2017 SEEPING WATER PUMP
Discussion in '2.5 Gen Tundras (2014-2021)' started by UTAHRTK, Aug 8, 2021.
  1. Aug 8, 2021 at 7:14 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    It was brought to my attention that the water pump was "leaking" on my 2017. Im at 59985 miles on the odometer so figured have it checked out at dealer with the assumption that the warranty would cover. After inspection I was notified that in order for pump to be covered it must be actively leaking! Yes I went ape shit- on the phone and at the dealer. WTF. I was told and shown that it had minor seepage sometime in the past - a small amount of pink crust. I am waiting to hear back if they will honor a "good faith" coverage. I have everything documented and I guess keeping fingers crossed. Any recommendations on a course of action if I get denied? Thanks.
  2. Aug 8, 2021 at 7:21 AM
    UTAHRTK
    SOCAL
  3. Aug 19, 2021 at 6:22 PM
    Shaken_1
    Shaken_1 New Member
    2015 TRD 4x4 OffRoad CrewMax
    Seeping and weeping are not wwarrantablemust be a actual leak however if coming out of a weep hole its s warrantable claim
  4. Aug 20, 2021 at 2:31 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Not actively leaking means that it is leaking under certain conditions that are currently present. You should be covered under warranty. The cooling system is pressurized and should never leak or seep.
  5. Aug 20, 2021 at 4:48 PM
    UTAHRTK
    SOCAL
    Agree.
