what pressure?
    edit to add the shorter wheelbase of the sequoia doesn’t help either.
  5. Jan 11, 2020 at 2:49 PM
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    how many miles on the vehicle? Is this problem new since the lift or developed recently?
  6. Jan 11, 2020 at 2:59 PM
    zachn131
    I have noticed problem before but it was my wife’s vehicle before it was handed down to me when I sold my tundra to get a suburban. When we found out we were having twins we needed more room...but I have noticed it more now since I drive it every day so it could have been once the lift was installed but I honestly couldn’t tell you. There is 80k on the sequoia. I am running 33x12.5r18 nitto grapplers a/t at 38psi
  7. Jan 11, 2020 at 3:08 PM
    HidetownRed
    Top O Texas
    I have had loose feeling rides at highways speeds. Culprit was a bad tie rod end. “Squirly” ride usually means there is some play in components due to wear.
  8. Jan 11, 2020 at 3:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There is a difference in handling with a simple lift. The steeper the angle on the arms, the worse it rides and drives.
    Did you get uca’s in your lift?
  9. Jan 11, 2020 at 4:09 PM
    zachn131
    No was 3x2 just strut spaces in front and coil spacers in the rear
  10. Jan 11, 2020 at 4:12 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Sequoia TRD Sport comes with a TRD front and rear extra special Red ones.
    For as big as the rig is, the thing corners really well.
